查看: 3102|回复: 1
spi的程序,用单片机驱动at93c46存储芯片
ID:407780 发表于 2018-11-21 14:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
spi的单片机源程序如下:
  1. #include"reg52.h"
  3. #define uint unsigned int
  4. uchar code s[9]={0x10,0x20,0x30,0x40,0x50,0x60,0x70,0x80,0x90};
  5. sbit cs=P3^4;
  6. sbit ck=P3^5;
  7. sbit di=P3^6;
  8. sbit d0=P3^7;
  9. #define readcode 0x0c
  10. #define writecode 0x0a
  11. void delay1ms()
  12. {
  13.    unsigned char i,j;
  14.   for(i=0;i<10;i++)
  15.    for(j=0;j<33;j++)
  16.     ;
  17. }
  18. /*****************************************************
  19. 函数功能:延时若干毫秒
  20. 入口参数:n
  21. ***************************************************/
  22. void delaynms(unsigned char n)
  23. {
  24.    unsigned char i;
  25. for(i=0;i<n;i++)
  26.     delay1ms();
  27. }
  28. void delay(uchar n)
  29. {
  30. int i;
  31. for(i=0;i<n;i++)
  32. ;
  33. }
  34. void clock(void)
  35. {
  36. ck=0;
  37. delay(2);
  38. ck=1;
  39. delay(2);
  40. }
  41. void send(uchar da_ta)
  42. {
  43. int i;
  44. for(i=0;i<8;i++)
  45. {
  46. di=(bit)(da_ta&0x80);
  47. da_ta<<=1;
  48. clock();
  49. }
  50. }
  51. uchar receive(void)
  52. {
  53. uchar data1=0;
  54. int i;
  55. clock();
  56. for(i=0;i<8;i++)
  57. {
  58. data1*=2;
  59. if(d0)
  60. data1++;
  61. clock();
  62. delay(2);
  63. }
  64. return(data1);
  65. }
  66. uchar readdata(uchar add)
  67. {
  68. uchar read_data;
  69. cs=1;
  70. send(readcode);
  71. send(add);
  72. read_data=receive();
  73. cs=0;
  74. return(read_data);
  75. }
  76. void writedata(uchar add,uchar write_data)
  77. {
  78. cs=1;
  79. send(writecode);
  80. send(add);
  81. send(write_data);
  82. cs=0;
  83. delay(4);
  84. cs=1;
  85. delay(4);
  86. while(!d0);
  87. cs=0;
  88. }
  89. void main()
  90. { int i;
  91. P2=0X00;
  92. while(1)
  93. {
  94. for(i=0;i<9;i++)
  95. {
  96. writedata(0x00+i,s[i]);
  97. P2=readdata(0x00+i);
  98. delaynms(1000);
  99. }
  100. }
  101. }
spi.rar (27.01 KB, 下载次数: 30)
ID:356472 发表于 2018-11-27 21:48 | 只看该作者
你不会是duluchun吧?
