查看: 1251|回复: 0
auidno示例代码LED hello world
ID:415637 发表于 2018-10-26 09:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//**************************************************************////  Name    : shiftOutCode, Hello World                                //  Author  : Carlyn Maw,Tom Igoe, David A. Mellis //  Date    : 25 Oct, 2006    //  Modified: 23 Mar 2010                                 //  Version : 2.0                                             //  Notes   : Code for using a 74HC595 Shift Register           ////          : to count from 0 to 255                           //****************************************************************//Pin connected to ST_CP of 74HC595int latchPin = 8;//Pin connected to SH_CP of 74HC595int clockPin = 12;////Pin connected to DS of 74HC595int dataPin = 11;void setup() {  //set pins to output so you can control the shift register  pinMode(latchPin, OUTPUT);  pinMode(clockPin, OUTPUT);  pinMode(dataPin, OUTPUT);}void loop() {  // count from 0 to 255 and display the number   // on the LEDs  for (int numberToDisplay = 0; numberToDisplay < 256; numberToDisplay++) {    // take the latchPin low so     // the LEDs don't change while you're sending in bits:    digitalWrite(latchPin, LOW);    // shift out the bits:    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay);      //take the latch pin high so the LEDs will light up:    digitalWrite(latchPin, HIGH);    // pause before next value:    delay(500);  }}
