查看: 4636|回复: 0
STM32多通道采集程序源码(12通道ADC_DMA)
ID:417400 发表于 2018-10-29 17:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是一个STM32加DMA多通道采集程序,需要的同学可以在此下载!提供给需要帮助的人
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "adc.h"
  7. extern __IO uint16_t ADC1ConvertedValue[10][12];
  8. __IO uint32_t ADC1ConvertedVoltage[12];
  9. int main(void)
  10. {
  11.     u8 i;
  12.         u8 j;
  13.         u8 k;
  14.         float temp[12];
  15.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
  16.         delay_init();    //初始化延时函数
  17.         uart_init(115200);        //初始化串口波特率为115200
  18.         LED_Init();                                        //初始化LED
  19.          LCD_Init();         //初始化LCD接口
  20.         Adc_Init();         //初始化ADC
  21.         POINT_COLOR=RED;
  22.
  23.         LCD_ShowString(200,70,200,16,24,"UESTC");
  24.
  25.         POINT_COLOR=BLUE;//设置字体为蓝色
  26.         LCD_ShowString(160,130,200,16,16,"ADC1_CH00_VAL:");
  27.         LCD_ShowString(160,150,200,16,16,"ADC1_CH00_VOL:0.000V");        //先在固定位置显示小数点
  28.     LCD_ShowString(160,170,200,16,16,"ADC1_CH01_VAL:");
  29.         LCD_ShowString(160,190,200,16,16,"ADC1_CH01_VOL:0.000V");        //先在固定位置显示小数点
  30.
  31.         LCD_ShowString(160,210,200,16,16,"ADC1_CH02_VAL:");
  32.         LCD_ShowString(160,230,200,16,16,"ADC1_CH02_VOL:0.000V");        //先在固定位置显示小数点
  33.     LCD_ShowString(160,250,200,16,16,"ADC1_CH03_VAL:");
  34.         LCD_ShowString(160,270,200,16,16,"ADC1_CH03_VOL:0.000V");        //先在固定位置显示小数点
  35.
  36.         LCD_ShowString(160,290,200,16,16,"ADC1_CH04_VAL:");
  37.         LCD_ShowString(160,310,200,16,16,"ADC1_CH04_VOL:0.000V");        //先在固定位置显示小数点
  38.     LCD_ShowString(160,330,200,16,16,"ADC1_CH05_VAL:");
  39.         LCD_ShowString(160,350,200,16,16,"ADC1_CH05_VOL:0.000V");        //先在固定位置显示小数点
  40.
  41.         LCD_ShowString(160,370,200,16,16,"ADC1_CH06_VAL:");
  42.         LCD_ShowString(160,390,200,16,16,"ADC1_CH06_VOL:0.000V");        //先在固定位置显示小数点
  43.     LCD_ShowString(160,410,200,16,16,"ADC1_CH07_VAL:");
  44.         LCD_ShowString(160,430,200,16,16,"ADC1_CH07_VOL:0.000V");        //先在固定位置显示小数点
  45.
  46.         LCD_ShowString(160,450,200,16,16,"ADC1_CH09_VAL:");
  47.         LCD_ShowString(160,470,200,16,16,"ADC1_CH09_VOL:0.000V");        //先在固定位置显示小数点
  48.     LCD_ShowString(160,490,200,16,16,"ADC1_CH10_VAL:");
  49.         LCD_ShowString(160,510,200,16,16,"ADC1_CH10_VOL:0.000V");        //先在固定位置显示小数点
  50.
  51.         LCD_ShowString(160,530,200,16,16,"ADC1_CH11_VAL:");
  52.         LCD_ShowString(160,550,200,16,16,"ADC1_CH11_VOL:0.000V");        //先在固定位置显示小数点
  53.     LCD_ShowString(160,570,200,16,16,"ADC1_CH12_VAL:");
  54.         LCD_ShowString(160,590,200,16,16,"ADC1_CH12_VOL:0.000V");        //先在固定位置显示小数点
  55.         while(1)
  56.         {
  57.
  58.                 ADC1ConvertedVoltage[0] = 0;
  59.
  60.
  61.         for(i=0;i<12;i++)
  62.         {
  63.                         ADC1ConvertedVoltage[i] = 0;
  64.                         for(j=0;j<10;j++)
  65.                         {
  66.             ADC1ConvertedVoltage[i]+= ADC1ConvertedValue[j][i];
  67.
  68.             };
  69.                         ADC1ConvertedVoltage[i] = ADC1ConvertedVoltage[i]/10;
  70.             };
  71.
  72.                 for(k=0;k<12;k++)
  73.                 {
  74.         temp[k] = ADC1ConvertedVoltage[k]*3.3/4096;
  75.
  76.
  77.                 LCD_ShowxNum(272,130+40*k,ADC1ConvertedVoltage[k],4,16,0);    //显示ADCC采样后的原始值
  78.                 i=temp[k];                            //赋值整数部分给adcx变量,因为adcx为u16整形
  79.                 LCD_ShowxNum(272,150+40*k,i,1,16,0);    //显示电压值的整数部分,3.1111的话,这里就是显示3
  80.                 temp[k]-=i;                           //把已经显示的整数部分去掉,留下小数部分,比如3.1111-3=0.1111
  81.                 temp[k]*=1000;                           //小数部分乘以1000,例如:0.1111就转换为111.1,相当于保留三位小数。
  82.                 LCD_ShowxNum(288,150+40*k,temp[k],3,16,0X80); //显示小数部分(前面转换为了整形显示),这里显示的就是111.
  83.
  84.                 };
  85.                 /*LCD_ShowxNum(264,170,ADC1ConvertedVoltage[1],4,16,0);    //显示ADCC采样后的原始值
  86.                 i=temp2;                            //赋值整数部分给adcx变量,因为adcx为u16整形
  87.                 LCD_ShowxNum(264,190,i,1,16,0);    //显示电压值的整数部分,3.1111的话,这里就是显示3
  88.                 temp2-=i;                           //把已经显示的整数部分去掉,留下小数部分,比如3.1111-3=0.1111
  89.                 temp2*=1000;                           //小数部分乘以1000,例如:0.1111就转换为111.1,相当于保留三位小数。
  90.                 LCD_ShowxNum(280,190,temp2,3,16,0X80); //显示小数部分(前面转换为了整形显示),这里显示的就是111.
  91.         */
  92.                 LED0=!LED0;
  93.                 delay_ms(1000);
  94.         }
  95. }
12通道ADC_DMA -.rar (356.54 KB, 下载次数: 110)
