查看: 4807|回复: 1
modbus通信协议中文版 附带一部分功能码的实现源码
内容包含以下modbus 功能码的实现01
读线圈状态
00001-09999
位操作  单个或多个
02
读(开关)输入状态
10001-19999
位操作  单个或多个
03
读保持寄存器
40001-49999
字操作  单个或多个
04
读输入寄存器
30001-39999
字操作  单个或多个
05
写单个线圈
00001-09999
位操作  单个
06
写单个保持寄存器
40001-49999
字操作  单个
15
写多个线圈
00001-09999
位操作  多个
16
写多个保持寄存器
40001-49999
字操作  多个
  1. #include "modbus.h"
  2. uint16_t modbus_addr[MODBUS_SIZE + 8];
  3. //
  4. uint16_t *COIL_ADDR = modbus_addr + 8;
  5. uint16_t *STATE_ADDR = (modbus_addr + 8 + COIL_SIZE / 16);
  6. uint16_t *INPUT_ADDR = (modbus_addr + 8 + (COIL_SIZE + STATE_SIZE) / 16);
  7. uint16_t *HOLD_ADDR = (modbus_addr + 8 + (COIL_SIZE + STATE_SIZE) / 16 + INPUT_SIZE);
  8. uint16_t read_coil(uint16_t coil_addr,uint16_t reg_type)
  9. {
  10.         uint16_t i,j;
  11.         if(reg_type == REG_MODBUS)
  12.                 coil_addr -= 1;
  13.
  14.         if(coil_addr >= COIL_SIZE)
  15.                 return 0;
  16.
  17.         i = coil_addr / 16;
  18.         j = coil_addr % 16;
  19.         i = *(COIL_ADDR + i) & (1<<j);
  20.         return (i != 0);
  21. }
  22. void write_coil(uint16_t coil_addr, uint16_t on_off, uint16_t reg_type)
  23. {
  24.         uint16_t i, j, *addr;
  25.         if(reg_type == REG_MODBUS)
  26.                 coil_addr -= 1;
  27.         if(coil_addr >= COIL_SIZE)
  28.                 return;
  29.         i = coil_addr / 16;
  30.         j = coil_addr % 16;
  31.         j = 1 << j;
  32.         addr = COIL_ADDR + i;
  33.         if(on_off)
  34.         {
  35.                 *addr = ( *addr | j);
  36.         }
  37.         else
  38.         {
  39.                 *addr = (*addr & (~j));
  40.         }
  41. }
  42. uint16_t read_state(uint16_t status_addr, uint16_t reg_type)
  43. {
  44.         uint16_t i,j;
  45.         if(reg_type == REG_MODBUS)
  46.                 status_addr -= 10001;
  47.         if(status_addr >= STATE_SIZE)
  48.                 return 0;
  49.
  50.         i = status_addr / 16;
  51.         j = status_addr % 16;
  52.         i = *(STATE_ADDR + i) & (1<<j);
  53.         return (i != 0);
  54. }
  55. void write_state(uint16_t state_addr, uint16_t on_off, uint16_t reg_type)
  56. {
  57.         uint16_t i, j, *addr;
  58.         if(reg_type == REG_MODBUS)
  59.                 state_addr -= 10001;
  60.         if(state_addr >= STATE_SIZE)
  61.                 return;
  62.         i = state_addr / 16;
  63.         j = state_addr % 16;
  64.         j = 1 << j;
  65.         addr = STATE_ADDR + i;
  66.         if(on_off)
  67.         {
  68.                 *addr = (*addr | j);
  69.         }
  70.         else
  71.         {
  72.                 *addr = (*addr & (~j));
  73.         }
  74. }
  75. uint16_t read_input(uint16_t input_addr, uint16_t reg_type)
  76. {
  77.         if(reg_type == REG_MODBUS)
  78.                 input_addr -= 30001;
  79.
  80.         if(input_addr >= INPUT_SIZE)
  81.                 return 0;
  82.         return *(INPUT_ADDR + input_addr);
  83. }
  84. void write_input(uint16_t input_addr, uint16_t data, uint16_t reg_type)
  85. {
  86.         if(reg_type == REG_MODBUS)
  87.                 input_addr -= 30001;
  88.         if(input_addr >= INPUT_SIZE)
  89.                 return;
  90.         *(INPUT_ADDR + input_addr) = data;
  91. }
  92. uint16_t read_hold(uint16_t hold_addr,uint16_t reg_type)
  93. {
  94.         if(reg_type == REG_MODBUS)
  95.                 hold_addr -= 40001;
  96.
  97.         if(hold_addr >= HOLD_SIZE)
  98.                 return 0;
  99.         return *(HOLD_ADDR + hold_addr);
  100. }
  101. void write_hold(uint16_t hold_addr, uint16_t data, uint16_t reg_type)
  102. {
  103.         if(reg_type == REG_MODBUS)
  104.                 hold_addr -= 40001;
  105.         if(hold_addr >= HOLD_SIZE)
  106.                 return;
  107.         *(HOLD_ADDR + hold_addr) = data;
  108. }
  109. uint16_t read_reg_n(uint16_t reg_addr)
  110. {
  111.         if((reg_addr >= 1) && (reg_addr <= COIL_SIZE))
  112.                 return read_coil(reg_addr, REG_MODBUS);
  113.         if((reg_addr >=10001) && (reg_addr <=(10000+STATE_SIZE)))
  114.                 return read_state(reg_addr ,REG_MODBUS);
  115.         if((reg_addr >=30001) && (reg_addr <=(30000+INPUT_SIZE)))
  116.                 return read_input(reg_addr ,REG_MODBUS);
  117.         if((reg_addr >=40001) && (reg_addr <=(40000+HOLD_SIZE)))
  118.                 return read_hold(reg_addr ,REG_MODBUS);
  119.         return 0;
  120. }
  121. /*???????*/
  122. void write_reg_n(uint16_t reg_addr ,uint16_t data)
  123. {
  124.         if((reg_addr >=1) && (reg_addr <=COIL_SIZE))
  125.                 write_coil(reg_addr ,data,REG_MODBUS);
  126.         else if((reg_addr >=10001) && (reg_addr <=(10000+STATE_SIZE)))
  127.                 write_state(reg_addr ,data,REG_MODBUS);
  128.         else if((reg_addr >=30001) && (reg_addr <=(30000+INPUT_SIZE)))
  129.                 write_input(reg_addr ,data,REG_MODBUS);
  130.         else if((reg_addr >=40001) && (reg_addr <=(40000+HOLD_SIZE)))
  131.                 write_hold(reg_addr ,data,REG_MODBUS);
  132.         else;
  133. }
  134. /*??????? swap=0-???? 1-????*/
  135. float read_reg_f(uint16_t reg_addr ,uint8_t swap)
  136. {
  137.         union { uint32_t i; float f; } w;
  138.         if((reg_addr >=30001) && (reg_addr <=(30000+INPUT_SIZE)))
  139.         {
  140.                 if(swap==1)
  141.                         w.i=(read_input(reg_addr ,REG_MODBUS)<<16)+read_input(reg_addr +1,REG_MODBUS);
  142.                 else
  143.                         w.i=read_input(reg_addr ,REG_MODBUS)+(read_input(reg_addr +1,REG_MODBUS)<<16);
  144.                 return w.f;
  145.         }
  146.         else if((reg_addr >=40001) && (reg_addr <=(40000+HOLD_SIZE)))
  147.         {
  148.                 if(swap==1)
  149.                         w.i=(read_hold(reg_addr ,REG_MODBUS)<<16)+read_hold(reg_addr +1,REG_MODBUS);
  150.                 else
  151.                         w.i=read_hold(reg_addr ,REG_MODBUS)+(read_hold(reg_addr +1,REG_MODBUS)<<16);
  152.                 return w.f;
  153.         }
  154.         else;
  155.         return 0.0;
  156. }
  157. /*??????? swap=0-???? 1-????*/
  158. void write_reg_f(uint16_t reg_addr ,float data,uint8_t swap)
  159. {
  160.         union { uint32_t i; float f; } w;                /*????????  ??:????ADP3?????!!!*/
  161.         w.f=data;
  162.         if((reg_addr >=30001) && (reg_addr <=(30000+INPUT_SIZE)))
  163.         {
  164.                 if(swap==1)
  165.                 {
  166.                         write_input(reg_addr ,w.i>>16,REG_MODBUS);
  167.                         write_input(reg_addr +1,w.i,REG_MODBUS);
  168.                 }
  169.                 else
  170.                 {
  171.                         write_input(reg_addr ,w.i,REG_MODBUS);
  172.                         write_input(reg_addr +1,w.i>>16,REG_MODBUS);
  173.                 }
  174.         }
  175.         else if((reg_addr>=40001) && (reg_addr<=(40000+HOLD_SIZE)))
  176.         {
  177.                 if(swap==1)
  178.                 {
  179.                         write_hold(reg_addr,w.i>>16,REG_MODBUS);
  180.                         write_hold(reg_addr+1,w.i,REG_MODBUS);
  181.                 }
  182.                 else
  183.                 {
  184.                         write_hold(reg_addr,w.i,REG_MODBUS);
  185.                         write_hold(reg_addr+1,w.i>>16,REG_MODBUS);
  186.                 }
  187.         }
  188.         else;
  189. }
  190. /*???????? swap=0-???? 1-????*/
  191. uint32_t read_reg_ln(uint16_t reg_addr, uint8_t swap)
  192. {
  193.         uint32_t i = 0;
  194.         if((reg_addr >= 30001) && (reg_addr <= (30000 + INPUT_SIZE)))
  195.         {
  196.                 if(swap == 1)
  197.                         i = (read_input(reg_addr, REG_MODBUS) << 16) + read_input(reg_addr + 1, REG_MODBUS);
  198.                 else
  199.                         i = read_input(reg_addr, REG_MODBUS) + (read_input(reg_addr + 1, REG_MODBUS) << 16);
  200.         }
  201.         else if((reg_addr >= 40001) && (reg_addr <= (40000 + HOLD_SIZE)))
  202.         {
  203.                 if(swap == 1)
  204.                         i = (read_hold(reg_addr, REG_MODBUS) << 16) + read_hold(reg_addr + 1,REG_MODBUS);
  205.                 else
  206.                         i = read_hold(reg_addr, REG_MODBUS) + (read_hold(reg_addr + 1, REG_MODBUS) << 16);
  207.         }
  208.         else;
  209.         return i;
  210. }
  211. void write_reg_ln(uint16_t reg_addr, uint32_t data, uint8_t swap)
  212. {
  213.         uint32_t i;
  214.         i = data;
  215.         if((reg_addr >= 30001) && (reg_addr<=(30000 + INPUT_SIZE)))
  216.         {
  217.                 if(swap==1)
  218.                 {
  219.                         write_input(reg_addr, i >> 16,REG_MODBUS);
  220.                         write_input(reg_addr + 1, i, REG_MODBUS);
  221.                 }
  222.                 else
  223.                 {
  224.                         write_input(reg_addr, i, REG_MODBUS);
  225.                         write_input(reg_addr + 1, i >> 16, REG_MODBUS);
  226.                 }
  227.         }
  228.         else if((reg_addr >= 40001) && (reg_addr <= (40000 + HOLD_SIZE)))
  229.         {
  230.                 if(swap==1)
  231.                 {
  232.                         write_hold(reg_addr, i >> 16, REG_MODBUS);
  233.                         write_hold(reg_addr + 1, i, REG_MODBUS);
  234.                 }
  235.                 else
  236.                 {
  237.                         write_hold(reg_addr, i, REG_MODBUS);
  238.                         write_hold(reg_addr + 1, i >> 16, REG_MODBUS);
  239.                 }
  240.         }
  241.         else;
  242. }
  243. uint8_t LRC(uint8_t *auchMsg, uint16_t usDataLen)
  244. {
  245.         uint8_t uchLRC = 0 ;
  246.         while (usDataLen--) { uchLRC += *auchMsg++ ; }
  247.         return ((uint8_t)(~uchLRC+1));
  248. }
  249. static const uint8_t auchCRCHi[]={
  250. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  251. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  252. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  253. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  254. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  255. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  256. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  257. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  258. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  259. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  260. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  261. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  262. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,
  263. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  264. 0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40,0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,
  265. 0x00,0xc1,0x81,0x40,0x01,0xc0,0x80,0x41,0x01,0xc0,0x80,0x41,0x00,0xc1,0x81,0x40
  266. };
  267. static const uint8_t auchCRCLo[]={
  268. 0x00,0xc0,0xc1,0x01,0xc3,0x03,0x02,0xc2,0xc6,0x06,0x07,0xc7,0x05,0xc5,0xc4,0x04,
  269. 0xcc,0x0c,0x0d,0xcd,0x0f,0xcf,0xce,0x0e,0x0a,0xca,0xcb,0x0b,0xc9,0x09,0x08,0xc8,
  270. 0xd8,0x18,0x19,0xd9,0x1b,0xdb,0xda,0x1a,0x1e,0xde,0xdf,0x1f,0xdd,0x1d,0x1c,0xdc,
  271. 0x14,0xd4,0xd5,0x15,0xd7,0x17,0x16,0xd6,0xd2,0x12,0x13,0xd3,0x11,0xd1,0xd0,0x10,
  272. 0xf0,0x30,0x31,0xf1,0x33,0xf3,0xf2,0x32,0x36,0xf6,0xf7,0x37,0xf5,0x35,0x34,0xf4,
  273. 0x3c,0xfc,0xfd,0x3d,0xff,0x3f,0x3e,0xfe,0xfa,0x3a,0x3b,0xfb,0x39,0xf9,0xf8,0x38,
  274. 0x28,0xe8,0xe9,0x29,0xeb,0x2b,0x2a,0xea,0xee,0x2e,0x2f,0xef,0x2d,0xed,0xec,0x2c,
  275. 0xe4,0x24,0x25,0xe5,0x27,0xe7,0xe6,0x26,0x22,0xe2,0xe3,0x23,0xe1,0x21,0x20,0xe0,
  276. 0xa0,0x60,0x61,0xa1,0x63,0xa3,0xa2,0x62,0x66,0xa6,0xa7,0x67,0xa5,0x65,0x64,0xa4,
  277. 0x6c,0xac,0xad,0x6d,0xaf,0x6f,0x6e,0xae,0xaa,0x6a,0x6b,0xab,0x69,0xa9,0xa8,0x68,
  278. 0x78,0xb8,0xb9,0x79,0xbb,0x7b,0x7a,0xba,0xbe,0x7e,0x7f,0xbf,0x7d,0xbd,0xbc,0x7c,
  279. 0xb4,0x74,0x75,0xb5,0x77,0xb7,0xb6,0x76,0x72,0xb2,0xb3,0x73,0xb1,0x71,0x70,0xb0,
  280. 0x50,0x90,0x91,0x51,0x93,0x53,0x52,0x92,0x96,0x56,0x57,0x97,0x55,0x95,0x94,0x54,
  281. 0x9c,0x5c,0x5d,0x9d,0x5f,0x9f,0x9e,0x5e,0x5a,0x9a,0x9b,0x5b,0x99,0x59,0x58,0x98,
  282. 0x88,0x48,0x49,0x89,0x4b,0x8b,0x8a,0x4a,0x4e,0x8e,0x8f,0x4f,0x8d,0x4d,0x4c,0x8c,
  283. 0x44,0x84,0x85,0x45,0x87,0x47,0x46,0x86,0x82,0x42,0x43,0x83,0x41,0x81,0x80,0x40
  284. };
  285. uint16_t CRC16(uint8_t* puchMsg, uint16_t usDataLen)
  286. {
  287.         uint8_t uchCRCHi=0xff;
  288.         uint8_t uchCRCLo=0xff;
  289.         uint16_t uIndex;
  290.         while(usDataLen--)
  291.         {
  292.                 uIndex=uchCRCHi^*(puchMsg++);
  293.                 uchCRCHi=uchCRCLo^auchCRCHi[uIndex];
  294.                 uchCRCLo=auchCRCLo[uIndex];
  295.         }
  296.         return uchCRCHi<<8|uchCRCLo;
  297. }
  298. uint16_t sx2toi(uint8_t *str)
  299. {
  300.         uint16_t i=0;
  301.
  302.         if((str[0]>='0') && (str[0]<='9'))                 i=(str[0]-'0')<<4;
  303.         else if((str[0]>='A') && (str[0]<='F')) i=(str[0]-'A'+10)<<4;
  304.         else if((str[0]>='a') && (str[0]<='f')) i=(str[0]-'a'+10)<<4;
  305.         else;
  306.         if((str[1]>='0') && (str[1]<='9'))                 i=i+str[1]-'0';
  307.         else if((str[1]>='A') && (str[1]<='F')) i=i+str[1]-'A'+10;
  308.         else if((str[1]>='a') && (str[1]<='f')) i=i+str[1]-'a'+10;
  309.         else;
  310.
  311.         return i;
  312. }
  313. void itosx2(uint16_t data,uint8_t *str)
  314. {
  315.         uint16_t i,j;
  316.
  317.         i=(data & 0xf0)>>4; j=data & 0x0f;
  318.
  319.         if(i<=9)         str[0]='0'+i;
  320.         else                 str[0]='A'+i-10;
  321.         if(j<=9)         str[1]='0'+j;
  322.         else                 str[1]='A'+j-10;
  323. }
  324. uint16_t modbus_asc_hex(uint8_t *asc_buf,uint16_t num)
  325. {
  326.         uint16_t i;
  327.         num=(num-3)/2;
  328.         for(i=0;i<num;i++)
  329.         { asc_buf[i]=(uint8_t)sx2toi(&asc_buf[i*2+1]); }
  330.         return i;
  331. }
  332. uint16_t modbus_hex_asc(uint8_t *hex_buf,uint8_t *asc_buf,uint16_t num)
  333. {
  334.         uint16_t i;
  335.         asc_buf[0]=':';
  336.         for(i=0;i<num;i++)
  337.         { itosx2((uint16_t)hex_buf[i],&asc_buf[i*2+1]); }
  338.         num=num*2+1;
  339.         asc_buf[num]='\r'; num++;
  340.         asc_buf[num]='\n'; num++;
  341.         return num;
  342. }
  343. static const uint32_t crc32tab[] =
  344. {
  345. 0x00000000L, 0x77073096L, 0xee0e612cL, 0x990951baL,
  346. 0x076dc419L, 0x706af48fL, 0xe963a535L, 0x9e6495a3L,
  347. 0x0edb8832L, 0x79dcb8a4L, 0xe0d5e91eL, 0x97d2d988L,
  348. 0x09b64c2bL, 0x7eb17cbdL, 0xe7b82d07L, 0x90bf1d91L,
  349. 0x1db71064L, 0x6ab020f2L, 0xf3b97148L, 0x84be41deL,
  350. 0x1adad47dL, 0x6ddde4ebL, 0xf4d4b551L, 0x83d385c7L,
  351. 0x136c9856L, 0x646ba8c0L, 0xfd62f97aL, 0x8a65c9ecL,
  352. 0x14015c4fL, 0x63066cd9L, 0xfa0f3d63L, 0x8d080df5L,
  353. 0x3b6e20c8L, 0x4c69105eL, 0xd56041e4L, 0xa2677172L,
  354. 0x3c03e4d1L, 0x4b04d447L, 0xd20d85fdL, 0xa50ab56bL,
  355. 0x35b5a8faL, 0x42b2986cL, 0xdbbbc9d6L, 0xacbcf940L,
  356. 0x32d86ce3L, 0x45df5c75L, 0xdcd60dcfL, 0xabd13d59L,
  357. 0x26d930acL, 0x51de003aL, 0xc8d75180L, 0xbfd06116L,
  358. 0x21b4f4b5L, 0x56b3c423L, 0xcfba9599L, 0xb8bda50fL,
  359. 0x2802b89eL, 0x5f058808L, 0xc60cd9b2L, 0xb10be924L,
  360. 0x2f6f7c87L, 0x58684c11L, 0xc1611dabL, 0xb6662d3dL,
  361. 0x76dc4190L, 0x01db7106L, 0x98d220bcL, 0xefd5102aL,
  362. 0x71b18589L, 0x06b6b51fL, 0x9fbfe4a5L, 0xe8b8d433L,
  363. 0x7807c9a2L, 0x0f00f934L, 0x9609a88eL, 0xe10e9818L,
  364. 0x7f6a0dbbL, 0x086d3d2dL, 0x91646c97L, 0xe6635c01L,
  365. 0x6b6b51f4L, 0x1c6c6162L, 0x856530d8L, 0xf262004eL,
  366. 0x6c0695edL, 0x1b01a57bL, 0x8208f4c1L, 0xf50fc457L,
  367. 0x65b0d9c6L, 0x12b7e950L, 0x8bbeb8eaL, 0xfcb9887cL,
  368. 0x62dd1ddfL, 0x15da2d49L, 0x8cd37cf3L, 0xfbd44c65L,
  369. 0x4db26158L, 0x3ab551ceL, 0xa3bc0074L, 0xd4bb30e2L,
  370. 0x4adfa541L, 0x3dd895d7L, 0xa4d1c46dL, 0xd3d6f4fbL,
  371. 0x4369e96aL, 0x346ed9fcL, 0xad678846L, 0xda60b8d0L,
  372. 0x44042d73L, 0x33031de5L, 0xaa0a4c5fL, 0xdd0d7cc9L,
  373. 0x5005713cL, 0x270241aaL, 0xbe0b1010L, 0xc90c2086L,
  374. 0x5768b525L, 0x206f85b3L, 0xb966d409L, 0xce61e49fL,
  375. ……………………
  376. …………限于本文篇幅 余下代码请从51黑下载附件…………
modbus.zip (1.09 MB, 下载次数: 68)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:235062 发表于 2019-10-14 11:21 | 只看该作者
下载了,谢谢楼主
