查看: 1854|回复: 1
时钟芯片DS12C887程序设计
ID:426640 发表于 2018-11-14 20:35 | 显示全部楼层 |阅读模式
/****头函数,函数的声明*****/
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
sbit beep=P2^3;
sbit dscs=P1^4;
sbit dsas=P1^5;
sbit dsrw=P1^6;
sbit dsds=P1^7;
sbit dsirq=P3^3;
uchar count,s1num,flag,flag1;
char miao,shi,fen;
uchar code table[]="  2007-7-30 MON";
uchar code table1[]="      :  :  ";
void write_ds(uchar,uchar);
void set_alarm(uchar,uchar,uchar);
uchar read_ds(uchar);void set_time();
/******主函数****/
#include<reg52.h>
#include<define.h>
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void didi()
        beep=0;
        delay(50);
        beep=1;
        delay(100);
        beep=0;
        delay(50);
        beep=1;
void write_com(uchar com)
        rs=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        uchar num;
        EA=1;
        EX0=1;
        IT0=1;
        dula=0;
        wela=0;
        lcden=0;
//        set_time();
        set_alarm(7,0,0);
        write_ds(0x0B,0x26);
        read_ds(0x0c);
//        fen=59;
//        miao=53;
//        shi=23;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)
                        write_date(table[num]);
                        delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                        write_date(table1[num]);
                        delay(5);
void write_sfm(uchar add,uchar date)
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void keyscan()
        rd=0;
        if(flag1==1)
                if(s2==0)
                        delay(5);
                        if(s2==0)
                                while(!s2);
                                flag1=0;
                if(s3==0)
                        delay(5);
                        if(s3==0)
                                while(!s3);
                                flag1=0;
        if(s1==0)
                delay(5);
                if(s1==0)
                {        s1num++;
                        flag=1;
                        flag1=0;
                        while(!s1);
                        if(s1num==1)
                                TR0=0;
                                write_com(0x80+0x40+10);
                                write_com(0x0f);
                        if(s1num==2)
                                write_com(0x80+0x40+7);
                        if(s1num==3)
                                write_com(0x80+0x40+4);
                        if(s1num==4)
                                s1num=0;
                                write_com(0x0c);
                                flag=0;
                                write_ds(0,miao);
                                write_ds(2,fen);
                                write_ds(4,shi);
                if(s1num!=0)
                        if(s2==0)
                                delay(1);
                                if(s2==0)
                                        while(!s2);
                                        if(s1num==1)
                                                miao++;
                                                if(miao==60)
                                                        miao=0;
                                                write_sfm(10,miao);
                                        if(s1num==2)
                                                fen++;
                                                if(fen==60)
                                                        fen=0;
                                                write_sfm(7,fen);
                                        if(s1num==3)
                                                shi++;
                                                if(shi==24)
                                                        shi=0;
                                                write_sfm(4,shi);
                        if(s3==0)
                                delay(1);
                                if(s3==0)
                                        while(!s3);
                                        if(s1num==1)
                                        /*        if(miao==0)
                                                        miao=59;
                                                        write_sfm(10,miao);
                                                miao--;
                                                if(miao==-1)
                                                        miao=59;
                                                write_sfm(10,miao);
                                        if(s1num==2)
                                                fen--;
                                                if(fen==-1)
                                                        fen=59;
                                                write_sfm(7,fen);
                                        if(s1num==3)
                                                shi--;
                                                if(shi==-1)
                                                        shi=23;
                                                write_sfm(4,shi);
void write_ds(uchar add,uchar date)
        dscs=0;
        dsas=1;
        dsds=1;
        dsrw=1;
        P0=add;
        dsas=0;
        dsrw=0;
        P0=date;
        dsrw=1;
        dsas=1;
        dscs=1;
uchar read_ds(uchar add)
        uchar ds_date;
        dsas=1;
        dsds=1;
        dsrw=1;
        dscs=0;
        P0=add;
        dsas=0;
        dsds=0;
        P0=0xff;
        ds_date=P0;
        dsds=1;
        dsas=1;
        dscs=1;
        return ds_date;
void set_time()
        write_ds(4,10);
        write_ds(2,32);
void set_alarm(uchar ashi,uchar afen,uchar amiao)
        write_ds(1,amiao);
        write_ds(3,afen);
        write_ds(5,ashi);
        init();
                keyscan();
                if(flag1==1)
                        didi();
                if(flag==0)
                        miao=read_ds(0);
                        fen=read_ds(2);
                        shi=read_ds(4);
                        write_sfm(10,miao);
                        write_sfm(7,fen);
                        write_sfm(4,shi);
void exter() interrupt 0
{        uchar c;
        flag1=1;
        c=read_ds(0x0c);
/****通过时钟芯片和51单片机实现时钟的设计和闹钟的设定,闹钟只能在代码中改,时间显示在液晶显示屏中,可以通过按键调节。具体接口可以再联系我****/
ID:426640 发表于 2018-11-20 00:38 | 显示全部楼层
谢谢管理员审核通过,明天发一个含金量更高的帖子
