查看: 2516|回复: 3
lpc1778驱动TG12232E-01液晶显示
ID:390945 发表于 2018-8-28 20:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <LPC177x_8x.h>
#include "lcm.h"
extern void write_data(uchar date);
extern void delay(uint32_t tick);
#define  LCM_EN_LOW()                      LPC_GPIO1->CLR |= (1UL<<19);          //EN
#define  LCM_EN_HIGH()                LPC_GPIO1->SET |= (1UL<<19);
#define  LCM_RW_LOW()                      LPC_GPIO1->CLR |= (1UL<<20);          //RW
#define  LCM_RW_HIGH()                LPC_GPIO1->SET |= (1UL<<20);
#define  LCM_RS_LOW()                      LPC_GPIO1->CLR |= (1UL<<21);          //RS
#define  LCM_RS_HIGH()                LPC_GPIO1->SET |= (1UL<<21);
#define LCD_NUM  8
typedef struct
    uint32_t gpioBaseAddr;   // 对应GPIO的基地址
    uint32_t pin;            // 对应的PIN脚掩码
}T_LCD;     // lcd data引脚的描述信息
// 定义data数据位
const T_LCD g_lcd[LCD_NUM]= {
    {LPC_GPIO1_BASE, 1UL << 22},            //DATA:D0-D7
    {LPC_GPIO1_BASE, 1UL << 23},
    {LPC_GPIO1_BASE, 1UL << 24},
    {LPC_GPIO1_BASE, 1UL << 25},
    {LPC_GPIO1_BASE, 1UL << 26},
    {LPC_GPIO1_BASE, 1UL << 27},
    {LPC_GPIO1_BASE, 1UL << 28},
    {LPC_GPIO1_BASE, 1UL << 29},
void lcd1602_init(void)
        delay(5000);
        write_command(0x30);         // 功能设定
        delay(100);
        write_command(0x04);    // 显示关闭
        delay(100);
        write_command(0x01);    // 清屏
        delay(100);
        write_command(0x0c);        // 显示开及光标设置
  delay(100);
        write_command(0x80);        // 显示光标移动设置
        delay(100);
        //write_command(0x04);    //开总显示,不开开光标,光标不闪烁
  //delay(1);
// 对lED使用的GPIO管脚进行初始化
void lcdInit(void)
    LPC_GPIO_TypeDef *pGPIO;
    uint32_t i;
    for (i = 0; i < LCD_NUM; i++)               //D0-D7 配置输出模式
        pGPIO = (LPC_GPIO_TypeDef *)g_lcd[i].gpioBaseAddr;
        pGPIO->DIR |= g_lcd[i].pin;
    LPC_IOCON->P1_19 &= 0xFFFFFFF8;                            //    EN
    LPC_IOCON->P1_19 |= 0x00000000;                                //
    LPC_GPIO1->DIR |= (1UL<<19);                //输出模式
    LPC_IOCON->P1_20 &= 0xFFFFFFF8;                            //    R/W
    LPC_IOCON->P1_20 |= 0x00000000;                                //
    LPC_GPIO1->DIR |= (1UL<<20);                //输出模式
    LPC_IOCON->P1_21 &= 0xFFFFFFF8;                            //    RS
    LPC_IOCON->P1_21 |= 0x00000000;                                //
    LPC_GPIO1->DIR |= (1UL<<21);                //输出模式
    lcd1602_init();
* @brief                Delay function
* @param[in]        tick - number milisecond of delay time
* @return                 None
     uint32_t i;
     uint32_t j;
     for (i=tick; i>0; i--)
        for (j=0; j<1000; j++);
void write_command(uchar command)               //写命令
    uchar i;
    i = command;
    LCM_RW_LOW();
    LCM_RS_LOW();
    LCM_EN_LOW();
    delay(5);
    LPC_GPIO1->CLR |= (0XFF << 22);             //数据八位清零
    LPC_GPIO1->SET |= (i << 22);                //数据位赋值
    delay(5);
    LCM_EN_HIGH();
    delay(5);
    LCM_EN_LOW();
void write_data(uchar date)                     //写单个字符
    uchar i;
    i = date;
    LCM_RW_LOW();
    LCM_RS_HIGH();
    LCM_EN_LOW();
    delay(5);
    delay(5);
    LCM_EN_HIGH();
    delay(5);
    LCM_EN_LOW();
void dr_screen_print(int x1,int x2,unsigned char *s1,unsigned char *s2)  //,int light
                int j;
                if ((x1 < 8) && (x2 < 8))
                                                j=0;
                                                write_command(0x80 +j* 16+ x1);//????DDRAM??row * 16 + col??
                                                while(*s1)
        write_data(*s1);
        s1++;
        ++j;
                                                write_command(0x80 +j*16+ x2);//????DDRAM??row * 16 + col??
                                                while(*s2)
        write_data(*s2);
        s2++;
unsigned char set_lcd_position(unsigned char row, unsigned char col)
  if ((row < 2) && (col < 8))    //?????2?7.5?(????????)
    write_command(0x80 + row * 16 + col);//????DDRAM??row * 16 + col??
    return 1;//????
    return 0;//????
void display_string(uchar *p)                   //写字符串
        while(*p)
                write_data(*p);
                p++;
/*void lcd_display(uchar row, uchar col, uchar *p)
  if (set_lcd_position(row, col))
    display_string(p);
/*void gotoxy(unsigned y,unsigned x)              //显示位置  2行16列     Y:1-2;  X:0-15
        if(y ==0)                                  //第一行
                write_command(0x80+x);
        else if(y ==1)                             //第二行
            write_command(0x80+0x0F+x);
ID:1 发表于 2018-8-28 20:39 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
ID:1 发表于 2018-8-29 01:07 | 只看该作者
缺头文件?
ID:138664 发表于 2019-1-24 13:04 | 只看该作者
缺函数文件
