查看: 4453|回复: 2
1602液晶 求高手帮忙指点一下程序哪出错了?
ID:35521 发表于 2012-3-9 12:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include #define uint unsigned int #define uchar unsigned char sbit rs=P2^4; sbit en=P2^5; sbit rw=P2^6; uchar num; uchar code table[]="I LOVE YOU"; void delay_1ms(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void write_com(uchar com) { rs=0; rw=0; en=0; delay_1ms(1); P0=com; delay_1ms(2); en=1; delay_1ms(2); en=0; } void write_data(uchar date) { rs=1; rw=0; en=0; delay_1ms(1); P0=date; delay_1ms(2); en=1; delay_1ms(2); en=0; } void init() { write_com(0x38); delay_1ms(1); write_com(0x0C); delay_1ms(1); write_com(0x06); delay_1ms(1); write_com(0x01); delay_1ms(1); } mian() { init(); write_com(0x80); for(num=0;num<8;num++) { write_data(table[num]); delay_1ms(2); } }
ID:35521 发表于 2012-3-9 12:14 | 只看该作者
ID:34099 发表于 2012-3-10 09:49 | 只看该作者
液晶初始化函数先给液晶15ms的反应时间吧   在write_com(0x38); 前面加delay_1ms(15);
