查看: 2030|回复: 0
N76E003 红外解码部分代码
ID:281424 发表于 2018-11-23 15:54 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
UINT8 IR_SCAN(void)
        UINT8 i=0;
        UINT8 t1,t2;
    if(bIR_scan==0) return 0;
         bIR_scan=0;
         RmtRec=0;
        if(IR_IO==0)
                clr_TR0;
                clr_TF0;
                TL0 =0;
                TH0 =0;
                set_TR0; //Start Timer0
                bIR=0;IR_cont=0;
                while ((IR_IO==0)&&(bIR != 1)); //Check Timer0 Time-Out Flag
                        clr_TR0; //Stop Timer0
                        clr_TF0;
                        Dval=TIM0_GetCounter();
                                if(Dval>8600&&Dval<9300) //9ms
                                TL0 =0;
                                TH0 =0;
                                bIR=0;IR_cont=0;
                                while ((IR_IO==1)&&(bIR != 1)); //Check Timer0 Time-Out Flag
                                        clr_TF0;
                                        if(Dval>4200&&Dval<4700) //4.5ms  &&×óóò¶¼ÎaÕæÔòÎaÕæ
                                                        do{
        TL0 =0;
        TH0 =0;
        bIR=0;IR_cont=0;
        clr_TF0;
                                                        if(Dval<300&&Dval>800)        //560us
        return 0;
                                                        TL0 =0;
                                                        TH0 =0;
                                                        bIR=0;IR_cont=0;
        clr_TF0;
        if(Dval>300&&Dval<800)        //560????,560us
        RmtRec<<=1;
        RmtRec|=0;        //½óêÕμ½0
        i++;
        else if(Dval>1400&&Dval<1800)        //1680Îa±ê×¼Ö죬1680uS
        RmtRec<<=1;
        RmtRec|=1;        //½óêÕμ½1
        i++;
        else if(Dval>2200&&Dval<2600)        //μÃμ½°′¼ü¼üÖμÔö¼óμÄDÅÏ¢£¬2500±ê×¼ÖμÎa2.5mS
        while(i<32);
        t1=RmtRec>>24;        //μÃμ½μØÖ·Âë
        t2=(RmtRec>>16)&0xff;        //μÃμ½μØÖ··′Âë
        if((t1==(UINT8)~t2)&&t1==REMOTE_ID)//¼ìÑéò£¿Øê¶±eÂë(ID)¼°μØÖ·
        t1=RmtRec>>8;
        t2=RmtRec;
        IR_code=t1;
        if(t1==(UINT8)~t2)return 1;//¼üÖμÕyè·
      return 0;
