查看: 2612|回复: 0
单片机1分钟计时代码,可以按键控制数字暂停和复位
ID:207124 发表于 2018-11-28 09:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"reg52.h"
//sbit e=P2^4;
//sbit f=P2^5;
sbit duan=P2^6;
sbit wei=P2^7;
sbit LED1=P0^0;                                                //声明LED1为P1.0端口
sbit LEDctr=P1^4;
sbit Beep=P2^2;
sbit key1=P3^2;
sbit key2=P3^4;
sbit key3=P3^6;
sbit key4=P3^7;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delayms(uchar);
uchar numt0,num;
void display(uchar numdis)
                uchar shi,ge;
                shi=numdis/10;
                ge=numdis%10;
                duan=1;
                P0=table[shi];
                duan=0;
                P0=0xff;
                wei=1;
                P0=0xfe;
                wei=0;
                delayms(100);
                duan=1;
                P0=table[ge];
                duan=0;
                P0=0xff;
                wei=1;
                P0=0xfd;
                wei=0;
                delayms(10);
void delayms(uchar xms)
                   uint i,j;
                   for(i=xms;i>0;i--)
                for(j=130;j>0;j--);
void init()
                TMOD=0x01;         //定时器工作模式
                TH0=(65536-20000)/256; //装初始值,20ms一次中断
                TL0=(65536-20000)%256;
                EA=1;                                   //全局中断允许位开
                ET0=1;               //定时器0中断允许位开
void keyscan()
          Beep=1;
          if(key1==0)
                  delayms(1);
            if(key1==0)
                    num++;
                    if(num==60)
                      num=0;
                         Beep=0;
                     while(!key1);
                         Beep=1;
          if(key2==0)
                   delayms(5);
                   if(key2==0)
                     if(num==0)
                            num=60;
                                num--;
                                Beep=0;
                                while(!key2);
                                Beep=1;
           if(key3==0)
                    delayms(5);
                        if(key3==0)
                           num=0;
                           Beep=0;
                           while(!key3);
                           Beep=1;
                if(key4==0)
                    delayms(5);
                        if(key4==0)
                           Beep=0;
                           while(!key4);
                           Beep=1;
                           TR0=~TR0;
        init();
                  keyscan();
                  display(num);
void T0_time()interrupt 1
   TH0=(65535-20000)/256;
   TL0=(65535-20000)%256;
   numt0++;
   if(numt0==50)
                           numt0=0;
                           num++;
                           if(num==60)
                                num=0;
