查看: 2260|回复: 2
我做一个单片机定时器1的中断矩阵按键的实验,但是没有结果显示,求大佬帮忙。
ID:383038 发表于 2018-11-9 09:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg51.h"
#define GPIO_KEY P1
typedef unsigned int u16;
typedef unsigned char u8;
u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                    0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
u8 KeyDown(void)
    u8 KeyValue = 0;
    if(GPIO_KEY!=0x0f)
        GPIO_KEY=0X0F;
        switch(GPIO_KEY)
            case(0X07):    KeyValue=0;break;
            case(0X0b):    KeyValue=1;break;
            case(0X0d): KeyValue=2;break;
            case(0X0e):    KeyValue=3;break;
        GPIO_KEY = 0xf0;
        switch(GPIO_KEY)
            case(0X70):    KeyValue=KeyValue;break;
            case(0Xb0):    KeyValue=KeyValue+4;break;
            case(0Xd0): KeyValue=KeyValue+8;break;
            case(0Xe0):    KeyValue=KeyValue+12;break;
        while(GPIO_KEY!=0xf0)
    return KeyValue;
void timer1Init(void)
    TMOD |= 0x10;
    TH1 = 0xff;
    TL1 = 0xff;
    TR1 = 1;
    ET1 = 1;
    EA = 1;
void timer1() interrupt 3 using 3
    static u16 i = 0;
    static u8 key = 0;
    TH1 = 0xff;
    TL1 = 0xff;
    GPIO_KEY = 0x0f;
    if (GPIO_KEY != 0x0f)
        i++;
        if (i >= 10000)
            key = KeyDown();
            i = 0;
    P0 =  ~smgduan[key];
int mian(void)
    timer1Init();
    while (1) ;
ID:89515 发表于 2018-11-9 12:31 | 只看该作者
#include "reg51.h"
#define GPIO_KEY P1
u8 KeyDown(void)//注意:只是提供思路
     u8 KeyValueH = 0;
    u8 KeyValueL = 0;
    static u8 state_k;
        GPIO_KEY=0x0f;
     if(GPIO_KEY!=0x0f&&!state_k){state_k=1;return;}//消抖
     if(GPIO_KEY!=0x0f)
         KeyValueH=GPIO_KEY;
         GPIO_KEY = 0xf0;
KeyValueL=GPIO_KEY;
    GPIO_KEY=0xff;
    while(GPIO_KEY!=0xff) ;//可以照着按下消抖的方法自己改
     return  (KeyValueH |KeyValueL);
u8 keyscan()
        switch(KeyDown())
              键值处理……
       return   键值;
     TMOD |= 0x10;
     TH1 =( 65536-20000)/256;
     TL1 =( 65536-20000)%256;
     TR1 = 1;
     ET1 = 1;
     EA = 1;
     static u16 i = 0;
     static u8 key = 0;
     GPIO_KEY = 0x0f;
             key = keyscan();
     P0 =  ~smgduan[key];
int mian(void)
     timer1Init();
     while (1) ;
ID:213173 发表于 2018-11-9 20:34 | 只看该作者
按键扫描程序里有这条语句while(GPIO_KEY!=0xff) 待松手,不适合放在中断中使用。而且65ms中断时间太长,数码管动态扫描玩不转。
