查看: 1606|回复: 0
sdram em638325引脚图与datasheet资料下载
ID:408660 发表于 2018-10-12 16:49 | 显示全部楼层 |阅读模式
里面有sdram的时序
em638325引脚图:
Overview
   The EM638325 SDRAM is a high-speed CMOS synchronous DRAM containing 64 Mbits. It is internally configured
as a quad 512K x 32 DRAM with a synchronous  interface  (all signals are  registered on  the positive edge of  the clock
signal, CLK). Each of  the 512K x 32 bit banks  is organized as 2048  rows by 256 columns by 32 bits. Read and write
accesses to the SDRAM are burst oriented; accesses start at a selected location and continue for a programmed number
of locations in a programmed sequence. Accesses begin with the registration of a BankActivate command which is then
followed by a Read or Write command.
    The  EM638325  provides  for  programmable Read  or Write  burst  lengths  of  1,  2,  4,  8,  or  full  page, with  a  burst
termination option. An auto precharge function may be enabled to provide a self-timed row precharge that is initiated at
the end of the burst sequence. The refresh functions, either Auto or Self Refresh are easy to use.
    By  having  a  programmable  mode  register,  the  system  can  choose  the  most  suitable  modes  to  maximize  its
performance. These devices are well suited for applications requiring high memory bandwidth.
Features
· Clock rate: 200/183/166/143/125/100 MHz
· Fully synchronous operation
·  Internal pipelined architecture
· Four internal banks (512K x 32bit x 4bank)
· Programmable Mode
  - CAS# Latency: 2 or 3
  - Burst Length: 1, 2, 4, 8, or full page
  - Burst Type: interleaved or linear burst
  - Burst-Read-Single-Write
· Burst stop function
·  Individual byte controlled by DQM0-3
· Auto Refresh and Self Refresh
· 4096 refresh cycles/64ms
· Single +3.3V ± 0.3V power supply
·  Interface:   LVTTL
· Package: 400 x 875 mil, 86 Pin TSOP II, 0.50mm
pin pitch
· Lead Free Package available
完整的pdf格式文档51黑下载地址:
datasheet.pdf (781.1 KB, 下载次数: 4)
