查看: 1790|回复: 1
数码管显示时间
8位共阴极数码管显示时间
#include<reg52.h>
uchar aa,shi1,shi0,fen1,fen0,miao1,miao0;
uint temp;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void display(uchar shi1,shi0,fen1,fen0,miao1,miao0);
void delay(uint z);
void init();
        init();//3õê¼»ˉ×ó3ìDò
                if(aa==20)
                        aa=0;
                        temp++;
                        if(temp==86400)
                                        temp=0;
                        shi1=temp/3600/10;
                        shi0=temp/3600-(shi1*10);
                        fen1=temp%3600/60/10;
                        fen0=temp%3600/60-(fen1*10);
                        miao1=temp%3600%60/10;
                        miao0=temp%3600%60-(miao1*10);
                display(shi1,shi0,fen1,fen0,miao1,miao0);
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
              dula=1;
                P0=table[shi1];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfe;
                wela=0;
                delay(1);
                dula=1;
                P0=table[shi0];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfd;
                wela=0;
                delay(1);
                dula=1;
                P0=0x40;//"-"
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfb;
                wela=0;
                delay(1);
                dula=1;
                P0=table[fen1];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xf7;
                wela=0;
                delay(1);
                dula=1;
                P0=table[fen0];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xef;
                wela=0;
                delay(1);
                dula=1;
                P0=0x40;//"-"
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xdf;
                wela=0;
                delay(1);
                dula=1;
                P0=table[miao1];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xbf;
                wela=0;
                delay(1);
                dula=1;
                P0=table[miao0];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0x7f;
                wela=0;
                delay(1);
void init()
        wela=0;
        dula=0;
        temp=41760;
        TMOD=0x01;
        TH0=(65536-46080)/256;
        TL0=(65536-46080)%256;
        EA=1;
        ET0=1;
        TCON=0x10;
         //TR0=1;
void timer0() interrupt 1
        aa++;
ID:428919 发表于 2018-11-18 22:49 | 只看该作者
顶!给力
