查看: 4275|回复: 0
51单片机矩阵键盘控制1602液晶
ID:416228 发表于 2018-10-27 11:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
测试可以使用,矩阵键盘和1602液晶显示
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar code kaxuns[] = "this is a joky";
  5. uchar code tels[] = "0755-86003600";
  6. uchar code nums[] = "0123456789";
  7. sbit leden = P3^4;
  8. sbit ledrs = P3^5;
  9. sbit key = P3^6;
  10. sbit d1 = P1^0;
  11. sbit d2 = P1^1;
  12. sbit d3 = P1^2;
  13. sbit d4 = P1^3;
  14. sbit d5 = P1^4;
  15. sbit d6 = P1^5;
  16. sbit d7 = P1^6;
  17. sbit d8 = P1^7;
  18. sbit dula = P2^6;
  19. sbit wela = P2^7;
  20. void delay(uint z)
  21. {
  22.         uint x,y;
  23.         for(x = z; x > 0; x--)
  24.                 for(y = 110; y > 0; y--);
  25. }
  26. void write_com(uchar com)//发命令
  27. {
  28.         //rs=L,rw=L.D0-D7指令码,E=高脉冲;
  29.         ledrs = 0;
  30.         P0 = com;
  31.         delay(5);
  32.         leden = 1;
  33.         delay(5);
  34.         leden = 0;
  35. }
  36. void write_data(uchar date)//写数据
  37. {
  38.         //rs=L,rw=L.D0-D7指令码,E=高脉冲;
  39.         ledrs = 1;
  40.         P0 = date;
  41.         delay(5);
  42.         leden = 1;
  43.         delay(5);
  44.         leden = 0;
  45. }
  46. void call()
  47. {
  48.         uint test1 = P3 & 0x0F;
  49.         uint test,test2;
  50.         if(test1 < 0x0F)//有键按下
  51.         {
  52.                 delay(10);
  53.                 test1 = P3 & 0x0F;
  54.                 if(test1 < 0x0F)//消抖后再测一次
  55.                 {
  56.                         P3 = 0xF0;
  57.                         delay(5);
  58.                         test2 = P3 & 0xF0;
  59.                         if(test2 < 0xF0)
  60.                         {
  61.                                 test = test1 + test2;
  62.                                 switch(test)
  63.                                 {
  64.                                         case 0xEE:
  65.                                                 d1 = 0;
  66.                                                 break;
  67.                                         case 0xED:
  68.                                                 d2 = 0;
  69.                                                 break;
  70.                                         case 0xEB:
  71.                                                 d3 = 0;
  72.                                                 break;
  73.                                         case 0xE7:
  74.                                                 d4 = 0;
  75.                                                 break;
  76.                                         case 0xDE:
  77.                                                 d5 = 0;
  78.                                                 break;
  79.                                         case 0xDD:
  80.                                                 d6 = 0;
  81.                                                 break;
  82.                                         case 0xDB:
  83.                                                 d7 = 0;
  84.                                                 break;
  85.                                         case 0xD7:
  86.                                                 d8 = 0;
  87.                                                 break;
  88.                                         case 0xBE:
  89.                                                 d1 = 0;
  90.                                                 break;
  91.                                         case 0xBD:
  92.                                                 d2 = 0;
  93.                                                 break;
  94.                                         case 0xBB:
  95.                                                 d3 = 0;
  96.                                                 break;
  97.                                         case 0xB7:
  98.                                                 d4 = 0;
  99.                                                 break;
  100.                                         case 0x7E:
  101.                                                 d5 = 0;
  102.                                                 break;
  103.                                         case 0x7D:
  104.                                                 d6 = 0;
  105.                                                 break;
  106.                                         case 0x7B:
  107.                                                 d7 = 0;
  108.                                                 break;
  109.                                         case 0x77:
  110.                                                 d8 = 0;
  111.                                                 break;
  112.                                 }
  113.                                 while(P3 != 0xF0);
  114.                         }
  115.                 }
  116.                 delay(100);
  117.                 P3 = 0x0F;
  118.                 P1 = 0xFF;
  119.         }
  120. }
  121. void init()
  122. {
  123.         uint ii;
  124.         dula = 0;//关断数码管
  125.         wela = 0;
  126.         leden = 0;
  127.         write_com(0x38);//初始化
  128.         write_com(0x0f);//光标显示
  129.         write_com(0x06);//地址自动加一
  130.         write_com(0x01);//清屏
  131.         //write_com(0x18);//整屏左移
  132.         //write_com(0x19);//整屏右移
  133.         write_com(0x81);//指针位置初始化
  134.         for(ii = 0; ii < 14; ii++)
  135.         {
  136.                 write_data(kaxuns[ii]);
  137.                 delay(20);
  138.         }
  139.         write_com(0xC2);//指针位置初始化
  140.         for(ii = 0; ii < 13; ii++)
  141.         {
  142.                 write_data(tels[ii]);
  143.                 delay(20);
  144.         }
  145. }
  146. void main()
  147. {
  148.         init();
  149.         write_com(0xC0);
  150.         P3 = 0x0F;
  151.         P1 = 0x00;
  152.         while(1)
  153.         {
  154.                 call();
  155.         }
  156. }
