查看: 5245|回复: 2
用24C04与1602LCD设计单片机电子密码锁仿真
电子密码锁仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
  1. //-----------------------------------------------------------------
  2. //原始程序中相邻两位密码不能相同.
  3. //本压缩包中的HEX由修改后的新程序编译生成,允许输入任意密码.
  4. //-----------------------------------------------------------------
  5. //改动的主要是main函数中while循环内的代码.
  6. //-----------------------------------------------------------------
  7. // 主程序
  8. //-----------------------------------------------------------------
  9. void main()
  10. {
  11.    uchar i = 0;
  12.    uchar IIC_Password[10];
  13.    uchar IS_Valid_User = 0;
  14.    P0 = 0xFF;
  15.    P1 = 0xFF;
  16.    P2 = 0xFF;
  17.    TMOD = 0x02;                     //T0设置为8位自动重装模式
  18.    TH0 = 175;
  19.    TL0 = 175;
  20.    TR0 = 1;                         //启动T0
  21.    DelayMS(10);
  22.    LCD_Init();                      //初始化LCD
  23.
  24.    IIC_24C04_Init();                //初始化24C04
  25.
  26.    Display_String(Title_Text,0x00); //在第1行显示标题
  27.
  28.    //24C04的内容已由初始化BIN文件导入
  29.    //将24C04中预先写入的密码读入pass
  30.    RecString(0xa0, 0 , IIC_Password, 6);
  31.    IIC_Password[6] = '\0';
  32.    while(1)
  33.    {
  34.       P1 = 0xF0;
  35.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //扫描键盘获取键序号KeyNo
  36.       switch ( KeyNo )
  37.       {
  38.            case 0:  case 1: case 2: case 3: case 4:
  39.            case 5:  case 6: case 7: case 8: case 9:
  40.
  41.                    if ( i<= 5 )             //密码限制在6位以内
  42.                    {
  43.                         //如果i为0则执行一次清屏
  44.                         if (i ==0) Display_String("                ",0x40);
  45.
  46.                         UserPassword[i] = KeyNo + '0';
  47.                         UserPassword[i+1] = '\0';
  48.
  49.                         DSY_BUFFER[i] = '*';
  50.                         DSY_BUFFER[i+1] = '\0';
  51.
  52.                         Display_String(DSY_BUFFER,0x40);
  53.
  54.                         i++;
  55.                     }
  56.                     break;
  57.
  58.            case 10: //按A键开锁
  59.                     if (strcmp(UserPassword,IIC_Password) == 0)
  60.                     {
  61.                        LED_OPEN = 0;  //点亮LED
  62.                        Clear_Password();
  63.                        Display_String("Unlock OK!      ",0x40);
  64.                        IS_Valid_User = 1;
  65.                     }
  66.                     else
  67.                     {
  68.                        LED_OPEN =1;   //关闭LED
  69.                        Clear_Password();
  70.                        Display_String("ERROR !         ",0x40);
  71.                        IS_Valid_User = 0;
  72.                     }
  73.                     i = 0;
  74.                     break;
  75.
  76.            case 11: //按B键上锁
  77.                     LED_OPEN =1;
  78.                     Clear_Password();
  79.                     Display_String(Title_Text,0x00);
  80.                     Display_String("                ",0x40);
  81.                     i = 0;
  82.                     IS_Valid_User = 0;
  83.                     break;
  84.
  85.            case 12: //按C键设置新密码
  86.                     //如果是合法用户则提示输入新密码
  87.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  88.                     else
  89.                     {
  90.                        i = 0;
  91.                        Display_String("New Password:   ",0x00);
  92.                        Display_String("                ",0x40);
  93.                      }
  94.
  95.                     break;
  96.
  97.            case 13: //按D键保存新密码
  98.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  99.                     else
  100.                     {
  101.                        SendString(0xa0, 0 , UserPassword, 6);
  102.
  103.                        //重新读入刚写的密码
  104.                        RecString(0xa0, 0 , IIC_Password, 6);
  105.                        IIC_Password[6] = '\0';
  106.
  107.                        i = 0;
  108.                        Display_String(Title_Text,0x00);
  109.                        Display_String("Password Saved! ",0x40);
  110.                      }
  111.
  112.                     break;
  113.
  114.            case 14: //按E键消除所有输入
  115.                     i = 0;
  116.                     Clear_Password();
  117.                     Display_String("                ",0x40);
  118.        }
  119.        Beep();
  120.        DelayMS(100);
  121.        P1= 0xF0;
  122.        while (P1 != 0xF0);    //如果有键未释放则等待
  123.        while (P1 == 0xF0);    //如果没有再次按下按键则等待
  124.    }
  125. }
34 用24C04与1602LCD设计电子密码锁.rar (24.48 KB, 下载次数: 100)
收藏收藏1 分享淘帖 顶 踩
ID:465706 发表于 2019-1-10 21:59 来自触屏版 | 只看该作者
几位密码的啊
ID:657857 发表于 2019-12-7 12:32 | 只看该作者
代码不全啊
