查看: 3739|回复: 2
单片机按键程序,支持连按(中断实现)
ID:222142 发表于 2018-9-26 09:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "INT.h"
void INT_Initial(void)
        INTEDG = 0;                                //0 下降沿触发  1 上升沿触发
        TRISBbits.TRISB0 = 1;        //RB0设置为输入
        LATBbits.LATB0 = 1;                //设置初始状态位高电平 , 为下降沿触发中断做准备
        INTCONbits.GIE = 1;                //允许所有中断
        INTCONbits.PEIE = 1;        //允许外设中断
        /*外部中断初始位*/
        INTCONbits.INTE = 1;        //允许外部中断
        INTCONbits.INTF = 0;        //外部中断标志位清0
        /*定时器0中断初始位*/
        INTCONbits.TMR0IE = 1;        //允许定时器0溢出中断
        INTCONbits.TMR0IF = 0;        //定时器0溢出中断标志位清0
        /*定时器1中断初始位*/
        PIE1bits.TMR1IE = 1;        //允许定时器1溢出中断
        PIR1bits.TMR1IF = 0;        //定时器1溢出中断标志位清0
        /*ADC中断初始位*/
        PIE1bits.ADIE = 1;                //允许ADC中断
        PIR1bits.ADIF = 0;                //ADC中断标志位清0
void Get_KeyValue(void)
    if((timing_s_count2 - key_keep_time) < 1)
            switch (key_value_buffer){
                case 0xFE://S1 K1 RF0
                    KeyCode = KEY_ENTER;
                    break;
//                case 0xFD://S3 K2 RF1
//                    KeyCode = KEY_UP;
//                    break;
                case 0xFB://S5 K3 RF2
                    KeyCode = KEY_LIGHT;
                    break;
//                case 0xF7://S7 K4 RF3
//                    KeyCode = KEY_DOWN;
//                    break;
                case 0xEF://S2 K5 RF4
                    KeyCode = KEY_BACK;
                    break;
                case 0xDF://S4 K6 RF5
                    KeyCode = KEY_FAN;
                    break;
//                case 0xBF://S6 K7 RF6
//                    KeyCode = KEY_STDBY;
//                    break;
                case 0x7F://S8 K8 RF7
                    KeyCode = KEY_SETUP;
                    break;
                default:
                    KeyCode = 0;
                    break;
    key_action_flag = 0;
void Get_key_valve_Long_press(void)
           if((timing_s_count2 - key_keep_time) > 1)
            case 0xFE:
                break;
                    break;
            default:
                key_action_flag_Long_press = 0;
                break;
void Get_key_valve_continuty(void)
                if(key_action_flag_continuty == 1)
                 switch (PORTF){
                    test_show_num = KEY_UP;
                    break;
                    test_show_num = KEY_DOWN;
                    break;
                default:
                test_show_num = 0;
                break;
void interrupt ISR(void)
        /*定时器0中断服务程序段*/
        if(TMR0IE & TMR0IF)
                TMR0 = 0x07;
                timing_ms_count1++;
                timing_ms_count3++;
                if(timing_ms_count1 % 300 == 0 && timing_ms_count1 != 0)
                        if(S16 == 1)
                                S15 = ~S15;
                        if(S11 == 1)
                                S12 = ~S12;
                        if(warning_flag == 1)
                                S1 = ~ S1;
                if(timing_ms_count1 % 500 == 0 && timing_ms_count1 != 0)
                        timing_half_s_count1++;
                if(timing_ms_count1 % 450 == 0 && timing_ms_count1 != 0)
                        LCD_showFanrun();
                TMR0IF = 0;
        /*定时器1中断服务程序段*/
        if(TMR1IE & TMR1IF)
                TMR1H = 0xFF;
                TMR1L = 0x08;
                timing_ms_count2++;
                if(timing_ms_count2 % 1000 == 0)
                        /*计时时间处理*/
                        if(S13 == 1)
                                timing_count_sec_set--;
                        Key_isrelease_time++;        //按键释放时间计时
                        timing_s_count1++;                //秒计时器1(未用)
                        /*系统运行时间处理*/
                        timing_s_count2++;
                        if(timing_s_count2 % 60 == 0)
                                timing_s_count2 = 0;
                                sys_time_minute++;
                                if(sys_time_minute % 30 == 0)
                                        sys_time_minute=0;
                                        sys_time_half_hour++;        //运行半小时计时
                                        if(sys_time_half_hour % 1440 == 0)
                                                sys_time_half_hour = 0;
                                                sys_time_month++;//运行月份计时
                if((PORTF != 0xFF) && (key_action_flag == 1))
                                Get_KeyValue();
                                key_count = 0;
                if((PORTF != 0xFF) && (key_action_flag_Long_press == 1))
                                Get_key_valve_Long_press();
                if((PORTF != 0xFF) && (key_action_flag_continuty == 1))
                                Get_key_valve_continuty();
                if(timing_ms_count2 % 200 == 0)
                        if((test_show_num == KEY_UP) || (test_show_num == KEY_DOWN))
                                KeyCode = test_show_num;
                if(PORTF == 0xFF)
                                test_show_num = 0;
                                key_action_flag_continuty == 0;
                if((KeyCode == KEY_UP) || (KeyCode == KEY_DOWN))
            Key_isrelease_time = 0;
                TMR1IF = 0;
        /*外部中断服务程序段*/
        if(INTF == 1)
                if(PORTF != 0xFF && key_action_flag == 0)
                        key_action_flag = 1;
                        key_action_flag_Long_press = 1;
                        key_action_flag_continuty = 1;
                        key_value_buffer = PORTF;
                        key_keep_time = timing_s_count2;
                INTF = 0;
                INTE = 0;
                TRISBbits.TRISB0 = 0;
                LATBbits.LATB0 = 1;
        /*ADC中断服务程序段*/
//        if(ADIE & ADIF)
//                ADIF = 0;
ID:1 发表于 2018-9-26 15:45 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
ID:66287 发表于 2018-9-27 09:29 | 只看该作者
高手!一句注释都没有,真高人
