查看: 2417|回复: 2
点阵滚动显示
ID:332269 发表于 2018-10-11 13:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
sbit SH_CP=P3^6;
sbit DS=P3^4;
sbit ST_CP=P3^5;
uchar num,temp,n,t;
uchar code tab[ ]=
{ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
0x00,0x3E,0x41,0x41,0x41,0x41,0x3E,0x00,/*"0",1*/
0x00,0x00,0x20,0x20,0x7F,0x00,0x00,0x00,/*"1",2*/
0x00,0x21,0x43,0x45,0x45,0x49,0x31,0x00,/*"2",3*/
0x00,0x22,0x41,0x49,0x49,0x49,0x36,0x00,/*"3",4*/
0x00,0x04,0x0C,0x14,0x24,0x7F,0x04,0x00,/*"4",5*/
0x00,0x72,0x51,0x51,0x51,0x53,0x4E,0x00,/*"5",6*/
0x00,0x3E,0x6B,0x49,0x49,0x49,0x26,0x00,/*"6",7*/
0x00,0x40,0x41,0x42,0x4C,0x50,0x60,0x00,/*"7",8*/
0x00,0x36,0x49,0x49,0x49,0x49,0x36,0x00,/*"8",9*/
0x00,0x32,0x49,0x49,0x49,0x4B,0x3E,0x00,/*"9",10*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,};/*" ",11*/
void delay_ms(unsigned int ms)
        uchar j;
        while(ms--)
        for(j=0;j<123;j++);
void WriteByte(uchar dat)
        uchar k;
        for(k=0;k<8;k++)
                dat=dat>>1;
                DS=CY;
                SH_CP=0;
                SH_CP=1;
                        for(n=0;n<88;n++)
                                        for(t=0;t<16;t++)// 重复显示 16 次,让流动稍微缓慢
                                                   { temp=0xfe;
                                                           {  for(num=n;num<8+n;num++)
        WriteByte(tab[num+0]);
        P0=temp;
        ST_CP=0;
        ST_CP=1;
        delay_ms(1);
        temp=_crol_(temp,1);
ID:1 发表于 2018-10-11 15:00 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
ID:332269 发表于 2018-10-13 18:47 | 只看该作者
sbit SH_CP=P3^6;  sbit DS=P3^4;  sbit ST_CP=P3^5; 为74HC595三输入端。所用普中开发板
参与人数 1黑币 +80 收起 理由
admin + 80 回帖助人的奖励!
