查看: 4154|回复: 2
单片机大佬们数码管和点阵怎么同时工作?
大佬们,我是想让数码管显示2018,点阵显示0--9,请大佬们指教我该怎么改正
#include<reg51.h>
#include<intrins.h>
//uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code DSY_CODE[]={0xa4,0xc0,0xf9,0x80};
uchar code wei[]={0x80,0x40,0x20,0x10};
unsigned char const xuehao[]={
0x00,0x00,0xFE,0x82,0x82,0x82,0xFE,0x00, //0
0x00,0x00,0x84,0x82,0xFF,0x80,0x80,0x00, //1
0x00,0x00,0xF2,0x92,0x92,0x92,0x9E,0x00, //2
0x00,0x00,0x92,0x92,0x92,0xFE,0x00,0x00, //3
0x00,0x20,0x30,0x28,0x24,0xFE,0x20,0x00, //4
0x00,0x00,0x9E,0x92,0x92,0x92,0xF2,0x00, //5
0x00,0x00,0xFE,0x92,0x92,0x92,0xF2,0x00, //6
0x00,0x00,0x00,0x02,0x02,0x02,0xFE,0x00, //7
0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00, //8
0x00,0x32,0x49,0x49,0x49,0x3e,0x00,0x00  //9
unsigned char code lie[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
void DelayMS(uint x)
        uchar t;
        while(x--) for(t=0;t<120;t++);
void Timer1Init()
        TMOD|=0X10;//选择为定时器1模式,工作方式1,仅用TR1打开启动。
        TH1=0XFC;        //给定时器赋初值,定时1ms
        TL1=0X18;
        ET1=1;//打开定时器1中断允许
        EA=1;//打开总中断
        TR1=1;//打开定时器
        uchar i;
                        for(i=0;i<4;i++)
                        P3=0x00; //关闭显示
                  P1=DSY_CODE[ i]; //发送数字段码
                        P3=wei[ i];
            DelayMS(10);
              Timer1Init();  //定时器1初始化
void Timer1() interrupt 3
  uchar t,j,k;
        TL1=0X18;
          for(t=0;t<10;t++)
       for(j=0;j<30;j++)
          for(k=0;k<8;k++)
            P2=lie[k];
            P0=~xuehao[t*8+k];
                                                 DelayMS(2);
收藏收藏1 分享淘帖 顶 踩
ID:155507 发表于 2018-11-18 09:45 | 只看该作者
你的程序有缺陷,给你改了一下,你试试。
  1. #include <reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. //uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  6. uchar code DSY_CODE[]={0xa4,0xc0,0xf9,0x80};
  7. uchar code wei[]={0x80,0x40,0x20,0x10};
  8. unsigned char const xuehao[]={
  9.         0x00,0x00,0xFE,0x82,0x82,0x82,0xFE,0x00, //0
  10.         0x00,0x00,0x84,0x82,0xFF,0x80,0x80,0x00, //1
  11.         0x00,0x00,0xF2,0x92,0x92,0x92,0x9E,0x00, //2
  12.         0x00,0x00,0x92,0x92,0x92,0xFE,0x00,0x00, //3
  13.         0x00,0x20,0x30,0x28,0x24,0xFE,0x20,0x00, //4
  14.         0x00,0x00,0x9E,0x92,0x92,0x92,0xF2,0x00, //5
  15.         0x00,0x00,0xFE,0x92,0x92,0x92,0xF2,0x00, //6
  16.         0x00,0x00,0x00,0x02,0x02,0x02,0xFE,0x00, //7
  17.         0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00, //8
  18.         0x00,0x32,0x49,0x49,0x49,0x3e,0x00,0x00  //9
  19. };
  20. unsigned char code lie[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  21. void DelayMS(uint x)
  22. {
  23.         uchar t;
  24.         while(x--) for(t=0;t<120;t++);
  25. }
  26. /*
  27. void Timer1Init()
  28. {
  29.         TMOD|=0X10;//选择为定时器1模式,工作方式1,仅用TR1打开启动。
  30.         TH1=0XFC;        //给定时器赋初值,定时1ms
  31.         TL1=0X18;
  32.         ET1=1;//打开定时器1中断允许
  33.         EA=1;//打开总中断
  34.         TR1=1;//打开定时器
  35. }
  36. */
  37. void main()
  38. {
  39.         uchar i;
  40.         uchar t,j,k;
  41.         //Timer1Init();  //定时器1初始化
  42.         while(1)
  43.         {
  44.                 //for(i=0;i<4;i++)
  45.                 //{
  46.                 //        DelayMS(10);
  47.                 //}
  48.                 for(t=0;t<10;t++)
  49.                 {
  50.                         for(j=0;j<30;j++)
  51.                         {
  52.                                 for(k=0;k<8;k++)
  53.                                 {
  54.                                         P2=lie[k];
  55.                                         P0=~xuehao[t*8+k];
  56.                                         DelayMS(2);
  57.                                         P3=0x00; //关闭显示
  58.                                         P1=DSY_CODE[ k/2]; //发送数字段码
  59.                                         P3=wei[ k/2];
  60.                                 }
  61.                         }
  62.                 }
  63.         }
  64. }
  65. /*
  66. void Timer1() interrupt 3
  67. {
  68.         TH1=0XFC;        //给定时器赋初值,定时1ms
  69.         TL1=0X18;
  70. }
  71. */
ID:252816 发表于 2018-11-18 16:31 | 只看该作者
angmall 发表于 2018-11-18 09:45
你的程序有缺陷,给你改了一下,你试试。
非常感谢师兄,仿真后没有问题
