查看: 3417|回复: 0
LCD12864液晶显示汇编语言代码
ID:432270 发表于 2018-11-24 11:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RS     EQU  P3.3
RW     EQU  P3.1
EN     EQU  P3.0
CS1    EQU  P3.5
CS2    EQU  P3.4
DATBUS EQU  P1
COM    EQU  30H
DAT    EQU  31H
OX     EQU  32H
OY     EQU  33H
XPAGE  EQU  34H
CODER  EQU  35H
COUNT  EQU  36H
DOT    EQU  37H
CONT   EQU  38H
START:
MAIN:
MOV   SP,#60H
LCALL DEL_20MS
MOV   P3,#0F8H   ;CS1=H,CS2=H,无关脚置高        LCALL INI
MOV   DPTR,#PIC1
LCALL WPIC
MOV   DPTR,#PIC2
LCALL WPIC
MOV   DPTR,#PIC3
LCALL WPIC
LJMP  MAIN
INI:
MOV   COM,#0C0H
LCALL WC1
LCALL WC2
MOV   COM,#3FH
LCALL WC1
LCALL WC2
RET
WPIC:
MOV   XPAGE,#00H
MOV   R3,#8
WP1:
MOV   A,XPAGE
ORL   A,#0B8H
PUSH  ACC
MOV   COM,A
LCALL WC1
MOV   COM,#40H
LCALL WC1
MOV   R2,#64
WP2:
MOV   A,#00H
MOVC  A,@A+DPTR
MOV   DAT,A
INC   DPTR
LCALL WD1
DJNZ  R2,WP2
POP   ACC
MOV   COM,A
LCALL WC2
MOV   COM,#40H
LCALL WC2
MOV   R2,#64
WP3:
MOV   A,#00H
MOVC  A,@A+DPTR
MOV   DAT,A
INC   DPTR
LCALL WD2
DJNZ  R2,WP3
INC   XPAGE
DJNZ  R3,WP1
LCALL DEL_1500MS
RET
WC1:
CLR   CS1
SETB  CS2
CLR   RS
SETB  RW
WC11:
MOV   P1,#0FFH
JB    ACC.7,WC11        CLR   RW
MOV   P1,COM
SETB  EN
CLR   EN
RET
WC2:
SETB  CS1
CLR   CS2
CLR   RS
SETB  RW
WC21:
MOV   P1,#0FFH        SETB  EN
MOV   A,P1
CLR   EN
JB    ACC.7,WC21        CLR   RW
MOV   P1,COM
SETB  EN
CLR   EN
RET
WD1:
CLR   CS1
SETB  CS2
CLR   RS
SETB  RW
WD11:
MOV   A,P1
CLR   EN
JB    ACC.7,WD11        SETB  RS
CLR   RW
MOV   P1,DAT
SETB  EN
CLR   EN
RET
WD2:
SETB  CS1
CLR   CS2
CLR   RS
SETB  RW
WD21:
MOV   A,P1
CLR   EN
JB    ACC.7,WD21        SETB  RS
CLR   RW
MOV   P1,DAT
SETB  EN
CLR   EN
RET
DEL_20MS:
MOV   R0,#20
D2:
MOV   R1,#200
D1:
NOP
NOP
NOP
RET
DEL_100MS:
LCALL  DEL_20MS
LCALL  DEL_20MS
LCALL  DEL_20MS
LCALL  DEL_20MS
LCALL  DEL_20MS
RET
DEL_500MS:
LCALL  DEL_100MS
LCALL  DEL_100MS
LCALL  DEL_100MS
LCALL  DEL_100MS
LCALL  DEL_100MS
RET
DEL_1500MS:
LCALL  DEL_500MS
LCALL  DEL_500MS
LCALL  DEL_500MS
RET
PIC1: DB  0FFH,0FFH,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H, DB  003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H, DB  003H,003H,083H,083H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H, DB  003H,003H,003H,003H,003H,003H,003H,003H,003H,043H,0C3H,0C3H,003H,003H,003H,003H, DB  003H,003H,003H,083H,083H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H, DB  003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H, DB  003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H, DB  003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,003H,0FFH,0FFH, DB  0FFH,0FFH,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,010H,030H,031H,0A3H,0C3H,040H,00EH,02FH,0B1H,0BDH,0EDH,0E1H,085H, DB  08DH,0D9H,0D3H,083H,001H,000H,000H,000H,000H,000H,000H,000H,040H,060H,0FFH,0FFH, DB  021H,020H,000H,0FEH,0FEH,000H,0FCH,0FCH,000H,000H,0FFH,0FFH,000H,000H,000H,000H, DB  000H,010H,030H,030H,021H,0C3H,0C3H,00AH,01AH,072H,0E2H,0C2H,0F2H,07FH,03FH,007H, DB  000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,03EH,0FEH,0CAH,0CAH,0CAH, DB  0CAH,04AH,0CAH,0CAH,0FEH,03EH,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,0FFH,0FFH, DB  0FFH,0FFH,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,010H,038H,03CH,01FH,043H,060H,031H,019H,00DH,007H,0FFH,0FFH,006H, DB  00CH,01CH,038H,030H,030H,020H,020H,000H,000H,000H,008H,008H,00CH,00CH,007H,007H, DB  042H,073H,03DH,00FH,003H,000H,00FH,00FH,000H,0C0H,0FFH,0FFH,000H,000H,000H,000H, DB  000H,010H,038H,03CH,03FH,033H,010H,018H,00CH,006H,007H,003H,007H,00EH,01CH,01CH, DB  018H,010H,010H,010H,000H,000H,000H,000H,084H,084H,0C4H,065H,03DH,01FH,007H,004H, DB  004H,004H,07FH,07FH,004H,004H,004H,004H,000H,000H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,0FFH,0FFH, DB  0FFH,0FFH,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,080H, DB  0C0H,040H,040H,068H,038H,0B0H,0A0H,020H,060H,060H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,0E0H,0E0H,000H,0F0H,0F0H,000H,000H,000H,000H,000H,000H,000H,000H, DB  040H,040H,040H,040H,0C0H,0E0H,078H,058H,060H,020H,020H,020H,020H,020H,000H,000H, DB  000H,0C0H,0E0H,0A0H,0E0H,060H,0E0H,0E0H,0A0H,0B0H,0F0H,0F0H,000H,000H,000H,000H, DB  000H,000H,000H,000H,000H,0C0H,0C0H,010H,010H,070H,0E0H,080H,000H,000H,000H,000H, DB  000H,000H,000H,000H,000H,000H,020H,0A0H,0A0H,0B0H,090H,010H,010H,0F0H,0F0H,000H, DB  000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,0FFH,0FFH, DB  0FFH,0FFH,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,021H, DB  021H,024H,0ADH,0FBH,072H,03FH,05FH,0C8H,088H,088H,008H,000H,000H,000H,000H,080H, DB  082H,08EH,08CH,0FFH,0FFH,040H,07FH,07FH,04CH,046H,043H,043H,040H,000H,000H,020H, DB  030H,018H,00CH,006H,0FFH,0FFH,02AH,02BH,029H,0FFH,0FFH,000H,000H,000H,000H,000H, DB  000H,0FFH,0FFH,005H,007H,006H,0FFH,0FFH,0CEH,05AH,03BH,06DH,064H,040H,040H,040H, DB  000H,010H,018H,00CH,0C7H,0E3H,0B0H,09CH,0CCH,050H,070H,0E1H,0C3H,006H,006H,004H, DB  004H,000H,000H,000H,01CH,03DH,025H,025H,036H,01EH,01EH,080H,080H,0FFH,0FFH,000H, DB  000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,0FFH,0FFH, DB  0FFH,0FFH,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,002H, DB  002H,003H,001H,000H,000H,000H,000H,000H,001H,001H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H, DB  000H,000H,000H,000H,003H,003H,000H,001H,003H,003H,001H,000H,000H,000H,000H,000H,
代码.doc
35.5 KB, 下载次数: 16, 下载积分: 黑币 -5
