查看: 4184|回复: 3
单片机推箱子程序 LCD12864液晶显示
ID:33449 发表于 2018-11-3 10:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
单片机推箱子源程序如下:
  1. #include<reg52.h>
  2. #include<stdlib.h>
  3. #include<stdio.h>
  4. #include<intrins.h>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7.
  8. sbit RS = P1^0;
  9. sbit RW = P1^1;
  10. sbit EN = P1^2;
  11. sbit psb=P1^3;
  12. sbit rst=P1^5;
  13.
  14. sbit key_up = P2^1;
  15. sbit key_down = P2^2;
  16. sbit key_left = P2^0;
  17. sbit key_right = P2^3;
  18.
  19. #define LCD_data P0
  20. int cur_x,cur_y,X,dir[4][2]={-1,0,1,0,0,-1,0,1},where[3][2]={4,6,5,6,6,6};
  21.
  22.
  23. uchar code table1[]="LCD12864";
  24. uchar code table2[]="推箱子";
  25. uchar code table3[]="BY laoda";
  26. uchar code table4[]="You Win!";
  27.
  28. uchar code tmp[]={//空格
  29. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
  30. };
  31. /* 0表示空格,1表示墙,2表示人,3表示箱子,4表示目的地 */
  32. uchar code mat[8][8]={
  33. 1,1,1,1,1,1,1,1,
  34. 1,1,1,1,0,2,1,1,
  35. 1,1,0,0,3,0,1,1,
  36. 1,1,0,1,0,1,1,1,
  37. 1,0,0,1,0,1,4,1,
  38. 1,0,1,0,0,3,4,1,
  39. 1,0,3,0,0,0,4,1,
  40. 1,1,1,1,1,1,1,1
  41. };
  42.
  43. uchar map[8][8];
  44.
  45. uchar code Qiang[]={//方格,有间隙
  46. 0xff,0x81,0x81,0x81,0x81,0x81,0x81,0xff
  47. };
  48.
  49. uchar code Ren[]={//人
  50. 0xff,0xff,0xe3,0xc5,0xb1,0xc5,0xe3,0xff
  51. };
  52.
  53. uchar code Xiang[]={//箱子
  54. 0xff,0x42,0x24,0x18,0x18,0x24,0x42,0xff
  55. };
  56.
  57. uchar code Mudi[]={//目的地
  58. 0xff,0xff,0xe7,0x81,0x81,0xe7,0xff,0xff
  59. };
  60.
  61. void delay(uint i) //延时函数
  62. {
  63.     while(--i);
  64. }
  65.
  66. void read_busy()//读忙函数。每次读写都要进行读忙操作
  67. {
  68.     RS=0;
  69.     RW=1;
  70.     EN=1;
  71.     while(LCD_data & 0x80);//最高位为BF位 DB7---BF
  72.     EN=0;
  73. }
  74.
  75. void write_LCD_command(uchar value)//写指令函数
  76. {
  77.     read_busy();
  78.     RS=0;
  79.     RW=0;
  80.     EN=1;       //EN从1---0锁存数据
  81.     LCD_data=value;
  82.     delay(20);
  83.     EN=0;
  84. }
  85.
  86. void write_LCD_data(uchar value)//写数据函数
  87. {
  88.     read_busy();
  89.     RS=1;
  90.     RW=0;
  91.     EN=1;       //EN从1---0锁存数据
  92.     LCD_data=value;
  93.     delay(20);
  94.     EN=0;
  95. }
  96. void init_BMP()
  97. {
  98.     write_LCD_command(0x36);//CL=1--8位。扩充指令(RE=1),绘图打开(G=1)
  99.     delay(100); //适当延时
  100.     write_LCD_command(0x36);
  101.     delay(37);
  102.     write_LCD_command(0x3E);//8位(CL=1),扩充指令(RE=1),绘图打开(G=1)
  103.     delay(100);
  104.     write_LCD_command(0x01);//清屏指令
  105.     delay(100);
  106. }
  107.
  108. void init_Hanzi()               //8位并口方式LCD1864初始化函数
  109. {
  110.     delay(4000);            //等待时间>40ms
  111.     write_LCD_command(0x30);//功能设定:8位数据、基本指令操作
  112.     delay(100);             //等待时间>100us
  113.     write_LCD_command(0x30);//功能设定:8位数据、基本指令操作
  114.     delay(37);              //等待时间>37us
  115.     write_LCD_command(0x0C);//显示设定:整体显示、游标关、不反白
  116.     delay(100);             // 等待时间>100us
  117.     //write_LCD_command(0x01);//清屏指令
  118.     //delay(10000);         //等待时间>10ms
  119.     write_LCD_command(0x06);//进入点设定:地址指针加1
  120. }
  121.
  122. void display_BMP(uchar fuck,uchar name1,uchar name2,uchar y,uchar x)
  123. {
  124.     uchar shit,i;
  125.     if(fuck==0)shit=0x80;
  126.     else shit=0x88;
  127.     for(i=0;i<8;i++)
  128.     {
  129.         write_LCD_command(0x80+i+8*x);//先送垂直地址
  130.         write_LCD_command(shit+y);  //再送水平地址 ----显示图片的上半部分
  131.
  132.         if(name1==0)    write_LCD_data(tmp[i]);
  133.         else if(name1==1)   write_LCD_data(Qiang[i]);
  134.         else if(name1==2)   write_LCD_data(Ren[i]);
  135.         else if(name1==3)   write_LCD_data(Xiang[i]);
  136.         else if(name1==4)   write_LCD_data(Mudi[i]);
  137.
  138.         if(name2==0)    write_LCD_data(tmp[i]);
  139.         else if(name2==1)   write_LCD_data(Qiang[i]);
  140.         else if(name2==2)   write_LCD_data(Ren[i]);
  141.         else if(name2==3)   write_LCD_data(Xiang[i]);
  142.         else if(name2==4)   write_LCD_data(Mudi[i]);
  143.     }
  144. }
  145.
  146. void show_map(){
  147.     uchar i,j,x,y;
  148.
  149.     for(i=0;i<2;i++){
  150.         for(j=0;j<4;j++){
  151.             x=2*i; y=2*j;
  152.             display_BMP(0,map[x][y],map[x][y+1],j,2*i);
  153.             x=2*i+1; y=2*j;
  154.             display_BMP(0,map[x][y],map[x][y+1],j,2*i+1);
  155.         }
  156.     }
  157.
  158.     for(i=2;i<4;i++){
  159.         for(j=0;j<4;j++){
  160.             x=2*i; y=2*j;
  161.             display_BMP(1,map[x][y],map[x][y+1],j,2*(i-2));
  162.             x=2*i+1; y=2*j;
  163.             display_BMP(1,map[x][y],map[x][y+1],j,2*(i-2)+1);
  164.         }
  165.     }
  166.
  167.     init_Hanzi();
  168.     write_LCD_command(0x80+4);
  169.     for(i=0;i<8;i++)
  170.     {
  171.         write_LCD_data(table1[i]);
  172.     }
  173.     write_LCD_command(0x90+4);
  174.     for(i=0;i<8;i++)
  175.     {
  176.         write_LCD_data(table2[i]);
  177.     }
  178.
  179.     write_LCD_command(0x88+4);
  180.     for(i=0;i<8;i++)
  181.     {
  182.         write_LCD_data(table3[i]);
  183.     }
  184.     delay(100);
  185. }
  186.
  187. void clear()//图形模式下,没有清屏函数,手动全部送0
  188. {
  189.     uchar i,j;
  190.     for(i=0;i<32;i++){
  191.         write_LCD_command(0x80+i);//先送垂直地址
  192.         write_LCD_command(0x80);  //再送水平地址 ----显示图片的上半部分
  193.         for(j=0;j<16;j++)write_LCD_data(0);
  194.     }
  195.     for(i=0;i<32;i++){
  196.         write_LCD_command(0x80+i);  //先送垂直地址
  197.         write_LCD_command(0x88);    //显示图片的下半部分
  198.         for(j=0;j<16;j++)write_LCD_data(0);
  199.     }
  200. }
  201.
  202. uchar judge(int x,int y,int id){                            //id 表示方向数组的行标,0,1,2,3 分别表示上下左右
  203.     int xx,yy,xxx,yyy;
  204.     xx=x+dir[id][0]; yy=y+dir[id][1];
  205.     if(map[xx][yy]==0 || map[xx][yy]==4)return 1;              //1表示前面是 空格 或者 目的地,就是可以直接移动
  206.     else if(map[xx][yy]==1)return 0;                           //0表示无法移动
  207.     else if(map[xx][yy]==3){
  208.         xxx=xx+dir[id][0]; yyy=yy+dir[id][1];
  209.         if(map[xxx][yyy]==1 || map[xxx][yyy]==3)return 0;
  210.         else if(map[xxx][yyy]==0 || map[xxx][yyy]==4)return 2; //2表示需要间接移动,先把前面的箱子移动一,再让人移动一
  211.     }return 0;
  212. }
  213.
  214. void update(uchar a,uchar b){
  215.     uchar i,j,x,y;
  216.
  217.     write_LCD_command(0x3E);//8位(CL=1),扩充指令(RE=1),绘图打开(G=1)
  218.     delay(100);
  219.
  220.     if(a<4){
  221.         i=a/2; j=b/2;
  222.         x=2*i; y=2*j;
  223.         display_BMP(0,map[x][y],map[x][y+1],j,2*i);
  224.         x=2*i+1; y=2*j;
  225.         display_BMP(0,map[x][y],map[x][y+1],j,2*i+1);
  226.     }
  227.     else {
  228.         i=a/2; j=b/2;
  229.         x=2*i; y=2*j;
  230.         display_BMP(1,map[x][y],map[x][y+1],j,2*(i-2));
  231.         x=2*i+1; y=2*j;
  232.         display_BMP(1,map[x][y],map[x][y+1],j,2*(i-2)+1);
  233.     }
  234. }
  235.
  236. void fun(uchar key,uchar dirction){
  237.     uchar x,y;
  238.     /* 0表示空格,1表示墙,2表示人,3表示箱子,4表示目的地 */
  239.     if(key==1){//直接移动
  240.         if(mat[cur_x][cur_y]==4)map[cur_x][cur_y]=4;
  241.         else map[cur_x][cur_y]=0;
  242.         update(cur_x,cur_y);
  243.
  244.         cur_x+=dir[dirction][0]; cur_y+=dir[dirction][1];
  245.         map[cur_x][cur_y]=2;
  246.         update(cur_x,cur_y);
  247.
  248.     }
  249.     else if(key==2){//间接移动
  250.         if(mat[cur_x][cur_y]==4)map[cur_x][cur_y]=4;
  251.         else map[cur_x][cur_y]=0;
  252.         update(cur_x,cur_y);
  253.
  254.         cur_x+=dir[dirction][0]; cur_y+=dir[dirction][1];
  255.         map[cur_x][cur_y]=2;
  256.         update(cur_x,cur_y);
  257.
  258.         x=cur_x+dir[dirction][0]; y=cur_y+dir[dirction][1];
  259.         map[x][y]=3;
  260.         update(x,y);
  261.     }
  262. }
  263.
  264. void lcd_init(){
  265.     uchar i,j;
  266.
  267.     init_BMP();
  268.
  269.     cur_x=1; cur_y=5;
  270.     X=3;
  271.
  272.     for(i=0;i<8;i++){
  273.         for(j=0;j<8;j++)map[i][j]=mat[i][j];
  274.     }
  275. }
  276.
  277. void main()
  278. {
  279.     uchar i,num,index=6;
  280.     lcd_init();
  281.     clear();
  282.     show_map();
  283.         psb=1;
  284.         rst=1;
  285.
  286.     /* 0表示空格,1表示墙,2表示人,3表示箱子,4表示目的地 */
  287.     while(1){
  288.         num=0;
  289.         for(i=0;i<3;i++){
  290.             if(map[ where[i][0] ][ where[0][1] ]==3)num++;
  291.             else break;
  292.         }
  293.         if(num==X)goto WIN;
  294.         if(key_up==0){
  295.             delay(500);
  296.             if(key_up==0){
  297.                 index=judge(cur_x,cur_y,0);
  298.                 fun(index,0);
  299.             }while(!key_up);
  300.         }
  301.         else if(key_down==0){
  302.             delay(500);
  303.             if(key_down==0){
  304.                 index=judge(cur_x,cur_y,1);
  305.                 fun(index,1);
  306.             }while(!key_down);
  307.         }
  308.         else if(key_left==0){
  309.             delay(500);
  310.             if(key_left==0){
  311.                 index=judge(cur_x,cur_y,2);
  312.                 fun(index,2);
  313.             }while(!key_left);
  314.         }
  315.         else if(key_right==0){
  316.             delay(500);
  317.             if(key_right==0){
  318.                 index=judge(cur_x,cur_y,3);
  319.                 fun(index,3);
  320.             }while(!key_right);
  321.         }
  322.     }
  323. WIN:
  324.     init_Hanzi();
  325.
  326.     write_LCD_command(0x98+4);
  327.     for(i=0;i<8;i++)
  328.     {
  329.         write_LCD_data(table4[i]);
  330.     }
  331.     delay(1000);
  332.     while(1);
  333. }
全部资料51hei下载地址:
推箱子.rar (31 KB, 下载次数: 116)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:397663 发表于 2018-11-5 18:25 | 只看该作者
好东西,谢楼主分享
ID:517444 发表于 2019-5-26 19:21 | 只看该作者
真牛逼
ID:608600 发表于 2020-7-4 15:02 | 只看该作者
感谢楼主好人一生平安
