查看: 1562|回复: 2
51单片机的两位汉显程序
ID:393479 发表于 2018-9-4 13:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include<stdio.h>
#include <intrins.h>
sbit DS = P0^1;      // 串行数据输入
sbit ST_CP = P0^0;        //数据锁存时钟
sbit SH_CP = P0^2;        //数据输入时钟
sbit A = P2^0;
sbit B1 = P2^1;
sbit C = P2^2;
sbit D = P2^3;
sbit EN = P2^4;
uchar a=0;                                //用于串口中断中的速度和运行方式命令
uchar d=0;                                                 //用于串口中断中的字数的命令
uchar zimo=0;
uchar zishu=0;
uchar speed=20;
uchar movestyle=1;
uint DisplayMode=0;
uchar s=0;
uint count = 0;
uchar ctrl = 0x00;                                           //用于行选
uchar z;                                        //左右移函数
uchar m;
uchar buf[192];
uchar speed;                                        //控制速度函数
uchar e;                     //控制速度函数
uchar code tabstart[192]=
0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFC,0x07,0xFD,0xFF,
0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0x00,0x01,0xFF,0xFF,/*"上",0*/
/* (16 X 16 , 宋体 )*/
0xFF,0xFF,0x00,0x01,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xBF,0xFD,0xDF,
0xFD,0xEF,0xFD,0xF7,0xFD,0xF7,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,/*"下",1*/
void Control(void)
        if(ctrl == 0x11||ctrl ==0xEE)        //停止
                DisplayMode = 4;
        if(ctrl == 0x22||ctrl ==0xDD)        //开始
                speed = 20;
        if(ctrl == 0x33||ctrl ==0xCC)        //加速
                if((speed == 60000) || (speed > 20))
                        speed =20;
                speed -= 5;
                if(speed <= 0)
                        speed = 1;
        if(ctrl == 0x44||ctrl ==0xBB)        //减速
                if((speed == 60000) || (speed < 10))
                        speed = 20;
                speed += 10;
        if(ctrl == 0x55||ctrl ==0xAA)        //左移
                DisplayMode = 0;
        if(ctrl == 0x56||ctrl ==0xA9)        //右移
                DisplayMode = 1;
        if(ctrl == 0x57||ctrl ==0xA8)        //上移
                DisplayMode = 2;
        if(ctrl == 0x58||ctrl ==0xA7)        //下移
                DisplayMode = 3;
void send(uchar dat)
uint i;
for(i=0;i<8;i++)
   SH_CP=0;
   if(dat&0x01)
   DS=0;
   DS=1;
   dat=dat>>1;
   SH_CP = 0;
   SH_CP = 1;
void display()
uint h;
for(h=0;h<16;h++)
send(buf[32+2*h+1]);
send(buf[32+2*h]);
send(buf[2*h+1]);
send(buf[2*h]);
P2 = s;
  s++;
  ST_CP = 0;
ST_CP = 1;
if(s==16)
s = 0;
void delay()//控制速度
for(e=2*speed;e>0;e--)
  display();
void left()
         {                  for(z=0;z<16;z++)
           uchar temp1 = 0,temp2 = 0,temp3 = 0,temp4 = 0,temp5 = 0,temp6 = 0,temp7 = 0,temp8 = 0,temp9 = 0,temp10 = 0,temp11 = 0,temp12 = 0;
           temp12=_crol_(buf[160+2*z+1]&0x80,1);
           temp11=_crol_(buf[160+2*z]&0x80,1) ;
           temp10=_crol_(buf[128+2*z+1]&0x80,1);
           temp9=_crol_(buf[128+2*z]&0x80,1) ;
           temp8=_crol_(buf[96+2*z+1]&0x80,1);
           temp7=_crol_(buf[96+2*z]&0x80,1) ;
           temp6=_crol_(buf[64+2*z+1]&0x80,1);
           temp5=_crol_(buf[64+2*z]&0x80,1);
           temp4=_crol_(buf[32+2*z+1]&0x80,1);
           temp3=_crol_(buf[32+2*z]&0x80,1);
           temp2=_crol_(buf[2*z+1]&0x80,1);
           temp1=_crol_(buf[2*z]&0x80,1);          //取出高位并移入最低位
           buf[2*z]=buf[2*z]<<1|temp2;
           buf[2*z+1]=buf[2*z+1]<<1|temp3;
           buf[32+2*z]=buf[32+2*z]<<1|temp4;
           buf[32+2*z+1]=buf[32+2*z+1]<<1|temp5;
           buf[64+2*z]=buf[64+2*z]<<1|temp6;
           buf[64+2*z+1]=buf[64+2*z+1]<<1|temp7;
           buf[96+2*z]=buf[96+2*z]<<1|temp8;
           buf[96+2*z+1]=buf[96+2*z+1]<<1|temp9;
           buf[128+2*z]=buf[128+2*z]<<1|temp10;
           buf[128+2*z+1]=buf[128+2*z+1]<<1|temp11;
           buf[160+2*z]=buf[160+2*z]<<1|temp12;
           buf[160+2*z+1]=buf[160+2*z+1]<<1|temp1;
        //移位并赋值
          delay();
  void right()
           for(z=0;z<16;z++)
           temp12=_cror_(buf[160+2*z+1]&0x01,1);
           temp11=_cror_(buf[160+2*z]&0x01,1);
           temp10=_cror_(buf[128+2*z+1]&0x01,1);
           temp9=_cror_(buf[128+2*z]&0x01,1);
           temp8=_cror_(buf[96+2*z+1]&0x01,1);
           temp7=_cror_(buf[96+2*z]&0x01,1);
           temp6=_cror_(buf[64+2*z+1]&0x01,1);
           temp5=_cror_(buf[64+2*z]&0x01,1);
           temp4=_cror_(buf[32+2*z+1]&0x01,1);
           temp3=_cror_(buf[32+2*z]&0x01,1);
           temp2=_cror_(buf[2*z+1]&0x01,1);
           temp1=_cror_(buf[2*z]&0x01,1);  //取出最低位,并移到最高位
           buf[2*z]=buf[2*z]>>1|temp12;
           buf[2*z+1]=buf[2*z+1]>>1|temp1;
           buf[32+2*z]=buf[32+2*z]>>1|temp2;
           buf[32+2*z+1]=buf[32+2*z+1]>>1|temp3;
           buf[64+2*z]=buf[64+2*z]>>1|temp4;
           buf[64+2*z+1]=buf[64+2*z+1]>>1|temp5;
           buf[96+2*z]=buf[96+2*z]>>1|temp6;
           buf[96+2*z+1]=buf[96+2*z+1]>>1|temp7;
           buf[128+2*z]=buf[128+2*z]>>1|temp8;
           buf[128+2*z+1]=buf[128+2*z+1]>>1|temp9;
           buf[160+2*z]=buf[160+2*z]>>1|temp10;
           buf[160+2*z+1]=buf[160+2*z+1]>>1|temp11;                //移位并赋值
          delay();
void up()
delay();
  s--;
void down()
delay();
  s++;
void sysinit(void)
uchar k;
for(k=0;k<192;k++)
  buf[k] = tabstart[k];
TMOD = 0x20;        //定时器T1使用工作方式2
        TH1 = 0xFd;           // 设置初值
        TL1 = 0xFd;
        TR1 = 1;            // 开始计时
        SCON = 0x50;        //工作方式1,波特率9600bps,允许接收
//   PCON |= 0x80;
        ES = 1;
        EA = 1;                    // 打开所有中断
        TI = 0;
        RI = 0;          //定时器1工作
{ sysinit();
switch(DisplayMode)
case 0:left();
       break;
case 1:right();
       break;
case 2:up();
       break;
case 3:down();
       break;
case 4:display();
       break;
void com_isr(void) interrupt 4                      //串口中断
        uchar tmp;
   if (RI==1)
                   RI=0;
                        if(count>=192)
                                 ctrl= SBUF;
//                                 SBUF=ctrl;
                                count = 0;
                                Control();
                                tmp = SBUF;
                                                //将寄存器复位等待接收下一个
                                buf[count] = tmp;                //将接收的数据存于变量中
                                count++;
ID:1 发表于 2018-9-4 16:27 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
ID:393479 发表于 2019-7-7 12:44 | 只看该作者
原理图已上传
点阵.pdf
104.28 KB, 下载次数: 2, 下载积分: 黑币 -5
原理图
