查看: 4778|回复: 5
stm32f105例程 CAN500K USART_LED
回帖奖励 2 黑币 回复本帖可获得 2 黑币奖励! 每人限 1 次
ID:397541 发表于 2018-9-28 09:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
stm32f105例程
  1. /*
  2.         CAN1
  3.         USART1
  4.     CAN波特率、收发器 配置见CAN.h
  5.         stm32f10x.h中修改了外部晶振值8MHz
  6.
  7. */
  8. /* Includes ------------------------------------------------------------------*/
  9. #include "stm32f10x.h"
  10. #include "stm32f10x_rcc.h"
  11. #include "stm32f10x_flash.h"
  12. #include "stm32f10x_can.h"
  13. #include "usart.h"
  14. #include "CAN.h"
  15. #include <stdio.h>
  16. void RCC_Configuration(void);
  17. void LED_Config(void);
  18. void Delay(__IO uint32_t nCount);
  19. CanTxMsg TxMsg1={0xAB,0,CAN_ID_STD,CAN_RTR_DATA,8,{0xAB,0,0,0,0,0,0,0}};
  20. CanTxMsg TxMsg2={0xCD,0,CAN_ID_STD,CAN_RTR_DATA,8,{0xCD,0,0,0,0,0,0,0}};
  21. int main(void)
  22. {
  23.
  24.   /* System Clocks Configuration **********************************************/
  25.   RCC_Configuration();
  26.   LED_Config();
  27.   // 串口配置
  28.   USART_Configuration();
  29.   USART_STR(USART2,"++++++++++++++++++++++++\r\n");
  30.   USART_STR(USART2,"  CAN Study Board\r\n");
  31.   USART_STR(USART2,"++++++++++++++++++++++++\r\n");
  32.
  33.
  34.   // CAN1 配置
  35.   CAN1_Config(SET_CAN_SJW,SET_CAN_BS1,SET_CAN_BS2,SET_CAN_PRES);
  36.
  37.   Delay(2000);
  38.
  39.   // CAN2 配置
  40.   CAN2_Config(SET_CAN_SJW,SET_CAN_BS1,SET_CAN_BS2,SET_CAN_PRES);
  41.
  42.
  43.   while (1)
  44.   {
  45.           GPIO_ResetBits(GPIOC,GPIO_Pin_0);
  46.           GPIO_SetBits(GPIOC,GPIO_Pin_1);
  47.           GPIO_SetBits(GPIOC,GPIO_Pin_14);
  48.           GPIO_SetBits(GPIOC,GPIO_Pin_15);
  49.       Delay(5000);
  50.           Delay(5000);
  51.           GPIO_SetBits(GPIOC,GPIO_Pin_0);
  52.           GPIO_ResetBits(GPIOC,GPIO_Pin_1);
  53.           GPIO_SetBits(GPIOC,GPIO_Pin_14);
  54.           GPIO_SetBits(GPIOC,GPIO_Pin_15);
  55.           CAN_SendData(CAN1,&TxMsg1);
  56.           Delay(5000);
  57.           Delay(5000);
  58.           GPIO_SetBits(GPIOC,GPIO_Pin_0);
  59.           GPIO_SetBits(GPIOC,GPIO_Pin_1);
  60.           GPIO_ResetBits(GPIOC,GPIO_Pin_14);
  61.           GPIO_SetBits(GPIOC,GPIO_Pin_15);
  62.           Delay(5000);
  63.           Delay(5000);
  64.           GPIO_SetBits(GPIOC,GPIO_Pin_0);
  65.           GPIO_SetBits(GPIOC,GPIO_Pin_1);
  66.           GPIO_SetBits(GPIOC,GPIO_Pin_14);
  67.           GPIO_ResetBits(GPIOC,GPIO_Pin_15);
  68.           Delay(5000);
  69.           Delay(5000);
  70.
  71.           CAN_SendData(CAN2,&TxMsg2);
  72.   }
  73. }
  74. void RCC_Configuration(void)
  75. {
  76.   /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
  77.      initialize the PLL and update the SystemFrequency variable. */
  78.   SystemInit();
  79.
  80. }
  81. void Delay(__IO uint32_t nCount)
  82. {
  83.     uint8_t x;
  84.     for(; nCount != 0; nCount--)
  85.             for(x=0;x<100;x++);
  86. }
  87. void LED_Config(void)
  88. {
  89.   GPIO_InitTypeDef GPIO_InitStructure;
  90.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  91.
  92.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_14|GPIO_Pin_15;
  93.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  94.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  95.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  96. }
  97. #ifdef  USE_FULL_ASSERT
  98. /**
  99.   * @brief  Reports the name of the source file and the source line number
  100.   *   where the assert_param error has occurred.
  101.   * @param  file: pointer to the source file name
  102. ……………………
  103. …………限于本文篇幅 余下代码请从51黑下载附件…………
stm32f105.rar (458.73 KB, 下载次数: 117)
收藏收藏1 分享淘帖 顶 踩
ID:418101 发表于 2018-10-31 12:15 | 只看该作者
楼主你好,我用你的代码,测试105r8 CAN时,发现发送的时候还是发不出去,在tx pin看不到波形,一直是高电平,打印transmit的返回值,发现mailbox值一直从1 2 3 4 4 4 后面就一直是4了,也就是从未发出去,楼主测试过吗?
ID:191583 发表于 2019-1-29 14:30 | 只看该作者
正在学习,谢谢提供的资料。
ID:158966 发表于 2019-7-30 09:49 | 只看该作者
正在学习,谢谢提供的资料
ID:251047 发表于 2019-7-30 15:05 | 只看该作者
多谢分享,哈哈哈
ID:320751 发表于 2020-9-7 21:17 | 只看该作者
谢谢分享  学习一下 感恩付出
