查看: 15483|回复: 16
全球首发,全世界第一个Proteus仿真Arduino控制OLED显示张学友表情包
ID:230913 发表于 2018-8-12 14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
注:I2C地址为 0x3D
Arduino仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
Arduino程序源码:
  1. #include <SPI.h>
  2. #include <Wire.h>
  3. #include <Adafruit_GFX.h>
  4. #include <Adafruit_SSD1306.h>
  5. #define OLED_RESET 4
  6. Adafruit_SSD1306 display(OLED_RESET);
  7. static const unsigned char PROGMEM logo[] =
  8. {
  9. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x07,0xFF,
  10. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0xFF,0xFF,0x00,0xFF,0xFF,
  11. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0xFF,0xE0,0xFF,0x83,0xFF,0xFF,0xFF,0xFF,0xFF,
  12. 0xFF,0xC0,0x00,0x3C,0x0F,0xFF,0xFC,0x7F,0xF0,0x3F,0xFF,0xFF,0xFF,0x80,0x00,0x01,
  13. 0xFF,0xFF,0xFF,0x8F,0xC0,0x07,0xFF,0xFF,0xFF,0x80,0x00,0x0F,0xFF,0xFF,0xFF,0xE3,
  14. 0x00,0x03,0xFF,0xFF,0xFF,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xF8,0x00,0x01,0xFF,0xFF,
  15. 0xFF,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x7F,
  16. 0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,
  17. 0x80,0x00,0x7F,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,0xFF,
  18. 0xFF,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,0xFF,0xFF,0x00,0x03,0xFF,
  19. 0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x7F,0xFF,0xFF,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,
  20. 0xF0,0x00,0x3F,0xFF,0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x3F,0xFF,
  21. 0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0x83,0xFF,0xF8,0x00,0x3F,0xFF,0xFF,0x00,0x1F,0xFF,
  22. 0xFF,0xFF,0x80,0xFF,0xF8,0x00,0x3F,0xFF,0xFF,0x80,0x1F,0xFF,0x80,0xFF,0xC0,0x3F,
  23. 0xFC,0x00,0x7F,0xFF,0xFF,0xC0,0x3F,0xFC,0x00,0x7F,0xFF,0x3F,0xFC,0x00,0x7F,0xFF,
  24. 0xFF,0xC0,0x7F,0xF0,0x00,0x3F,0xFF,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xE0,0x7F,0xF0,
  25. 0xFC,0x1F,0xFF,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xF0,0x7F,0xFF,0xFF,0x7F,0xFF,0xFF,
  26. 0xFF,0x01,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,0xFF,0xFF,
  27. 0xFF,0xFE,0xFF,0xFF,0xC1,0xFF,0xC0,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,
  28. 0x01,0xFF,0xF0,0xFF,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x03,0xFF,0xF3,0xFF,
  29. 0xFF,0xBF,0xFF,0xFF,0xFF,0xFD,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,0xFF,
  30. 0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xFB,0xFF,0xFF,
  31. 0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  32. 0xFF,0xDF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,
  33. 0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,
  34. 0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xE7,0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,
  35. 0xFF,0xCF,0xFF,0xFF,0xFF,0xEF,0xFF,0xFF,0xF8,0xFF,0xFE,0xFF,0xFF,0xEF,0xFF,0xFF,
  36. 0xFF,0xEF,0xFF,0xFF,0xF9,0xB0,0xE7,0x7F,0xFF,0xEF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,
  37. 0xFF,0x00,0x0F,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFF,0xC0,0x3F,0xFF,
  38. 0xFF,0xE7,0xFF,0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xE7,0xFF,0xFF,
  39. 0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE3,0xFF,0xFF,0xFC,0x1F,0xFF,0xFF,
  40. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFF,0xF8,0x1F,0xFF,0xFF,0xFF,0xF0,0x03,0xFF,
  41. 0xFF,0xE1,0xFF,0xFF,0xF8,0x0F,0xFF,0xFF,0xFF,0x80,0x01,0xFF,0xFF,0xE0,0xFF,0xFF,
  42. 0xF8,0x0F,0xFF,0xFF,0xFF,0x07,0xF1,0xFF,0xFF,0xE0,0xFF,0xFF,0xF8,0x07,0xFF,0xFF,
  43. 0xFF,0x01,0x01,0xFF,0xFF,0xE0,0x7F,0xFF,0xF8,0x07,0xFF,0xFF,0xFF,0x00,0x23,0xFF,
  44. 0xFF,0xC0,0x7F,0xFF,0xF8,0x07,0xFF,0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xC0,0x3F,0xFF,
  45. 0xF8,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x1F,0xFF,0xF8,0x01,0xFF,0xFF,
  46. 0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x1F,0xFF,0xF8,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  47. 0xFF,0x80,0x1F,0xFF,0xF8,0x00,0xFF,0xFF,0xFF,0xC3,0xFF,0xFF,0xFF,0x00,0x0F,0xFF,
  48. 0xF8,0x00,0x3F,0xFF,0xFF,0xE0,0x0F,0xFF,0xFE,0x00,0x0F,0xFF,0xF8,0x00,0x1F,0xFF,
  49. 0xFF,0xF8,0x0F,0xFF,0xFC,0x00,0x0F,0xFF,0xF8,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,
  50. 0xF8,0x00,0x0F,0xFF,0xF8,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x0F,0xFF,
  51. 0xF8,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x0F,0xFF,0xF8,0x00,0x00,0xFF,
  52. 0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xF8,
  53. 0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xC0,0x00,0x00,0x0F,0xFF,
  54. 0xF8,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x00,
  55. 0x0F,0xF8,0x00,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  56. 0x00,0x00,0x0F,0xFF
  57. };
  58.
  59. #if (SSD1306_LCDHEIGHT != 64)
  60. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  61. #endif
  62. void setup()   {
  63.   Serial.begin(9600);
  64.   display.begin(SSD1306_SWITCHCAPVCC, 0x3D);
  65.   display.clearDisplay();
  66. }
  67. void loop() {
  68.   display.drawBitmap(19, 0, logo, 89, 63, 1);  //在坐标X0,Y0的位置开始显示图片
  69.                                                //128是取模软件显示的宽度
  70.                                                //64是取模软件显示的高度
  71.   display.display();                           //把缓存的都显示
  72.   delay(1);
  73.
  74.   display.clearDisplay();     //清除屏幕
  75. }
全部资料51hei下载地址:
lcd.zip (37.9 KB, 下载次数: 238)
收藏收藏4 分享淘帖 顶4 踩
ID:369368 发表于 2019-3-11 16:41 | 只看该作者
没有库,打不开
ID:188720 发表于 2019-3-13 11:32 | 只看该作者
支持。
ID:513131 发表于 2019-4-19 19:31 | 只看该作者
厉害,
ID:513131 发表于 2019-4-20 21:03 | 只看该作者
压缩包里没有PROTEUS仿真例程呀,
ID:524619 发表于 2019-4-29 18:36 | 只看该作者
原来这是张学友啊
ID:521352 发表于 2019-4-29 22:32 | 只看该作者
厉害了!,我想问一下在Proteus中你选Arduino开发板是在哪里选的?
ID:473159 发表于 2019-5-15 01:46 | 只看该作者
还真别说,眼睛,鼻子,嘴巴还有那么个样子,最好将图像修修就更像了
ID:602550 发表于 2019-8-22 19:01 | 只看该作者
驱动芯片规格书SSD1306
驱动芯片规格书SSD1306.pdf
1.34 MB, 下载次数: 21, 下载积分: 黑币 -5
驱动芯片规格书SSD1306
ID:639525 发表于 2019-11-22 16:52 | 只看该作者
请问这个地址0x3d怎么确定的,和0x78的区别在哪里?
ID:639525 发表于 2019-11-22 16:58 | 只看该作者
请问I2C地址为 0x3D怎么确定的?看到有的是设置为0x78
ID:601052 发表于 2019-12-30 09:46 | 只看该作者
下载试试看 ,正需要这个
ID:444561 发表于 2020-1-8 14:23 | 只看该作者
为什么我用STM32 PROTEUS总是不能点亮OLED
ID:456386 发表于 2020-2-23 14:09 | 只看该作者
下载学习一下
ID:446681 发表于 2020-4-21 13:28 | 只看该作者
楼主proteus的版本是多少?工程文件用8.1的打不开
ID:800738 发表于 2020-7-9 23:00 | 只看该作者
请问,用到的头文件应该放到哪里
ID:852547 发表于 2020-12-1 17:16 | 只看该作者
我想问一下oxFF这种是什么东西?
