查看: 5749|回复: 1
PIC单片机的一个简单的SPI小程序
这里介绍一个简单的PIC单片机SPI测试小程序,希望大家能够喜欢。
  1. // DAC module connections
  2. sbit Chip_Select at RC0_bit;
  3. sbit Chip_Select_Direction at TRISC0_bit;
  4. // End DAC module connections
  5. unsigned int value;
  6. void InitMain() {
  7.   TRISA0_bit = 1;                        // Set RA0 pin as input
  8.   TRISA1_bit = 1;                        // Set RA1 pin as input
  9.   Chip_Select = 1;                       // Deselect DAC
  10.   Chip_Select_Direction = 0;             // Set CS# pin as Output
  11.   SPI1_Init();                           // Initialize SPI module
  12. }
  13. // DAC increments (0..4095) --> output voltage (0..Vref)
  14. void DAC_Output(unsigned int valueDAC) {
  15.   char temp;
  16.   Chip_Select = 0;                       // Select DAC chip
  17.
  18.   // Send High Byte
  19.   temp = (valueDAC >> 8) & 0x0F;         // Store valueDAC[11..8] to temp[3..0]
  20.   temp |= 0x30;                          // Define DAC setting, see MCP4921 datasheet
  21.   SPI1_Write(temp);                      // Send high byte via SPI
  22.
  23.   // Send Low Byte
  24.   temp = valueDAC;                       // Store valueDAC[7..0] to temp[7..0]
  25.   SPI1_Write(temp);                      // Send low byte via SPI
  26.
  27.   Chip_Select = 1;                       // Deselect DAC chip
  28. }
  29. void main() {
  30.   ANSEL = 0;
  31.   ANSELH = 0;
  32.   InitMain();                            // Perform main initialization
  33.   value = 2048;                          // When program starts, DAC gives
  34.                                          //   the output in the mid-range
  35.
  36. while (1) {                             // Endless loop
  37.     if ((RA0_bit) && (value < 4095)) {   // If RA0 button is pressed
  38.       value++;                           //   increment value
  39.       }
  40.     else {
  41.       if ((RA1_bit) && (value > 0)) {    // If RA1 button is pressed
  42.         value--;                         //   decrement value
  43.         }
  44.       }
  45.     DAC_Output(value);                   // Send value to DAC chip
  46.     Delay_ms(1);                         // Slow down key repeat pace
  47.   }
  48. }
详细内容,请参考:http://www.51hei.com/bbs/dpj-138111-1.html
ID:247624 发表于 2018-12-12 17:06 | 只看该作者
你好!pic的spi怎么检测发送完成呀,能贴一下你的SPI1_Write代码吗?谢谢
