查看: 2771|回复: 3
这个温度报警程序,上下限温度是怎么看的
ID:386308 发表于 2018-10-20 10:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include <intrins.h>
#include <math.h>
sbit RS = P0^7;
sbit LCDEN = P0^5;
sbit rw=P0^6;
sbit  BEEP=P3^6;
void delay500(void)     //500us延时函数
        uchar  i;
        for(i=230;i>0;i--);
void delayUs()
        _nop_();
void delayMs(uint a)
    uint i, j;
    for(i=a; i>0; i--)
    for(j=100; j>0; j--);
void writeComm(uchar comm)
        RS = 0;
    P2 = comm;
    LCDEN = 1;
        delayUs();
    LCDEN = 0;
    delayMs(1);
//写数据:RS=1, RW=0;
void writeData(uchar dat)
    RS = 1;
    P2 = dat;
    LCDEN = 1;
        delayUs();
    LCDEN = 0;
    delayMs(1);
void init()
    rw=0;
    writeComm(0x38);
    writeComm(0x0c);
        writeComm(0x06);
    writeComm(0x01);
void writeString(uchar * str, uchar length)
        uchar i;
    for(i=0; i<length; i++)
                writeData(str[i]);
/*******************************DS18B20*******************************/
sbit dq = P3^7;
void dqInit()
    unsigned int i;
    dq = 0;
    i = 100;
        while(i>0) i--;
    dq = 1;
    i = 4;
    while(i>0) i--;
void dqWait()
        unsigned int i;
    while(dq);
    while(~dq);
    i = 4;
    while(i > 0) i--;
bit readBit()
    unsigned int i;
    bit b;
    dq = 0;
    i++;
    dq = 1;
    i++; i++;
    b = dq;
    i = 8;
    while(i>0) i--;
    return b;
unsigned char readByte()
    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
        j = readBit();
        dat = (j<<7)|(dat>>1);
    return dat;
void writeByte(unsigned char dat)
    unsigned int i;
    unsigned char j;
    bit b;
    for(j=0; j<8; j++)
        b = dat & 0x01;
        dat >>= 1;
        if(b)
                        dq = 0;
                        i++;
            dq = 1;
            i = 8;
                        while(i>0)
                        i--;
            dq = 0;
            i = 8;
                        while(i>0)
                        i--;
            dq = 1;
            i++;
void sendChangeCmd()
    dqInit();
    dqWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
    dqInit();
    dqWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
    t = value * 0.0625;
    value = t*100+(value>0?0.5:-0.5); //大于0加0.5, 小于0减0.5
    return value;
void display(int v)
    unsigned char count;
    unsigned char datas[] = {0, 0, 0, 0, 0};
    unsigned int tmp = abs(v);
    datas[0] = tmp / 10000;
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
    datas[3] = tmp % 100 / 10;
    datas[4] = tmp % 10;
    writeComm(0xc0+3);
    if(v < 0)
                writeString("- ", 2);
        writeString("+ ", 2);
    if(datas[0] != 0)
        writeData('0'+datas[0]);
    for(count = 1; count != 5; count++)
        writeData('0'+datas[count]);
        if(count == 2)
            writeData('.');
    uchar table[] = "  Temperature:  ";
        int i;//i储存转换后的温度值
        uchar j;
    sendChangeCmd();
    init();
    writeComm(0x80);
    writeString(table, 16);
        delayMs(1000); //温度转换时间需要750ms以上
        writeComm(0xc0);
                i = getTmpValue();
                if(i > 2300)
                        for(j=200;j>0;j--)
                                  BEEP=~BEEP;       //输出频率1KHz
                                  delay500();       //延时500us
                        for(j=200;j>0;j--)
                                  BEEP=~BEEP;       //输出频率500Hz
                                  delay500();       //延时1ms
                                  delay500();
        display(i);
        sendChangeCmd();
ID:303383 发表于 2018-10-20 12:46 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:7485 发表于 2018-10-20 18:17 | 只看该作者
这个程序大概你还看不懂。
温度上下限是初始设置时写进去的。和温度实测值一同读出来。
ID:274129 发表于 2018-10-30 22:27 | 只看该作者
温度上下限是自己程序里面设置的
