查看: 5138|回复: 0
8086CPU+8255并行接口扩展实验(源码+仿真)
ID:436262 发表于 2018-11-30 09:17 | 显示全部楼层 |阅读模式
8086芯片源码如下:
; Main.asm file generated by New Project wizard
; Created:   周二 11月 27 2018
; Processor: 8086
; Compiler:  MASM32
; Before starting simulation set Internal Memory Size
; in the 8086 model properties to 0x10000
CODE    SEGMENT
        ASSUME CS:CODE
IOCON EQU 8006H
IOA     EQU 8000H
IOB     EQU 8002H
IOC     EQU 8004H
START:
MOV AL,90H
        MOV DX,IOCON
        OUT DX,AL
        NOP
START1: NOP
        NOP
        MOV AL,0
        MOV DX,IOA
        IN AL,DX
        NOP
        NOP
        MOV DX,IOB
        OUT DX,AL
JMP START1
CODE    ENDS
        END START
全部资料51hei下载地址:
8255.zip (67.72 KB, 下载次数: 43)
