查看: 6544|回复: 3
基于DSP28035的SPWM程序
ID:415421 发表于 2018-10-25 19:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于DSP28035的SPWM程序设计
  1. #include "DSP28x_Project.h"
  2. #include "HK_all_include.h"
  3. extern Uint16 RamfuncsLoadSize;
  4. void InitLED(void);
  5. //Uint16 Error;
  6. //Uint16 Tmp = 0;
  7. void main(void)
  8. {
  9.    InitSysCtrl();
  10.    DINT;
  11.    InitPieCtrl();
  12.    IER = 0x0000;
  13.    IFR = 0x0000;
  14.    InitPieVectTable();
  15.    memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (Uint32)&RamfuncsLoadSize);
  16.    //InitLED();        //LED初始化
  17.    //SCI_Init();
  18.    //open_uart_debug();
  19.   // printf("\r\n\r\nDSP is ready!\r\n");
  20.     //softResetIIC_BUS();         //软件复位IIC从设备
  21.            //InitI2C_Gpio();             //io 初始化为IIC
  22.            //I2CA_Init();                //HW IIC初始化,100KHz
  23.            //Timer0_init();
  24.            //ADC_Config();
  25.            //LigntVal = 0x71;//BIT6到BIT4为亮度调节,BIT0是  1 开启/0关闭
  26.            //TM1650_Send(CMD_SEG,LigntVal);   //8级亮度,开启显示
  27.            //TM1650_Send(DIG1,SEG7Table[0]);  //GID1
  28.            //TM1650_Send(DIG2,SEG7Table[0]);  //GID2
  29.            //TM1650_Send(DIG3,SEG7Table[0]);  //GID3
  30.            //TM1650_Send(DIG4,SEG7Table[0]);  //GID4
  31.    //        Running.showNum = PWM7BLED.PWMstep;
  32.            //Running.showNum = AdcResult.ADCRESULT2;
  33.    //        Running.showhex[0]=SEGHexBLK;
  34.    //        Running.showhex[1]=SEGHexBLK;
  35.    //        Running.showhex[2]=SEGHexBLK;
  36.    //        Running.showhex[3]=SEGHexBLK;
  37.            //InitEPwm7();         //初始化PWM7外设功能以及GPIO41作为PWM7B引脚输出
  38.            //PWM7BLED.dutyDir = LEDUP;
  39.            EALLOW;
  40.            SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
  41.            EDIS;
  42.    InitEPWM_AQ_DB();
  43.    EALLOW;
  44.    SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
  45.    EDIS;
  46.    PieCtrlRegs.PIECTRL.bit.ENPIE = 1;          // Enable the PIE block
  47.    EINT;                                      // Enable Global interrupt INTM
  48.    ERTM;
  49.            while(1)
  50.     {
  51.                    asm ( " NOP" );
  52.                    /*if(timer0Base.Mark_Para.Status_Bits.OnemsdFlag == 1)
  53.                                {
  54.                                        timer0Base.Mark_Para.Status_Bits.OnemsdFlag = 0;
  55.                                            if(timer0Base.msCounter >= 1000)   //ms
  56.                                            {
  57.                                                    timer0Base.msCounter = 0;
  58.                                                    if(k >= 400)
  59.                                                             {
  60.        k = 0;
  61.                                                              }
  62.                                                              EPwm1Regs.CMPA.half.CMPA = TonC[k];
  63.                                                              EPwm1Regs.CMPB = TonC[k];
  64.                                                              k++;
  65.                        // AdcRegs.ADCSOCFRC1.all = 0X000F; //软件触发AD 的 SOC0--SOC3采样
  66.                        //ChangePWMDutyCycle();//改变占空比,进而改变PWM输出,控制D400
  67.                     // EPwm1Regs.CMPA.half.CMPA = 500;
  68.                     // EPwm2Regs.CMPA.half.CMPA = 500;
  69.                     // EPwm3Regs.CMPA.half.CMPA = 500;
  70.                                            }
  71.                                  }
  72.                    //SegScanTask(&Running);  //数码管、三色LED、按键操作函数------关键函数
  73.                    //handleScanKeyforPWM_LED(&Running);//PWM例程的扫描按键处理函数
  74.     }*/
  75. }
  76. }
  77. /*void InitLED()
  78. {
  79.         EALLOW;
  80.         D400MUX = 0;   //GPIO功能
  81.         D400DIR = 1;   //输出
  82.         D401MUX = 0;
  83.         D401DIR = 1;
  84.         D402MUX = 0;
  85.         D402DIR = 1;
  86.         RGB_R_MUX = 0;
  87.         RGB_R_DIR = 1;
  88.         RGB_G_MUX = 0;
  89.         RGB_G_DIR = 1;
  90.         RGB_B_MUX = 0;
  91.     RGB_B_DIR = 1;
  92.     EDIS;
  93. }*/
全部资料51hei下载地址:
chengxu.zip (467.23 KB, 下载次数: 81)
收藏收藏4 分享淘帖 顶1 踩
ID:460245 发表于 2019-1-2 16:58 | 只看该作者
看下,好资料
ID:555525 发表于 2019-6-5 12:30 来自触屏版 | 只看该作者
学习,,,,,
ID:430284 发表于 2020-5-19 01:46 | 只看该作者
很少来这里。 没空玩单片机了
