查看: 2480|回复: 0
STC89xx系列单片机串行口的测试程序(C程序)
ID:402219 发表于 2018-9-29 08:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
串行口的测试程序(C程序及汇编程序)
1. C程序:
/* --- STC MCU International Limited ---------------------------------------*/
/* --- 演示STC89xx系列单片机串行口功能 (8-bit/9-bit) ----------------*/
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 18432000L //System frequency
#define BAUD 9600 //UART baudrate
/*Define UART parity mode*/
#define NONE_PARITY 0 //None parity
#define ODD_PARITY 1 //Odd parity
#define EVEN_PARITY 2 //Even parity
#define MARK_PARITY 3 //Mark parity
#define SPACE_PARITY 4 //Space parity
#define PARITYBIT EVEN_PARITY //Testing even parity
sbit bit9 = P2^2; //P2.2 show UART data bit9
bit busy;
void SendData(BYTE dat);
void SendString(char *s);
#if (PARITYBIT == NONE_PARITY)
SCON = 0x50; //8-bit variable UART
135
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
SCON = 0xda; //9-bit variable UART, parity bit initial to 1
#elif (PARITYBIT == SPACE_PARITY)
SCON = 0xd2; //9-bit variable UART, parity bit initial to 0
#endif
TMOD = 0x20; //Set Timer1 as 8-bit auto reload mode
TH1 = TL1 = -(FOSC/12/32/BAUD); //Set auto-reload vaule
TR1 = 1; //Timer1 start run
ES = 1; //Enable UART interrupt
EA = 1; //Open master interrupt switch
SendString("STC89-90xx\r\nUart Test !\r\n");
while(1);
UART interrupt service routine
void Uart_Isr() interrupt 4 using 1
if (RI)
RI = 0; //Clear receive interrupt flag
P0 = SBUF; //P0 show UART data
bit9 = RB8; //P2.2 show parity bit
if (TI)
TI = 0; //Clear transmit interrupt flag
busy = 0; //Clear transmit busy flag
Send a byte data to UART
Input: dat (data to be sent)
Output:None
while (busy); //Wait for the completion of the previous data is sent
ACC = dat; //Calculate the even parity bit P (PSW.0)
if (P) //Set the parity bit according to P
#if (PARITYBIT == ODD_PARITY)
136
TB8 = 0; //Set parity bit to 0
#elif (PARITYBIT == EVEN_PARITY)
TB8 = 1; //Set parity bit to 1
#endif
#endif
busy = 1;
SBUF = ACC; //Send data to UART buffer
Send a string to UART
Input: s (address of string)
Output:None
while (*s) //Check the end of the string
SendData(*s++); //Send current char and increment string ptr
