查看: 4211|回复: 1
ILITEK ILI9806E规格书
ID:389054 发表于 2018-8-22 21:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Introduction
The ILI9806E is a 16.7M single-chip SOC driver for a-Si TFT liquid crystal display panels with a resolution up to
480(RGB)x864. The ILI9806E is comprised of a 1441-channel source driver, an gate-IC-less level shifter, and a
power supply circuit.
The ILI9806E supports 3-line serial peripheral interface to input commands. The ILI9806E supports a RGB
(16-/18-/24-bit) data bus for video image display. For high-speed serial interface, the MIPI DSI interface mode,
the ILI9806E supports two data lanes and one clock lane for high-speed and low power transmission in both
directions with low EMI noise.
The ILI9806E operates a wide range of an analog power supplies. The ILI9806E supports sleep mode and deep
standby power management functions, making the ILI9806E an ideal LCD driver for medium or small sized
portable products such as digital cellular phones, smart phones, MP3 players, personal media players and
similar devices with color graphics display where conserving battery power is desired. Additionally, it has an
internal DC/DC converter that generates the LCD driving voltage and the voltage follower circuit for LCD driver.
ILI9806E Specification for all customers(V.092)_20130813.pdf
5.74 MB, 下载次数: 42, 下载积分: 黑币 -5
ID:138677 发表于 2023-7-4 09:40 | 只看该作者
谢谢楼主的文档
