查看: 1304|回复: 0
c#串口通讯
ID:401988 发表于 2018-9-25 08:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
namespace ComDemo
    public partial class ComSet : Form
        public ComSet()
            InitializeComponent();
        private void ComSet_Load(object sender, EventArgs e)
            //串口
            string[] ports = SerialPort.GetPortNames();
            foreach (string port in ports)
                cmbPort.Items.Add(port);
            cmbPort.SelectedIndex = 0;
            //波特率
            cmbBaudRate.Items.Add("110");
            cmbBaudRate.Items.Add("300");
            cmbBaudRate.Items.Add("1200");
            cmbBaudRate.Items.Add("2400");
            cmbBaudRate.Items.Add("4800");
            cmbBaudRate.Items.Add("9600");
            cmbBaudRate.Items.Add("19200");
            cmbBaudRate.Items.Add("38400");
            cmbBaudRate.Items.Add("57600");
            cmbBaudRate.Items.Add("115200");
            cmbBaudRate.Items.Add("230400");
            cmbBaudRate.Items.Add("460800");
            cmbBaudRate.Items.Add("921600");
            cmbBaudRate.SelectedIndex = 5;
            //数据位
            cmbDataBits.Items.Add("5");
            cmbDataBits.Items.Add("6");
            cmbDataBits.Items.Add("7");
            cmbDataBits.Items.Add("8");
            cmbDataBits.SelectedIndex = 3;
            //停止位
            cmbStopBit.Items.Add("1");
            cmbStopBit.SelectedIndex = 0;
            //佼验位
            cmbParity.Items.Add("无");
            cmbParity.SelectedIndex = 0;
        private void bntOK_Click(object sender, EventArgs e)
            //以下4个参数都是从窗体MainForm传入的
            MainForm.strProtName = cmbPort.Text;
            MainForm.strBaudRate = cmbBaudRate.Text;
            MainForm.strDataBits = cmbDataBits.Text;
            MainForm.strStopBits = cmbStopBit.Text;
            DialogResult = DialogResult.OK;
        private void bntCancel_Click(object sender, EventArgs e)
            DialogResult = DialogResult.Cancel;
