查看: 3829|回复: 0
STM32F103的基于定时器的PWM波产生
ID:306943 发表于 2018-8-16 11:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本例用的是定时器2,产生脉冲为1KHz
void time2_pwm(int period,int Prescaler)
  GPIO_InitTypeDef        GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef       TIM_OCInitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); /*????2??*/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); /*GPIO????*/
                     /*??GPIO*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                /*????*/
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*??TIMER2*/
                    /*??TIMER2*/
  TIM_DeInit(TIM2);                                               /*??????2*/
  TIM_TimeBaseStructure.TIM_Period = period;                      /*??? ??????3600-1 ???0??*/
  TIM_TimeBaseStructure.TIM_Prescaler = Prescaler;                /*????*/
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        /*????*/
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;     /*????*/
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /*??TIMER2PWM??*/
                      /*??TIMER2PWM??*/
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;               /*PWM2????*/
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;   /*??????*/
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;        /*????? ?????*/
  /*??1*/
//  TIM_OCInitStructure.TIM_Pulse =40*36;
//  TIM_OC1Init(TIM2, &TIM_OCInitStructure);
//  TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
  /*??2*/
  TIM_OCInitStructure.TIM_Pulse =0;           /*?????*/
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);         /*?????TIMx ??*/
  TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);/*CH1?????*/
  /*??3*/
//  TIM_OCInitStructure.TIM_Pulse =90*36;
//  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
//  TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
  /*??4*/
//  TIM_OCInitStructure.TIM_Pulse =0*36;
//  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
//  TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE);   /*??TIMx?ARR????????*/
  TIM_Cmd(TIM2, ENABLE);                /*?????2*/
产生频率为72MHz/m   占空比为oxy%,可以视情况自行修改
time2_pwm(m-1,0);
TIM_SetCompare2(TIM2,oxy*m);
