查看: 6036|回复: 4
emWin两个窗口间的切换程序
ID:382757 发表于 2018-9-14 12:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
emWin 两个窗口间的切换
  1. #include "DIALOG.h"
  2. #define ID_FRAMEWIN_0        (GUI_ID_USER + 0x00)
  3. #define ID_BUTTON_0                (GUI_ID_USER + 0x01)
  4. #define ID_BUTTON_1                (GUI_ID_USER + 0x02)
  5. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {        //控件结构体数组
  6.         { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 320, 240, FRAMEWIN_CF_MOVEABLE, 0x64, 0 },
  7.         { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 5, 180, 60, 25, 0, 0x0, 0 },
  8.         { BUTTON_CreateIndirect, "Button", ID_BUTTON_1, 75, 180, 60, 25, 0, 0x0, 0 },
  9. };
  10. extern WM_HWIN hPage[4];
  11. static void _cbDialog(WM_MESSAGE * pMsg)
  12. {
  13.         WM_HWIN hItem;
  14.         int                 NCode;
  15.         int                 Id;
  16.         switch (pMsg->MsgId)
  17. {
  18.         case WM_INIT_DIALOG:      //初始化消息,创建窗口/控件时有效,比如在这里设置一些
  19. 控件的初始参数
  20.                 hItem = pMsg->hWin;
  21.                 FRAMEWIN_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
  22.                 FRAMEWIN_SetText(hItem, "Page 0");
  23.                 FRAMEWIN_SetTitleHeight(hItem, 18);
  24.                 FRAMEWIN_SetFont(hItem, GUI_FONT_16B_1);
  25.                 FRAMEWIN_SetTextColor(hItem, (0x008000FF));
  26.                 FRAMEWIN_AddCloseButton(hItem, FRAMEWIN_BUTTON_RIGHT, 0);
  27.                 FRAMEWIN_AddMaxButton(hItem, FRAMEWIN_BUTTON_RIGHT, 0);
  28.                 FRAMEWIN_AddMinButton(hItem, FRAMEWIN_BUTTON_RIGHT, 0);
  29.                 FRAMEWIN_SetClientColor(pMsg->hWin, GUI_GREEN);
  30.                 hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0);
  31.                 BUTTON_SetText(hItem, "Return");
  32.                 hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_1);
  33.                 BUTTON_SetText(hItem, "Next");
  34.                 break;
  35.         case WM_PAINT:           //窗口重绘消息,这个比较难说明白,反正在Framewin或Window
  36. 窗体之中我们一般是用控
  37.                                           //件,如果要在Framewin或Window窗体之中显示文字或绘制直线、
  38. 矩形、圆等在这里实现
  39.                 GUI_SetColor(GUI_BLUE);        //设置前景颜色
  40.                 GUI_SetFont((GUI_FONT *)&GUI_Font16_ASCII);                            //设置当前字库
  41.                 GUI_SetTextMode(GUI_TEXTMODE_TRANS);                                //设置文字透明显示
  42.                 GUI_DispStringAt("neqee.com", 3, 3);                                        //重绘显示文字
  43.                 break;
  44.         case WM_NOTIFY_PARENT:          //操作触发消息处理(操作屏幕程序会跑到这里),
  45. 比如点击按键、点击编辑框(任何的操作)等等......
  46.                 Id                = WM_GetId(pMsg->hWinSrc);
  47.                 NCode = pMsg->Data.v;
  48.                 switch(Id) {
  49.                 case ID_BUTTON_0:                                                //ID为ID_BUTTON_0的按键被点击
  50.                         switch(NCode)
  51. {
  52.                         case WM_NOTIFICATION_CLICKED:                //按下动作消息
  53.                                 break;
  54.                         case WM_NOTIFICATION_RELEASED:                //弹起动作消息
  55.                                 break;
  56.                         }
  57.                         break;
  58.                 case ID_BUTTON_1:                                                //ID为ID_BUTTON_1的按键被点击
  59.                         switch(NCode)
  60.   {
  61.                         case WM_NOTIFICATION_CLICKED:                //按下动作消息
  62.                                 break;
  63.                         case WM_NOTIFICATION_RELEASED:                //弹起动作消息
  64.                                 WM_HideWindow(hPage[0]);                        //隐藏Page 0
  65.                                 WM_ShowWindow(hPage[1]);                //显示Page 1
  66.                                 break;
  67.                         }
  68.                         break;
  69.                 }
  70.                 break;
  71.         default:
  72.                 WM_DefaultProc(pMsg);
  73.                 break;
  74.         }
  75. }
  76. static void _cbBackGround(WM_MESSAGE* pMsg)     //桌面背景的回调函数
  77. {
  78. switch (pMsg->MsgId)
  79.         {
  80.         case WM_PAINT:               //窗口重绘消息,这个比较难说明白,反正在Framewin
  81. 或Window窗体之中我们一般是用控
  82.                                                     //件,如果要在Framewin或Window窗体之中显示文字
  83. 或绘制直线、矩形、圆等在这里实现
  84.                 GUI_SetBkColor(GUI_RED);        //设置背景颜色
  85.                 GUI_Clear();                                                        //清屏
  86.                 break;
  87.         default: WM_DefaultProc(pMsg); break;
  88.         }
  89. }
  90. WM_HWIN CreateFramewin0(WM_HWIN hParent);
  91. WM_HWIN CreateFramewin0(WM_HWIN hParent)
  92. {
  93.         WM_HWIN hWin;
  94.         WM_SetCallback(WM_HBKWIN, _cbBackGround);         //设置桌面背景的回调函数
  95.         hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, hParent, 0, 0);
  96.         return hWin;
  97. }
enWin两个窗口切换.docx
15.12 KB, 下载次数: 64, 下载积分: 黑币 -5
ID:1 发表于 2018-9-14 17:32 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
ID:108573 发表于 2020-2-9 11:15 | 只看该作者
这种比较耗内存,不过速度快。
ID:701889 发表于 2020-5-13 19:14 | 只看该作者
一个物理按键切换多个界面怎么做,哪位有做过?
ID:455905 发表于 2021-7-14 16:29 | 只看该作者
大佬搞出来了吗,我最近也在做这个功能
