查看: 4723|回复: 11
关于单片机数码管倒计时如何变成正计时的问题?
请问如何将天数的倒计时变成天数的正计时
  1. #include <REGX52.H>
  2. #include<intrins.h>  //包含_nop_();定义的头文件
  3. #include<LS595driver.h>
  4. #include<LS595_2driver.h>
  5. #include<ds1302driver.h>
  6. SYSTEMTIME today;                  //2018.1.2 12:00:00 2
  7. unsigned int T0loop;          //记录进入T0的次数
  8. unsigned int flag;        //约10秒1次,
  9. unsigned int countupday; //记录正计时天数的参数
  10. unsigned char olddaytemp,newdaytemp;  //用来比较是否已经过一天
  11. unsigned char keyvalue;//记录按键扫描函数的返回值
  12. //******************
  13. //unsigned int test[10]={0,111,222,333,444,555,666,777,888,999}; //记录倒计时天数的参数
  14. unsigned char i;
  15. //*******************
  16. sbit key1 = P1^0;
  17. sbit key2 = P1^1;
  18. sbit key3 = P1^2;
  19. sbit LEDr=P1^3;
  20. sbit LEDg=P1^4;
  21. sbit LEDy=P1^5;
  22. void Init_89C52();      //初始化89C52
  23. void InitT0();
  24. char Keyscan();         //按键扫描并返回键值
  25. void Setcountupday(); //按键设置正计时天数
  26. void main()
  27. {
  28.   Init_89C52();
  29.   Delay_ms(1000);
  30.   countupday = 865;
  31.   LEDr = 1;
  32.   LEDg = 1;
  33.   LEDy = 1;
  34. //*****************************
  35.   Init_1302();  //初始化时钟
  36.   InitT0();     //初始化T0定时器
  37.   Displayround();
  38.   while(1)
  39.   {
  40.    Displaysecond_595(&today);
  41.    Displayday_595(&today);
  42.    Displayhour_595(&today);
  43.    Displayminute_595(&today);
  44.    Setcountupday();
  45.    Displaycountupnum(countupday);
  46.    if(flag==1)
  47.    {
  48.      flag = 0;
  49.          if(olddaytemp=!newdaytemp)
  50.          {
  51.            countupday++;
  52.      }
  53.    }
  54.   }
  55. }
  56. //*************************************************************************
  57. //Time0中断函数
  58. //功能:定时出10秒/50毫秒=200个循环
  59. //参数:无
  60. //*************************************************************************
  61. void Time0(void) interrupt 1 using 1
  62. {
  63.   TR0 = 0;
  64.   T0loop++;
  65.   if(T0loop==200)
  66.   {
  67.     Gettime_1302(&today);
  68.         olddaytemp = today.day;
  69.   }
  70.   if(T0loop==400)
  71.   {
  72.         Gettime_1302(&today);
  73.         newdaytemp = today.day;
  74.         flag = 1;
  75.         T0loop = 0;
  76.   }
  77.   TH0 = (65536-46083)/256;                                  //重新给T0赋初始值
  78.   TL0 = (65536-46083)%256;                                  //
  79.   TR0 = 1;                                //启动T0
  80. }
  81. //*************************************************************************
  82. //Time0中断函数
  83. //功能:每8秒进入中断,执行开门或关门操作,并重设Time0
  84. //参数:无
  85. //*************************************************************************
  86. void InitT0()
  87. {
  88.   TMOD=0x01;    //使用定时器T0,11.0592MHz晶振的12分频,16位定时器65536-1
  89.   TH0 =(65536-46083)/256;  //将定时器计时时间设定为46083*1.085微秒=50000微秒=50毫秒
  90.   TL0 =(65536-46083)%256;  //
  91.   EA  = 1;       //开启总中断
  92.   ET0 = 1;       //T0中断允许
  93.   TR0 = 1;       //启动定时器T0
  94.   T0loop = 0;                          //记录进入T0的次数
  95.   flag = 0;         //10秒一个周期
  96. }
  97. /*89C52初始化*/
  98. void Init_89C52()
  99. {
  100.   P0 = 0;
  101.   P1 = 1;
  102.   P2 = 0;
  103.   T0loop = 0;
  104. }
  105. /*按键扫描函数*/
  106. char Keyscan()
  107. {
  108.   if(key1==0)
  109.   {
  110.     Delay_ms(200);
  111.         if(key1==0)
  112.         {
  113.           return 1;
  114.         }
  115.   }
  116.   if(key2==1)
  117.   {
  118.     Delay_ms(200);
  119.         if(key2==1)
  120.         {
  121.           return 2;
  122.         }
  123.   }
  124.   if(key3==1)
  125.   {
  126.     Delay_ms(200);
  127.         if(key3==1)
  128.         {
  129.           return 2;
  130.         }
  131.   }
  132.   else
  133.     return 0;
  134. }
  135. /*按键调整函数*/
  136. void Setcountupday()
  137. {
  138.   switch(Keyscan())
  139.   {
  140.     case 1:
  141.         countupday--;
  142.         Displaycountupnum(countupday);
  143.         break;
  144.         case 2:
  145.         countupday++;
  146.         Displaycountupnum(countupday);
  147.         break;
  148.         default:
  149.         Displaycountupnum(countupday);
  150.         break;
  151.   }
  152. }
ID:277550 发表于 2018-9-17 09:35 | 只看该作者
这个Displaycountupnum函数在哪呢
其实,是把要显示的变量,换成
这个变量
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:393625 发表于 2018-9-17 14:11 | 只看该作者
其实,是把要显示的变量,换成
请问能详细说一下怎么改吗,非常感谢
ID:397025 发表于 2018-9-17 14:36 | 只看该作者
你是想做成日期一样吗?
ID:267330 发表于 2018-9-17 14:51 | 只看该作者
请问能详细说一下怎么改吗,非常感谢
ID:80221 发表于 2018-9-17 17:56 | 只看该作者
Displaycountupnum(),这个函数贴出来
ID:164602 发表于 2018-9-18 08:16 | 只看该作者
正计时,根本不需要你这个倒计时程序嘛,只要正确读出1302的数据,就可以了,因为1302本身就是正计时啊。
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:393625 发表于 2018-9-19 10:13 | 只看该作者
/*                     第二组级联74LS595_2数码管驱动程序         */
#ifndef _LS595_2driver_H_
#define _LS595_2driver_H_
sbit RCK_595_2 = P0^4;        //第二组级联595的并行输出时钟
sbit DS_595_2 = P0^3;         //第二组级联595数据线
sbit CLK_595_2 = P0^5;        //第二组级联595移位输入时钟
unsigned char code countupseg[] =        //第二组595中定义0~9,高亮低灭
{// 0         1          2           3        4         5          6           7        8         9
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F
unsigned char code roundseg[6]={0x01,0x02,0x04,0x08,0x10,0x20}; //花式旋转
/*延时函数  1ms为单位*/
void Delay_ms(unsigned int t)           //延时函数,t/ms
  unsigned int a,b;
  for(a=0;a<t;a++)
    for(b=0;b<100;b++)
       _nop_();
/* 向1个LS595_2写入1个字节*/
void Send1byte_595_2(unsigned char dat)
  unsigned char i;
  for(i=0;i<8;i++)
        if(dat&0x80)
        DS_595_2 = 1;
        DS_595_2 = 0;
        dat <<=1;
        CLK_595_2 = 0;
        _nop_();
        CLK_595_2 = 1;
/* 向3个级联LS595_2写入3个字节*/
void Send3byte_595_2(unsigned char dat1,unsigned char dat2,unsigned char dat3)
  Send1byte_595_2(dat1);
  Send1byte_595_2(dat2);
  Send1byte_595_2(dat3);
/*允许将LS595输出并行数据*/
void Out_595_2()
  RCK_595_2 = 0;
  _nop_();
  RCK_595_2 = 1;
/*显示倒计时 3位*/
void Displaycountupnum(unsigned int num)
  unsigned int units,tens,hundreds;
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Send3byte_595_2(countupseg[hundreds],countupseg[tens],countupseg[units]);        //显示倒计时的个、十、百位
  Out_595_2();
/*大字花式转圈*/
void Displayround()
  unsigned char j;
  for(j=0;j<5;j++)
    Send3byte_595_2(roundseg[j],roundseg[j],roundseg[j]);
        Out_595_2();
        Delay_ms(800);
#endif
参与人数 1黑币 +40 收起 理由
admin + 40 回帖助人的奖励!
ID:393625 发表于 2018-9-20 08:47 | 只看该作者
cico 发表于 2018-9-17 14:36
你是想做成日期一样吗?
就是数码管000-999的的正计时,一天加一。
ID:393625 发表于 2018-9-20 10:26 | 只看该作者
/*                     DS1302驱动程序                            */
#ifndef _ds1302driver_H_
#define _ds1302driver_H_
//#include<LS595driver.h>
sbit RST_1302 = P2^2;       //1302的RST
sbit IO_1302 = P2^1;        //1302的IO
sbit SCLK_1302 = P2^0;      //1302的SCLK
sbit ACC0 = ACC^0;          //定义单片机累加器寄存器ACC
sbit ACC7 = ACC^7;          //定义单片机累加器寄存器ACC
/*  宏定义DS1302的写入寄存器  */
#define WDS1302_SECOND  0X80
#define WDS1302_MINUTE  0X82
#define WDS1302_HOUR    0X84
#define WDS1302_WEEK    0X8A
#define WDS1302_DAY     0X86
#define WDS1302_MONTH   0X88
#define WDS1302_YEAR    0X8C
#define WDS1302_BATTERY 0X90
/*  宏定义DS1302的读取寄存器  */
#define RDS1302_SECOND  0X81
#define RDS1302_MINUTE  0X83
#define RDS1302_HOUR    0X85
#define RDS1302_WEEK    0X8B
#define RDS1302_DAY     0X87
#define RDS1302_MONTH   0X89
#define RDS1302_YEAR    0X8D
#define RDS1302_BATTERY 0X91
/*向DS1302写入一个字节*/
void Send1byte_1302(unsigned char dat)
  unsigned char i;
  ACC = dat;        //将dat放入累加器ACC内
  for(i=8;i>0;i--)
    IO_1302 = ACC0;     //将ACC的最低位赋值给IO管脚
        SCLK_1302 = 1;
        SCLK_1302 = 0;
        ACC = ACC>>1;
/*从DS1302读取一个字节*/
unsigned char Get1byte_1302()
  unsigned char i;
  for(i=8;i>0;i--)
    ACC = ACC>>1;                  //挪空最高位
        ACC7 = IO_1302;       //将IO管脚赋值给ACC的最高位
    SCLK_1302 = 1;
        SCLK_1302 = 0;
  return(ACC);
/*向DS1302指定地址写入数据  add--1302的地址,dat--写入的数据*/
void Write_1302(unsigned char add,unsigned char dat)
  RST_1302 = 0;
  SCLK_1302 = 0;
  RST_1302 = 1;
  Send1byte_1302(add);
  Send1byte_1302(dat);
  SCLK_1302 = 1;
  RST_1302 = 0;
/*从DS1302指定地址读取数据  add--1302的地址*/
unsigned char Read_1302(unsigned char add)
  unsigned char temp;
  RST_1302 = 0;
  SCLK_1302 = 0;
  RST_1302 = 1;
  Send1byte_1302(add|0x01);
  temp = Get1byte_1302();
  SCLK_1302 = 1;
  RST_1302 = 0;
  return(temp);
/*设置写保护 flag=1~禁止写  flag=0~允许写*/
void Protect_1302(unsigned char flag)
  if(flag)
    Write_1302(0x8e,0x80);
    Write_1302(0x8e,0x00);
/*初始化DS1302 的日期*/
void Init_1302()//
  RST_1302 = 0;
  SCLK_1302 = 0;
  Protect_1302(0);                    //允许写操作
  Write_1302(WDS1302_SECOND,0x00);    //向DS1302秒寄存器80H写入秒初始00
  Write_1302(WDS1302_MINUTE,0x00);    //向DS1302分寄存器82H写入分初始00
  Write_1302(WDS1302_HOUR,0x12);      //向DS1302时寄存器84H写入时初始12
  Write_1302(WDS1302_WEEK,0x03);      //向DS1302周寄存器8aH写入周初始03
  Write_1302(WDS1302_DAY,0x01);       //向DS1302日寄存器86H写入日初始1
  Write_1302(WDS1302_MONTH,0x08);     //向DS1302月寄存器88H写入月初始8
  Write_1302(WDS1302_YEAR,0x18);      //向DS1302年寄存器8cH写入年初始18
  Protect_1302(1);                    //禁止写操作
/*设置单个寄存器日期时间*/
void Set_time_1302(unsigned char add,unsigned char time)
  unsigned char timeBCD;
  timeBCD = (time/10)<<4 | (time%10);   //将十进制转为二进制才能写入
  Write_1302(0x8e,0x00);                                //允许写入
  Write_1302(add,timeBCD);
  Write_1302(0x8e,0x80);                                //启动保护 禁止写
/*获取DS1302内的时间日期*/
void Gettime_1302(SYSTEMTIME *time)
  unsigned char gettempe;
  gettempe = Read_1302(RDS1302_SECOND);                                                   //获取秒寄存器
  time->second = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成秒赋值 二进制转十进制
  gettempe = Read_1302(RDS1302_MINUTE);                                                   //获取分寄存器
  time->minute = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成分赋值 二进制转十进制
  gettempe = Read_1302(RDS1302_HOUR);                                                   //获取时寄存器
  time->hour = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成时赋值 二进制转十进制
  gettempe = Read_1302(RDS1302_WEEK);                                                   //获取周寄存器
  time->week= ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成周赋值 二进制转十进制
  gettempe = Read_1302(RDS1302_DAY);                                                   //获取日寄存器
  time->day = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成日赋值 二进制转十进制
  gettempe = Read_1302(RDS1302_MONTH);                                                   //获取月寄存器
  time->month = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成月赋值 二进制转十进制
  gettempe = Read_1302(RDS1302_YEAR);                                                   //获取年寄存器
  time->year = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成年赋值 二进制转十进制
#endif
请问这个程序能达到我想要的效果吗
ID:393625 发表于 2018-9-20 10:46 | 只看该作者
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Out_595_2();
ID:393625 发表于 2018-9-20 10:48 | 只看该作者
其实,是把要显示的变量,换成
/*延时函数  1ms为单位*/
  unsigned int a,b;
  for(a=0;a<t;a++)
    for(b=0;b<100;b++)
       _nop_();
  unsigned char i;
  for(i=0;i<8;i++)
        if(dat&0x80)
        DS_595_2 = 1;
        DS_595_2 = 0;
        dat <<=1;
        CLK_595_2 = 0;
        _nop_();
        CLK_595_2 = 1;
/*允许将LS595输出并行数据*/
void Out_595_2()
  RCK_595_2 = 0;
  _nop_();
  RCK_595_2 = 1;
/*显示倒计时 3位*/
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Out_595_2();
/*大字花式转圈*/
void Displayround()
  unsigned char j;
  for(j=0;j<5;j++)
        Out_595_2();
        Delay_ms(800);
#endif
