查看: 2008|回复: 1
超声测距1602显示
ID:392097 发表于 2018-8-31 19:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <AT89x51.H>                //器件配置文件
#include <intrins.h>
#define  RX  P2_7
#define  TX  P2_6
#define LCM_RW  P3_4 //定义LCD引脚
#define LCM_RS  P3_3
#define LCM_E   P3_5
#define LCM_Data  P1
#define Key_Data P2_0 //定义Keyboard引脚
#define Key_CLK  P3_2
#define Busy    0x80 //用于检测LCM状态字中的Busy标识
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code mcustudio[] ={"mcustudio.com.cn"};
unsigned char code email[] =    {"fhwxaoo@163.com "};
unsigned char code Cls[] =      {"                "};
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //显示用指针
       unsigned int  time=0;
           unsigned long S=0;
           bit      flag =0;
           unsigned char disbuff[4]           ={ 0,0,0,0,};
//写数据
        ReadStatusLCM(); //检测忙
        LCM_Data = WDLCM;
        LCM_RS = 1;
        LCM_RW = 0;
        LCM_E = 0; //若晶振速度太高可以在这后加小的延时
        LCM_E = 0; //延时
        LCM_E = 1;
//写指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
        if (BuysC) ReadStatusLCM(); //根据需要检测忙
        LCM_Data = WCLCM;
        LCM_RS = 0;
        LCM_RW = 0;
        LCM_E = 0;
        LCM_E = 0;
        LCM_E = 1;
//读数据
        LCM_RS = 1;
        LCM_RW = 1;
        LCM_E = 0;
        LCM_E = 0;
        LCM_E = 1;
        return(LCM_Data);
//读状态
        LCM_Data = 0xFF;
        LCM_RS = 0;
        LCM_RW = 1;
        LCM_E = 0;
        LCM_E = 0;
        LCM_E = 1;
        while (LCM_Data & Busy); //检测忙信号
        return(LCM_Data);
void LCMInit(void) //LCM初始化
        LCM_Data = 0;
        WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
        Delay5Ms();
        Delay5Ms();
        Delay5Ms();
        WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
        WriteCommandLCM(0x08,1); //关闭显示
        WriteCommandLCM(0x01,1); //显示清屏
        WriteCommandLCM(0x06,1); // 显示光标移动设置
        WriteCommandLCM(0x0F,1); // 显示开及光标设置
//按指定位置显示一个字符
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
        X |= 0x80; //算出指令码
        WriteCommandLCM(X, 1); //发命令字
        WriteDataLCM(DData); //发数据
//按指定位置显示一串字符
        unsigned char ListLength;
  ListLength = 0;
        Y &= 0x1;
        while (DData[ListLength]>0x19) //若到达字串尾则退出
                        if (X <= 0xF) //X坐标应小于0xF
                                        DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
                                        ListLength++;
                                        X++;
//5ms延时
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//400ms延时
        unsigned char TempCycA = 5;
        unsigned int TempCycB;
        while(TempCycA--)
                        TempCycB=7269;
                        while(TempCycB--);
    void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;     //算出来是CM
         if((S>=700)||flag==1) //超出测量范围显示“-”
          flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
          DisplayOneChar(1, 1, ASCII[10]);        //显示点
          DisplayOneChar(2, 1, ASCII[11]);
          DisplayOneChar(3, 1, ASCII[11]);
          DisplayOneChar(4, 1, ASCII[12]);        //显示M
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%10 %10;
          DisplayOneChar(0, 1, ASCII[disbuff[0]]);
          DisplayOneChar(2, 1, ASCII[disbuff[1]]);
          DisplayOneChar(3, 1, ASCII[disbuff[2]]);
     void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
    flag=1;                                                         //中断溢出标志
     void  StartModule()                          //启动模块
          TX=1;                                             //启动一次模块
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TX=0;
void delayms(unsigned int ms)
        unsigned char i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
void main(void)
        unsigned char TempCyc;
        Delay400Ms(); //启动等待,等LCM讲入工作状态
        LCMInit(); //LCM初始化
        Delay5Ms(); //延时片刻(可不要)
        DisplayListChar(0, 0, mcustudio);
        DisplayListChar(0, 1, email);
        ReadDataLCM();//测试用句无意义
        for (TempCyc=0; TempCyc<10; TempCyc++)
        Delay400Ms(); //延时
        DisplayListChar(0, 1, Cls);
         TMOD=0x01;                   //设T0为方式1,GATE=1;
         TH0=0;
         TL0=0;
         ET0=1;             //允许T0中断
         EA=1;                           //开启总中断
             StartModule();
                // DisplayOneChar(0, 1, ASCII[0]);
             while(!RX);                //当RX为零时等待
             TR0=1;                            //开启计数
             while(RX);                        //当RX为1计数并等待
             TR0=0;                                //关闭计数
         Conut();                        //计算
                 delayms(80);                //80MS
ID:1 发表于 2018-9-1 04:06 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
