查看: 5825|回复: 2
谁有8*点阵显示0-9的16进制代码 帮忙改一下
ID:34099 发表于 2012-2-8 23:16 | 显示全部楼层 |阅读模式
#include unsigned char code tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; unsigned char code digittab[10][8]={ {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0 {0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1 {0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2 {0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3 {0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4 {0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5 {0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6 {0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7 {0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8 {0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00} //9 }; unsigned int timecount; unsigned char cnta; unsigned char cntb; void main(void) { TMOD=0x01; TH0=(65536-3000)/256; TL0=(65536-3000)%256; TR0=1; ET0=1; EA=1; while(1) {; } } void t0(void) interrupt 1 using 0 { TH0=(65536-3000)/256; TL0=(65536-3000)%256; P3=tab[cnta]; P1=digittab[cntb][cnta]; cnta++; if(cnta==8) { cnta=0; } timecount++; if(timecount==333) { timecount=0; cntb++; if(cntb==10) { cntb=0; } } } [upload=c,点阵数字.c]viewFile.asp?ID=957[/upload]
ID:33621 发表于 2012-2-8 23:55 | 显示全部楼层
自己查一下不就好了
ID:34099 发表于 2012-2-9 09:40 | 显示全部楼层
这个是我查的  但是显示的数字不像
