查看: 7229|回复: 1
基于STM32F4系列单片机的OLED驱动程序源码
自己在驱动oled的时候找了很多资料,看了很多示例代码。总觉得那些代码兼容性很好,但是作为单片机初学者来说
过于冗杂。所以自己整理了一下。加上了一点自己想法,写了这个精简版得oled驱动程序。
实物图如下:
  1. /*
  2.         STM32F429
  3.         这个是基于9.6 oled的驱动程序
  4.         仅供学习参考,代码较为简单,未进行注释
  5.         交流联系方式 1452912499@qq.com
  6. #
  7. */
  8. #include "bsp_SPI.h"
  9. uint32_t time;
  10. uint8_t OLED_GRAM[8][128];
  11. extern uint8_t font[94][16];
  12. void SPI_Config(void)
  13. {
  14.         GPIO_InitTypeDef GP;
  15.
  16.         RCC_AHB1PeriphClockCmd(SPI_NSS_CLK|SPI_SCK_CLK|SPI_MOSI_CLK|SPI_DC_CLK|SPI_REST_CLK,ENABLE);
  17.
  18.
  19.         GP.GPIO_Mode =GPIO_Mode_OUT;
  20.         GP.GPIO_OType = GPIO_OType_PP;
  21.         GP.GPIO_PuPd = GPIO_PuPd_UP;
  22.         GP.GPIO_Speed = GPIO_Speed_50MHz;
  23.
  24.
  25.         GP.GPIO_Pin = SPI_NSS_Pin;
  26.         GPIO_Init(SPI_NSS_Port,&GP);
  27.
  28.         GP.GPIO_Pin = SPI_REST_Pin;
  29.         GPIO_Init(SPI_REST_Port,&GP);
  30.
  31.         GP.GPIO_Pin = SPI_DC_Pin;
  32.         GPIO_Init(SPI_DC_Port,&GP);
  33.
  34.         GP.GPIO_Pin = SPI_SCK_Pin;
  35.         GPIO_Init(SPI_SCK_Port,&GP);
  36.
  37.         GP.GPIO_Pin = SPI_MOSI_Pin;
  38.         GPIO_Init(SPI_MOSI_Port,&GP);
  39.
  40.         DC_HIGH
  41.         CS_HIGH
  42.         DATA_HIGH
  43.         CLK_HIGH
  44.
  45. }
  46. void OLED_Config(void)
  47. {
  48.
  49.
  50.         SysTick_Init();
  51.         Rest_HIGH
  52.         Delay_us(10000);
  53.         Rest_LOW//初始化
  54.         Delay_us(10000);
  55.         Rest_HIGH
  56.
  57.   Write(0xAE,CMD);//--turn off oled panel
  58.         Write(0x00,CMD);//---set low column address
  59.         Write(0x10,CMD);//---set high column address
  60.         Write(0x40,CMD);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
  61.         Write(0x81,CMD);//--set contrast control register
  62.         Write(0xCF,CMD); // Set SEG Output Current Brightness
  63.         Write(0xA1,CMD);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
  64.         Write(0xC8,CMD);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
  65.         Write(0xA6,CMD);//--set normal display
  66.         Write(0xA8,CMD);//--set multiplex ratio(1 to 64)
  67.         Write(0x3f,CMD);//--1/64 duty
  68.         Write(0xD3,CMD);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
  69.         Write(0x00,CMD);//-not offset
  70.         Write(0xd5,CMD);//--set display clock divide ratio/oscillator frequency
  71.         Write(0x80,CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
  72.         Write(0xD9,CMD);//--set pre-charge period
  73.         Write(0xF1,CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
  74.         Write(0xDA,CMD);//--set com pins hardware configuration
  75.         Write(0x12,CMD);
  76.         Write(0xDB,CMD);//--set vcomh
  77.         Write(0x40,CMD);//Set VCOM Deselect Level
  78.         Write(0x20,CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
  79.         Write(0x02,CMD);//
  80.         Write(0x8D,CMD);//--set Charge Pump enable/disable
  81.         Write(0x14,CMD);//--set(0x10) disable
  82.         Write(0xA4,CMD);// Disable Entire Display On (0xa4/0xa5)
  83.         Write(0xA6,CMD);// Disable Inverse Display On (0xa6/a7)
  84.         Write(0xAF,CMD);//--turn on oled panel
  85.
  86.         OLED_Clear();
  87. }
  88. void Updata(void)
  89. {
  90.
  91.
  92.         uint8_t i,n;
  93.   for(i=0;i<8;i++)
  94.   {
  95.         Write(0xb0+i,CMD);
  96.         Write(0x00,CMD);
  97.         Write(0x10,CMD);
  98.         for(n=0;n<128;n++){Write(OLED_GRAM[i][n],DATA);}
  99.   }
  100. }
  101. void Write(uint8_t data,uint8_t x)
  102. {
  103.         uint8_t i;
  104.         if(x)
  105.         {
  106.                 DC_HIGH
  107.         }
  108.         else
  109.         {
  110.                 DC_LOW
  111.         }
  112.         CS_LOW
  113. for(i=0;i<8;i++)
  114.         {
  115.                 CLK_LOW
  116.                 if(data&0x80)
  117.                         DATA_HIGH
  118.                 else
  119.                         DATA_LOW
  120.                 CLK_HIGH
  121.                 data<<=1;
  122.         }
  123.         CS_HIGH
  124.         DC_HIGH
  125. }
  126. void OLED_Clear(void)
  127. {
  128.
  129.         uint8_t i,n;
  130.   for(i=0;i<8;i++)
  131.   {
  132.         Write(0xb0+i,CMD);
  133.         Write(0x00,CMD);
  134.         Write(0x10,CMD);
  135.         for(n=0;n<128;n++)Write(0x00,DATA);
  136.   }
  137.
  138. }
  139. void ConPart(uint8_t x,uint8_t y,uint8_t *map)
  140. {
  141.         uint8_t y2;
  142.         for(y2 =0;y2<8&&y2+y<128;y2++)
  143.         {
  144.                                 OLED_GRAM[x][y2+y] = *(map+y2);
  145.         }
  146. ……………………
  147. …………限于本文篇幅 余下代码请从51黑下载附件…………
OLED-429模拟SPI.rar (4.2 MB, 下载次数: 113)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:517861 发表于 2019-8-28 11:16 | 只看该作者
看起来很厉害的样子
