查看: 1894|回复: 0
51单个超声波测距源码+串口发送到上位
ID:416059 发表于 2018-11-3 21:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include <intrins.h>
#include<stdio.h>
sbit rs=P3^5; //1602Ö¸áîÑ¡×Å¿ØÖÆ
sbit rw=P3^6; //1602¶áD′¿ØÖÆ
sbit en=P3^4; //1602ê1Äü¿ØÖÆ
sbit trig1=P1^0; //3¬éù1·¢
sbit echo1=P3^2; //3¬éù1½ó
sbit led1=P1^7;
uchar ii,shuju;
bit flag1;  //′¥·¢±êÖ¾
uchar count,count1;
long int distance,distance1;
unsigned char code table[ ]={"0123456789"}; //1206ÏÔê¾×Ö·û¶¨òå
void delay(uint n)     //Ñóê±oˉêy1
    uint x,y;
    for(x=n;x>0;x--)
    for(y=110;y>0;y--);
void delayt(uint x) //Ñóê±oˉ2
    uchar j;
    while(x-- > 0)
              for(j = 0;j < 125;j++)
void lcd_wcom(uchar com)   //1206D′Ãüáî
    rs=0;
    rw=0;
    P0=com;
    delay(5);
    en=1;
    en=0;
void lcd_wdat(uchar dat)   //1206D′êy¾Y
    rs=1;
    rw=0;
    P0=dat;
    delay(5);
    en=1;
    en=0;
void lcd_init()        //12063õê¼
    lcd_wcom(0x38);
    lcd_wcom(0x0c);
    lcd_wcom(0x06);
    lcd_wcom(0x01);  //ÇåÆá
void lcd_xianshi()       //LCDÏÔê¾
                                lcd_wcom(0x80+0x40);
        lcd_wdat('J');
        lcd_wdat('u');
                                lcd_wdat(' ');
        lcd_wdat('L');
        lcd_wdat('i');
                                lcd_wdat(' ');
        lcd_wdat('L');
        lcd_wdat(':');
        lcd_wcom(0x80+0x4c);
        lcd_wdat('.');
        lcd_wcom(0x80+0x4e);
        lcd_wdat('c');
        lcd_wdat('m');
void init_t0()   //¶¨ê±Æ÷3õê¼
                        TMOD=0x21;
                        TL0=0x66;
                        TH0=0xfc;
                        ET0=1;
                        //TMOD=0X20;
                  //SCON=0x50;
                        //TCON=0x40;
                        //PCON=0x80;
                        TH1=0xfD;
                        TL1=0xfD;
                        SM0=0;
                        SM1=1;
                        REN=1;
                        TR1=1;
                        ES=1;
                        EA=1;
                        TI=1;
void trigger()    //3¬éù·¢
                        trig1=0;
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
                  _nop_();
      trig1=1;
void init_measuring()//3¬éù¶Ë¿ú3õê¼
        trig1=1;
        echo1=1;
        count=0;
void measuring()  //¾ààë2aêÔ
        uchar l;
        uint h,y;
        TR0 = 1;
        while(echo1==1)
        TR0 = 0;
        l = TL0;
        h = TH0;
        y = (h << 8) + l;
        y = y - 0xfc66;
        distance = y + 1000 * count;
        TL0 = 0x66;
        TH0 = 0xfc;
        delayt(20);//Ô-30
        distance = 3453* distance / 20000;
void display(uint x) //ÏÔê¾¼ÆËã
        uchar qian,bai,shi,ge;
        qian=x/1000;
        bai=(x/100)%10;
        shi=(x/10)%10;
        ge=x%10;
        lcd_wcom(0x80+0x49);
        lcd_wdat(table[qian]);
        lcd_wdat(table[bai]);
        lcd_wdat(table[shi]);
        lcd_wcom(0x80+0x4d);
        lcd_wdat(table[ge]);
void main()     //Ö÷oˉêy
{   lcd_init(); //òo¾§3õê¼
    init_t0();//¶¨ê±Æ÷03õê¼
    init_measuring();  //3¬éù¶Ë¿ú3õê¼
                lcd_xianshi(); //1206×Ô¶¨ÏÔê¾
                trigger();   //3¬éù′¥·¢Æô¶ˉ
                 while(echo1==0)
                                                measuring();
            display(distance);        //ÏÔê¾
            //delayt(1);  //¼ä¸ô600ms
                                                SBUF= 60;
                                        while(!TI);
                                                TI=0;
                                   SBUF= distance/1000%10+48;
                                        while(!TI);
                                                TI=0;
                                        SBUF= distance/100%10+48;
                                        while(!TI);
                                                TI=0;
                                        SBUF= distance/10%10+48;
                                        while(!TI);
                                                TI=0;
                                        SBUF= distance%10+48;
                                                while(!TI);
                                                TI=0;
                                        SBUF= 62;
                                        while(!TI);
                                                TI=0;
                                        //SBUF=10;
                                //        while(!TI);
                                        //        TI=0;
void T_0()interrupt 1
        TF0 = 0;
        TL0 = 0x66;
        TH0 = 0xfc;
        count++;
        if(count==18)
          TR0 =0;
          TL0 = 0x66;
          TH0 = 0xfc;
          count = 0;
