查看: 6808|回复: 2
ili9486 tft屏硬件规格书资料(中景园电子3.5寸字库SPI接口)
spi驱动
中景园3.5寸TFT LCD 带字库SPI接口原理图.pdf
中景园3.5寸TFT LCD 带字库SPI接口结构图.pdf
中景园3.5寸TFT LCD 规格书 .pdf
中景园3.5寸TFT LCD 驱动芯片ILI9486规格书.pdf
字库芯片GT30L32S4W规格书.pdf
ILI9486 supports MIPI DSI which can be enabled or disabled by external IM [4] pin. ILI9486 can be accessed
through one PHY lane module which communicates via two lines to a complementary part at the other side of
the lane interconnects. The communication can be separated two different levels between the MCU and ILI9486:
      ● Low level communication what is done on the interface level.
      ● High level communication what is done on the packet level.
ILI9486 uses data and clock lane differential pairs for DSI, The data lane (DATAP and DATAN) is used for data
communication and clock lane (CLKP and CLKN) is used to transmit the clock signal. The Mobile Industry
Processor Interface (MIPI) can be used for communication between the processor and DSI-compliant LCD
driver chip. The selection of this interface is done when IM [3:1] pins are high state (IOVCC level).
全部资料51hei下载地址:
中景园电子3.5寸字库SPI接口技术资料.zip (8.78 MB, 下载次数: 177)
收藏收藏1 分享淘帖 顶 踩
ID:369039 发表于 2020-2-27 00:24 | 只看该作者
   好东西 正在学习这些东西
ID:230895 发表于 2020-3-18 09:47 | 只看该作者
我使用字库例程,字库里面的ascii码可以正常显示,但汉字乱码,什么原因
