查看: 3900|回复: 1
51单片机 红外通信控制舵机,自己写的程序实现不了?大神看看
ID:405273 发表于 2018-10-20 21:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51单片机红外控制舵机程序
#include "reg52.h"
#include <intrins.h>
typedef unsigned int u16;
typedef unsigned char u8;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit pwm =P1^5;
sbit IRIN=P3^2;        //红外传感器定义口
u8 jd;
u8 count;
u8 IrValue[6];
u8 Time;
u8 DisplayData[8];
u8 code smgduan[17]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0X76};
//extern controlcar(unsigned char contype);
u8 IRCOM[7];
延时函数
void delay(u16 i)
while(i--);
中断函数 定时器中断 0.25ms控制舵机
void Time0_Init()          //??????????
TMOD = 0x01;           //?????0????????1
IE   = 0x82;
TH0  = 0xff;
TL0  = 0x06;     //12MZ????0.25ms
TR0=1;                 //????????
EX1=1;
  IT1=1;
  EA=1;
void DigDisplay()  //数码管显示函数
u8 i;
for(i=0;i<3;i++)
  switch(i)  //λ?????????????????
   case(0):
    LSA=0;LSB=0;LSC=0; break;//?????0λ
   case(1):
    LSA=1;LSB=0;LSC=0; break;//?????1λ
   case(2):
    LSA=0;LSB=1;LSC=0; break;//?????2λ
  P0=DisplayData[2-i];//????????
  delay(100); //????????????
  P0=0x00;//????
//舵机定义函数
void zuozhuan()
delay(100);
jd=3;
count=0;
void guiwei()
delay(100);
jd=4;
count=0;
void youzhuan()
delay(100);
jd=5;
count=0;
void controlcar(unsigned char contype)
jd=4;
switch(contype)
  case 1:
   zuozhuan();
   delay(100) ;
   break;
  case 2:
   guiwei()   ;
   delay(100);
   break;
  case 3:
   youzhuan();
   delay(100);
   break;
* ??????         : IrInit()
void IrInit()
IT0=1;//????????
EX0=1;//???ж?0????
EA=1; //?????ж?
IRIN=1;//????????
* ?? ?? ??       : main
IrInit();
Time0_Init();
// EX1=1;                                               //????????ж?1
//  IT1=1;                                               //?趨???ж?1?????????????
//  EA=1;
delay(10);
  DisplayData[0] = smgduan[IrValue[2]/16];
  DisplayData[1] = smgduan[IrValue[2]%16];
  DisplayData[2] = smgduan[16];
     DigDisplay();
红外线解码函数
void IR_IN() interrupt 2 using 0                      //????INT2???ж????
  unsigned char j,k,N=0;                              //??????????????
  EX1 = 0;                                            //??????ж?,?????????????
  delay(15);                                        //?????????к???????
  if (IRIN==1)                                        //?ж?????????????
     EX1 =1;                                          //???ж??
  return;                                          //????
  while (!IRIN)                                       //??IR?????????????9ms?????????????
      delay(1);                                     //??????
  for (j=0;j<4;j++)                                   //????????????????
    for (k=0;k<8;k++)                                 //??β??8λ????
       while (IRIN)                                   //?? IR ?????????????4.5ms?????????????
         delay(1);                                  //??????
       while (!IRIN)                                  //?? IR ???????
         delay(1);                                  //??????
       while (IRIN)                                   //????IR???????
         delay(1);                                  //??????
         N++;                                         //?????????
         if (N>=30)                                   //?ж??????????
           EX1=1;                                     //?????ж????
        return;                                    //????
      IRCOM[j]=IRCOM[j] >> 1;                         //????????λ??????????????
      if (N>=8)                                       //?ж????????
         IRCOM[j] = IRCOM[j] | 0x80;                  //???????λ??1
      N=0;                                            //????λ???????
  if (IRCOM[2]!=~IRCOM[3])                            //?ж???????????
     EX1=1;                                           //?????ж?
     return;                                          //????
  for(j=0;j<10;j++)                                   //??????м??????
      if(IRCOM[2]=smgduan[j])                       //???м?λ???
       controlcar(j);                                          //???????????????
   EX1 = 1;                                           //???ж??
void Time0_Int() interrupt 1 //定时器中断函数
TH0  = 0xff;             //??????
TL0  = 0x06;
    if(count< jd)              //?ж?0.5ms???????С??????
      pwm=1;                  //??С???PWM???????
      pwm=0;                  //?????????????
    count=(count+1);          //0.5ms??????1
    count=count%40;     //???????????40 ???????????20ms
ID:334190 发表于 2018-10-21 15:52 | 只看该作者
我也遇到过你这个问题,后来我换了接收头哈哈哈。淘宝上有卖的,接收特定的码值输出高电平。哪一款一共有8个输出位,可以实现遥控的功能。就是避开了解码的一步
y宝链接在下面,但是要邮费有点贵
【8路点动红外接收模块/红外接收模块/红外模块/接收模块+9键遥控器】
链接下载.rar
726 Bytes, 下载次数: 14
admin + 50 回帖助人的奖励!
