查看: 4238|回复: 1
STM32的ADC多通道采样,使用DMA传出数据,并且通过串口打印ADC各个通道的采样值
ID:389034 发表于 2018-8-25 12:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "adc.h"
  6. #include "dma.h"
  7. #define M 9 //为9个通道
  8. extern vu16 After_Adc[M]; //用来存放求平均值之后的结果
  9. u16 value[M];
  10. int main(void)
  11. {
  12.          int i;
  13.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  14.         Delay_conf(72);                     //延时函数初始化
  15.         Adc_Init();                                  //ADC初始化
  16.         uart_init(9600);         //串口初始化为9600
  17.         LED_Init();                                  //初始化与LED连接的硬件接口
  18.         DMA_Configuration();
  19.         printf("\r\n你好\r\n");
  20.         while(1)
  21.         {
  22.      ADC_smooth();
  23.      for(i=0;i<M;i++)
  24.      {
  25.                     value[i]= Getvolt(After_Adc[i]);
  26.         printf("value[%d]:\t%d.%dv\n",i,value[i]/100,value[i]%100) ;
  27.         delay_ms(100);
  28.                  }
  29.          }
  30. }
  1. #include "adc.h"
  3. extern const int  M; //为10个通道
  4. void  Adc_Init(void)
  5. {
  6.         ADC_InitTypeDef ADC_InitStructure;
  7.         GPIO_InitTypeDef GPIO_InitStructure;
  8.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB| RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1        , ENABLE );          //使能ADC1通道时钟
  9.         RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M
  10.
  11.         //PA0/1/2 作为模拟通道输入引脚
  12.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
  13.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  14.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  15.         //PB0/1 作为模拟通道输入引脚
  16.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  18.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  19.         //PC0/1/2/3/4/5 作为模拟通道输入引脚
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  22.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  23.         ADC_DeInit(ADC1);  //复位ADC1,将外设 ADC1 的全部寄存器重设为缺省值
  24.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式
  25.         ADC_InitStructure.ADC_ScanConvMode =ENABLE; //模数转换工作在扫描模式
  26.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //模数转换工作在连续转换模式
  27.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //外部触发转换关闭
  28.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐
  29.         ADC_InitStructure.ADC_NbrOfChannel = M; //顺序进行规则转换的ADC通道的数目
  30.         ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
  31.         ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_239Cycles5 );
  32.         ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_239Cycles5 );
  33.         ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_239Cycles5 );
  34.         ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_239Cycles5 );
  35.         ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 5, ADC_SampleTime_239Cycles5 );
  36.         ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 6, ADC_SampleTime_239Cycles5 );
  37.         ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 7, ADC_SampleTime_239Cycles5 );
  38.         ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 8, ADC_SampleTime_239Cycles5 );
  39.         ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 9, ADC_SampleTime_239Cycles5 );
  40. //        ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 10, ADC_SampleTime_239Cycles5 );
  41. //        ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
  42. //        ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
  43.
  44.
  45.   // 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
  46.    ADC_DMACmd(ADC1, ENABLE);
  47.
  48.
  49.         ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
  50.
  51.         ADC_ResetCalibration(ADC1);        //使能复位校准
  52.
  53.         while(ADC_GetResetCalibrationStatus(ADC1));        //等待复位校准结束
  54.
  55.         ADC_StartCalibration(ADC1);         //开启AD校准
  56.         while(ADC_GetCalibrationStatus(ADC1));         //等待校准结束
  57.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的软件转换启动功能
  58. }
  59. //获得ADC值
  60. //ch:通道值 0~3
  61. u16 Get_Adc(u8 ch)
  62. {
  63.           //设置指定ADC的规则组通道,一个序列,采样时间
  64.         ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );        //ADC1,ADC通道,采样时间为239.5周期
  65.
  66.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的软件转换启动功能
  67.
  68.         while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待转换结束
  69.         return ADC_GetConversionValue(ADC1);        //返回最近一次ADC1规则组的转换结果
  70. }
  71. u16 Get_Adc_Average(u8 ch,u8 times)
  72. {
  73.         u32 temp_val=0;
  74.         u8 t;
  75.         for(t=0;t<times;t++)
  76.         {
  77.                 temp_val+=Get_Adc(ch);
  78.                 delay_ms(5);
  79.         }
  80.         return temp_val/times;
  81. }
ADC扫描模式连续转换之DMA传输.rar (296.41 KB, 下载次数: 77)
收藏收藏3 分享淘帖 顶 踩
ID:267330 发表于 2018-9-14 09:06 | 只看该作者
想学习,但是没有黑逼
