查看: 1881|回复: 0
51单片机小车循迹程序怎么写出来的讲解一下
ID:396867 发表于 2018-9-19 11:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
uchar temp,signal,tt1;
void delay_1ms(uint d)
uint i;
while(d--)
  for(i=0;i<75;i++);
void motor_run()     //?????
   P1=0x35;
delay_1ms(150);
P1=0x00;
delay_1ms(20);
/* ENA=1;
OUT1=0;
OUT2=1;
delay_1ms(800);
OUT2=0;
delay_1ms(200);
ENB=1;
OUT4=0;
OUT3=1;
delay_1ms(800);
OUT3=0;
delay_1ms(200);
void motor_left()    //???
P1=0x30;
delay_1ms(150);
P1=0x00;
delay_1ms(20);
void motor_right()     //???
P1=0x05;
delay_1ms(150);
P1=0x00;
delay_1ms(20);
void motor_big_right()    //?????
P1=0x55;
delay_1ms(150);
P1=0x00;
delay_1ms(20);
void motor_big_left()
P1=0x33;
delay_1ms(150);
P1=0x00;
delay_1ms(20);
void motor_stop()     //?????
  P1=0x00;
void motor_back()
P1=0x53;
tt1=0;
EA=1;
ET1=1;
TR1=1;
TMOD=0x01;
TH1=-(1000/256);
TL1=-(1000%256);
   temp=P2;
  signal=temp&0xff;     //????????????
  switch(signal)
   case 0xff:    //?????
    motor_run();
    break;
   case 0xfd:    //1?????
    motor_left();
    break;
   case 0xef:     //4?????
    motor_right();
    break;
   case 0xfb:     //2?????????
   case 0xf9:    //1??2?????
     motor_big_left();
//    delay_1ms(10);
    break;
   case 0xdf:    //5???????
   case 0xcf:      //4??5?????
     motor_big_right();
//    delay_1ms(10);
    break;
   case 0xfe:    //0?????????
   case 0xfa:
     motor_big_left();
//    delay_1ms(10);
    break;
   case 0xbf:     //6?????????
    case 0x9f:
    motor_big_right();
//    delay_1ms(10);
    break;
   case 0xeb:  //?????????????????
   case 0xdb:  //??????????????????
   case 0xbe:  //?м?????????????????
   case 0xac:   //????????????????
   case 0x9a:  //?????????????????
    motor_back();
    delay_1ms(200);
    motor_stop();
//    delay_1ms(1000);
   default:
    break;
void time1() interrupt 3
TH1=-(1000/256);
TL1=-(1000%256);
tt1++;
if(tt1==300)
  motor_back();
// delay_1ms(1);
  tt1=0;
