查看: 3294|回复: 0
stm32手写识别源程序代码
ID:385269 发表于 2018-8-11 15:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
stm32手写识别
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "malloc.h"
  8. #include "sdio_sdcard.h"
  9. #include "w25qxx.h"
  10. #include "ff.h"
  11. #include "exfuns.h"
  12. #include "text.h"
  13. #include "atk_ncr.h"
  14. #include "touch.h"
  15. //最大记录的轨迹点数
  16. atk_ncr_point READ_BUF[200];
  17. //画水平线
  18. //x0,y0:坐标
  19. //len:线长度
  20. //color:颜色
  21. void gui_draw_hline(u16 x0,u16 y0,u16 len,u16 color)
  22. {
  23.         if(len==0)return;
  24.         LCD_Fill(x0,y0,x0+len-1,y0,color);
  25. }
  26. //画实心圆
  27. //x0,y0:坐标
  28. //r:半径
  29. //color:颜色
  30. void gui_fill_circle(u16 x0,u16 y0,u16 r,u16 color)
  31. {
  32.         u32 i;
  33.         u32 imax = ((u32)r*707)/1000+1;
  34.         u32 sqmax = (u32)r*(u32)r+(u32)r/2;
  35.         u32 x=r;
  36.         gui_draw_hline(x0-r,y0,2*r,color);
  37.         for (i=1;i<=imax;i++)
  38.         {
  39.                 if ((i*i+x*x)>sqmax)// draw lines from outside
  40.                 {
  41.                          if (x>imax)
  42.                         {
  43.                                 gui_draw_hline (x0-i+1,y0+x,2*(i-1),color);
  44.                                 gui_draw_hline (x0-i+1,y0-x,2*(i-1),color);
  45.                         }
  46.                         x--;
  47.                 }
  48.                 // draw lines from inside (center)
  49.                 gui_draw_hline(x0-x,y0+i,2*x,color);
  50.                 gui_draw_hline(x0-x,y0-i,2*x,color);
  51.         }
  52. }
  53. //两个数之差的绝对值
  54. //x1,x2:需取差值的两个数
  55. //返回值:|x1-x2|
  56. u16 my_abs(u16 x1,u16 x2)
  57. {
  58.         if(x1>x2)return x1-x2;
  59.         else return x2-x1;
  60. }
  61. //画一条粗线
  62. //(x1,y1),(x2,y2):线条的起始坐标
  63. //size:线条的粗细程度
  64. //color:线条的颜色
  65. void lcd_draw_bline(u16 x1, u16 y1, u16 x2, u16 y2,u8 size,u16 color)
  66. {
  67.         u16 t;
  68.         int xerr=0,yerr=0,delta_x,delta_y,distance;
  69.         int incx,incy,uRow,uCol;
  70.         if(x1<size|| x2<size||y1<size|| y2<size)return;
  71.         delta_x=x2-x1; //计算坐标增量
  72.         delta_y=y2-y1;
  73.         uRow=x1;
  74.         uCol=y1;
  75.         if(delta_x>0)incx=1; //设置单步方向
  76.         else if(delta_x==0)incx=0;//垂直线
  77.         else {incx=-1;delta_x=-delta_x;}
  78.         if(delta_y>0)incy=1;
  79.         else if(delta_y==0)incy=0;//水平线
  80.         else{incy=-1;delta_y=-delta_y;}
  81.         if( delta_x>delta_y)distance=delta_x; //选取基本增量坐标轴
  82.         else distance=delta_y;
  83.         for(t=0;t<=distance+1;t++ )//画线输出
  84.         {
  85.                 gui_fill_circle(uRow,uCol,size,color);//画点
  86.                 xerr+=delta_x ;
  87.                 yerr+=delta_y ;
  88.                 if(xerr>distance)
  89.                 {
  90.                         xerr-=distance;
  91.                         uRow+=incx;
  92.                 }
  93.                 if(yerr>distance)
  94.                 {
  95.                         yerr-=distance;
  96.                         uCol+=incy;
  97.                 }
  98.         }
  99. }
  100. int main(void)
  101. {
  102.          u8 i=0;
  103.         u8 tcnt=0;
  104.         u8 res[10];
  105.         u8 key;
  106.         u16 pcnt=0;
  107.         u8 mode=4;                                        //默认是混合模式
  108.          u16 lastpos[2];                                //最后一次的数据
  109.
  110.         delay_init();                     //延时函数初始化
  111.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
  112.         uart_init(115200);                 //串口初始化为115200
  113.          LED_Init();                                          //初始化与LED连接的硬件接口
  114.         KEY_Init();                                        //初始化按键
  115.         LCD_Init();                                           //初始化LCD
  116.         W25QXX_Init();                                //初始化W25Q128
  117.         tp_dev.init();                                //初始化触摸屏
  118.          my_mem_init(SRAMIN);                //初始化内部内存池
  119.         exfuns_init();                                //为fatfs相关变量申请内存
  120.          f_mount(fs[0],"0:",1);                 //挂载SD卡
  121.          f_mount(fs[1],"1:",1);                 //挂载FLASH.
  122.         alientek_ncr_init();                //初始化手写识别
  123.         POINT_COLOR=RED;
  124.          while(font_init())                         //检查字库
  125.         {
  126.                 LCD_ShowString(30,50,200,16,16,"Font Error!");
  127.                 delay_ms(200);
  128.                 LCD_Fill(30,50,240,66,WHITE);//清除显示
  129.         }
  130. RESTART:
  131.         Show_Str(30,10,200,16,"战舰 STM32开发板",16,0);
  132.         Show_Str(30,30,200,16,"手写识别实验",16,0);
  133.         Show_Str(30,50,200,16,"正点原子@ALIENTEK",16,0);
  134.         Show_Str(30,70,200,16,"KEY0:MODE KEY_UP:Adjust",16,0);
  135.         Show_Str(30,90,200,16,"识别结果:",16,0);
  136.         LCD_DrawRectangle(19,114,lcddev.width-20,lcddev.height-5);
  137.         POINT_COLOR=BLUE;
  138.         Show_Str(96,207,200,16,"手写区",16,0);
  139.         tcnt=100;
  140.         tcnt=100;
  141.         while(1)
  142.         {
  143.                 key=KEY_Scan(0);
  144.                 if(key==WKUP_PRES&&(tp_dev.touchtype&0X80)==0)
  145.                 {
  146.                         TP_Adjust();          //屏幕校准
  147.                         LCD_Clear(WHITE);
  148.                         goto RESTART;        //重新加载界面
  149.                 }
  150.                 if(key==KEY0_PRES)
  151.                 {
  152.                         LCD_Fill(20,115,219,314,WHITE);//清除当前显示
  153.                         mode++;
  154.                         if(mode>4)mode=1;
  155.                         switch(mode)
  156.                         {
  157.                                 case 1:
  158.                                         Show_Str(80,207,200,16,"仅识别数字",16,0);
  159.                                         break;
  160.                                 case 2:
  161.                                         Show_Str(64,207,200,16,"仅识别大写字母",16,0);
  162.                                         break;
  163.                                 case 3:
  164.                                         Show_Str(64,207,200,16,"仅识别小写字母",16,0);
  165.                                         break;
  166.                                 case 4:
  167.                                         Show_Str(88,207,200,16,"全部识别",16,0);
  168.                                         break;
  169.                         }
  170.                         tcnt=100;
  171.                 }
  172.                  tp_dev.scan(0);//扫描
  173.                  if(tp_dev.sta&TP_PRES_DOWN)//有按键被按下
  174.                 {
  175.                         delay_ms(1);//必要的延时,否则老认为有按键按下.
  176.                          tcnt=0;//松开时的计数器清空
  177.                         if((tp_dev.x[0]<(lcddev.width-20-2)&&tp_dev.x[0]>=(20+2))&&(tp_dev.y[0]<(lcddev.height-5-2)&&tp_dev.y[0]>=(115+2)))
  178.                         {
  179.                                 if(lastpos[0]==0XFFFF)
  180.                                 {
  181.                                         lastpos[0]=tp_dev.x[0];
  182.                                         lastpos[1]=tp_dev.y[0];
  183.                                 }
  184.                                 lcd_draw_bline(lastpos[0],lastpos[1],tp_dev.x[0],tp_dev.y[0],2,BLUE);//画线
  185.                                 lastpos[0]=tp_dev.x[0];
  186.                                 lastpos[1]=tp_dev.y[0];
  187.                                 if(pcnt<200)//总点数少于200
  188.                                 {
  189.                                         if(pcnt)
  190.                                         {
  191.                                                 if((READ_BUF[pcnt-1].y!=tp_dev.y[0])&&(READ_BUF[pcnt-1].x!=tp_dev.x[0]))//x,y不相等
  192.                                                 {
  193.                                                         READ_BUF[pcnt].x=tp_dev.x[0];
  194.                                                         READ_BUF[pcnt].y=tp_dev.y[0];
  195.                                                         pcnt++;
  196.                                                 }
  197.                                         }else
  198.                                         {
  199.                                                 READ_BUF[pcnt].x=tp_dev.x[0];
  200.                                                 READ_BUF[pcnt].y=tp_dev.y[0];
  201.                                                 pcnt++;
  202.                                         }
  203.                                 }
  204.                         }
  205.                 }else //按键松开了
  206.                 {
  207.                         lastpos[0]=0XFFFF;
  208.                         tcnt++;
  209.                         delay_ms(10);
  210.                         //延时识别
  211.                         i++;
  212.                         if(tcnt==40)
  213.                         {
  214.                                 if(pcnt)//有有效的输入
  215.                                 {
  216.                                         printf("总点数:%d\r\n",pcnt);
  217.                                         alientek_ncr(READ_BUF,pcnt,6,mode,(char*)res);
  218.                                         printf("识别结果:%s\r\n",res);
  219.                                         pcnt=0;
  220.                                           POINT_COLOR=BLUE;//设置画笔蓝色
  221.                                          LCD_ShowString(30+72,90,200,16,16,res);
  222. ……………………
  223. …………限于本文篇幅 余下代码请从51黑下载附件…………
实验45 手写识别实验.rar (1.82 MB, 下载次数: 14)
