查看: 13709|回复: 1
电源芯片CS5171引脚图电路图与资料手册下载
ID:388332 发表于 2018-8-20 22:36 | 显示全部楼层 |阅读模式
cs5171其实需要一些处理。
CS5171引脚图:
CS5171电路图:
CS5171框图:
The CS5171/2/3/4 products are 280 kHz/560 kHz switching
regulators with a high efficiency, 1.5 A integrated switch. These parts
operate over a wide input voltage range, from 2.7 V to 30 V. The
flexibility of the design allows the chips to operate in most power
supply configurations, including boost, flyback, forward, inverting,
and SEPIC. The ICs utilize current mode architecture, which allows
excellent load and line regulation, as well as a practical means for
limiting current. Combining high frequency operation with a highly
integrated regulator circuit results in an extremely compact power
supply solution. The circuit design includes provisions for features
such as frequency synchronization, shutdown, and feedback controls
for either positive or negative voltage regulation. These parts are
pin−to−pin compatible with LT1372/1373.
完整的pdf格式文档51黑下载地址:
cs5171.pdf (187.43 KB, 下载次数: 85)
ID:405613 发表于 2022-3-15 15:46 | 显示全部楼层
有没有中文的资料?英文的看不大懂
