查看: 2478|回复: 0
音乐猪八戒背媳妇
ID:292103 发表于 2018-8-17 16:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
sbit fm=P2^7;
uchar timeh,timel;//用于存放定时器的高8
uchar code zbjbxf[]=
   { //定义猪八戒背媳妇的简谱数组
   0x64,0xA3,0xC1,0xA2,0x62,0x84,0x61,0x81,0x61,0xA4,
   0xA1,0x91,0xA1,0x81,0x64,0xA3,0xC1,0xD2,0xD2,0xD2,
   0xA2,0xC4,0xA1,0xC1,0xA1,0xC1,0xD2,0xD2,0xD2,0xA2,
   0xC4,0xC2,0x62,0xC2,0x62,0xA2,0xA2,0x84,0x94,0x94,
   0x92,0x81,0x91, 0xA2,0xC2,0xD4,0xE4,0xA4,0xE4,0xA2,
   0xE2,0xA2,0xE2,0xA2, 0xA2,0x84,0x94,0x94,0x92,0x81,
   0x91,0xA2,0xC2,0xD8
   }; //适合12M 的晶振定时器初值表,高低 位分开
uchar code chuzhi[]=
   0xff,0xff,0xFC,0x8E,0xFC, 0xED,0xFD,0x43,0xFD,0x6A,
   0xFD,0xB3,0xFD,0xF3,0xFE,0x2D,0xFE, 0x47,0xFE,0x76,
   0xFE,0xA1,0xFE,0xC7,0xFE,0xD9,0xFE,0xF9,0xFF,0x16
void timer0() interrupt 1 //定时器0中断服务程序
TH0=timeh;//将timeh 赋给计时器的高8
TL0=timel;//将timel 赋给计时器的低8
fm=~fm;
}//定时器每次到时将蜂鸣器反相
void delay(uint z)
{        uint y;
    for(z;z>0;z--)
        for(y=19000;y>0;y--);
void delay1(uint z)
{        uint y;
    for(z;z>0;z--)
        for(y=112;y>0;y--);
music.rar
960 Bytes, 下载次数: 7, 下载积分: 黑币 -5
