查看: 3461|回复: 0
单片机4位时钟8位小灯闪烁仿真与程序
单片机同时实现4位时钟8位小灯闪烁的仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. /*
  6. sbit p20=P2^0;
  7. sbit p21=P2^1;
  8. sbit p22=P2^2;
  9. sbit p23=P2^3;
  10. */
  11. void Disp();
  12. void Delay_ms(uint delay);
  13. uchar code LED_Val[10] = {0xC0,0xF9,0xA4,0xb0,0x99,0x92,0x82,0xf8,0x80,0X98};//0-9
  14. uchar data num[4];
  15. uchar data led_point[4]={0xfe,0xfd,0xfb,0xf7};
  16. uchar i,s,m,h,second,jjjj,HHHH,LED=0XFE;
  17. uint ge,shi,bai,qian,display_number,bai1,shi1;
  18. void Disp()
  19. {
  20.            qian=display_number/1000 ;
  21.           bai1= display_number%1000        ;
  22.           bai=bai1/100;
  23.           shi1=bai1%100;
  24.           shi=shi1/10;
  25.           ge=shi1%10;
  26.     num[0] = ge;
  27.         num[1] = shi;
  28.         num[2] = bai;
  29.         num[3] =qian;
  30. for(i=0;i<4;i++)
  31. {
  32.   P1=LED_Val[num[i]];
  33.   P2=~led_point[i];
  34.   Delay_ms(2);
  35.   P1=0XFF;
  36.   P2=~0XFF;
  37. }
  38. }
  39. //////////// /////////////////////////
  40. void Delay_ms(uint delay)
  41. {
  42.   uchar j;
  43.   while(delay--)
  44.   {
  45.     for(j=125;j>0;j--)
  46.         {;}
  47.   }
  48. }
  49. void chushihua()
  50. {
  51. TMOD=0x01;
  52. TH0=-52500;
  53. TL0=-52500;
  54. ET0=1;
  55. EA=1;
  56. TR0=1;
  57. }
  58. void time_t0(void )  interrupt 1  using  1
  59. {
  60. TH0=-52500;
  61. TL0=-52500;
  62. //TH0=65534;
  63. //TL0=65534;
  64.         second++;
  65.         if(second ==40)
  66.         {
  67.           jjjj++;
  68.           if(jjjj==7)
  69.           {
  70.           P3=LED;
  71.           LED=LED<<1;
  72.           HHHH++;
  73.           if(HHHH>8){LED=0XFE;HHHH=0;}
  74.           jjjj=0;
  75.           }
  76.           second=0;
  77.            s++;
  78.            if(s == 60)
  79.            {
  80.                     m++;
  81.                  s        =0;
  82.                  if(m==60)
  83.                  {
  84.                           m=0;
  85.                          h++;
  86.                  if(h==24)
  87.                    {
  88.                    h=0;
  89.                    }
  90.                  }
  91.            }
  92.
  93.         }
  94. }
  95. ////////////////////////////////////////////////
  96. void main()
  97. {
  98. chushihua();
  99. //display_number=1234;
  100. while(1)
  101. {
  102. display_number=h*100+m;
  103. Disp();
  104. }
  105. }
4位时钟8位小灯闪烁.zip (57.15 KB, 下载次数: 16)
