查看: 2657|回复: 1
矩阵按键c语言中断延时扫描按键
ID:393433 发表于 2018-9-4 12:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
unsigned char i,j;        unsigned char backup[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
TMOD=0x01;
TH0=0xFC;
TL0=0x65;
TR0=1;
EA=1;
ET0=1;
                for(i=0;i<4;i++)
                        for(j=0;j<4;j++)
                                if(keysta[i][j]!=backup[i][j])
                                        if(backup[i][j]==0)
                                        outbyte(no[0],duan[i*4+j]);
                              backup[i][j]=keysta[i][j];
void InterruptTimer0() interrupt 1
        unsigned char i;
  static unsigned char keybuf[4][4]={
  {0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},
        {0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF}};
  static unsigned char keyout=0;
        TH0=0xFC;
        TL0=0x65;
        keybuf[keyout][0]=(keybuf[keyout][0]<<1)|KEYIN1;
        keybuf[keyout][1]=(keybuf[keyout][1]<<1)|KEYIN2;
        keybuf[keyout][2]=(keybuf[keyout][2]<<1)|KEYIN3;
        keybuf[keyout][3]=(keybuf[keyout][3]<<1)|KEYIN4;
        for(i=0;i<4;i++)
                if((keybuf[keyout][i]&0x0F)==0x00)
                  keysta[keyout][i]=0;
          else if((keybuf[keyout][i]&0x0F)==0x0F)
                   keysta[keyout][i]=1;
        keyout++;
        keyout=keyout&0x03;
        switch(keyout)
                case 0:KEYOUT4=1;KEYIN1=0;break;
                case 1:KEYOUT1=1;KEYIN2=0;break;
                case 2:KEYOUT2=1;KEYIN3=0;break;
                case 3:KEYOUT3=1;KEYIN4=0;break;
                default :break;
ID:1 发表于 2018-9-4 21:55 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
