查看: 4311|回复: 2
MSP430将FFFF转换成十进制数并在LED上显示
ID:436127 发表于 2018-11-30 20:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
源の代码:
#include "TM1638.h"
#include "msp430f6638.h"
#include "stdint.h"
#include "math.h"
#include "string.h"
uint8_t num[8];    [ i]//各个数码管显示的值
uint8_t led_flag[8];
const uint8_t tab[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x00};
void init_port(void)
    P3DIR |= BIT5;
    P3DIR |= BIT4 + BIT2;
    P1DIR |= BIT0;    [ i]// ACLK set out to pins
    P1SEL |= BIT0;
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void TM1638_Write(unsigned char DATA) {    [ i]//写数据函数{
    unsigned char i;
    DIO_OUT;
    for(i=0;i<8;i++) {
        CLK_low;
        if(DATA & 0x01)
            DIO_high;
            DIO_low;
      CLK_high;
      DATA >>= 1;
unsigned char TM1638_Read(void) {    [ i]//读数据函数
    unsigned char i;
    unsigned char temp=0;
    DIO_IN;
    STB_low;
    for(i=0;i<8;i++) {
          temp>>=1;
          CLK_low;
          _delay_us(100);
          if(DIO_READ)
              temp |= 0x80;
              temp &= 0x7f;
          CLK_high;
    return temp;
void Write_COM(unsigned char cmd) {    [ i]//发送命令字
    CLK_high;
    STB_high;
    STB_low;
    TM1638_Write(cmd);
    STB_high;
void Write_DATA(unsigned char add,unsigned char DATA) {    [ i]//指定地址写入数据
    Write_COM(0x44);
    STB_low;
    TM1638_Write(0xc0|add);
    TM1638_Write(DATA);
    STB_high;
void init_TM1638(void) {
    unsigned char count = 0;
    unsigned char times = 1;
    while(times--) {
         Write_allLED(tab2[count]);
        count++;
        if(count == 16)
            count = 0;
        _delay_ms(100);
    Write_allLED(0xff);
    _delay_ms(100);
    Write_allLED(0);
void  Write_allLED(unsigned char DATA) {
    unsigned char i;
    Write_COM(0x8F);[ i]//显示控制
    Write_COM(0x40); [ i]//数据命令
    STB_low;
    TM1638_Write(0xc0);
    for(i=0;i<16;i++)
    TM1638_Write(DATA);
    STB_high;
int main(void) {
    WDTCTL = WDTPW + WDTHOLD;
    init_port();
    init_TM1638();
    char s[10] = {'F', 'F', 'F', 'F'};
    int t = strlen(s);
    long sum = 0;
    for(int i = 0; i < t; i++) {
        if(s >= 'A' && s <= 'Z')
[ i]
            s = (s - 'A') + 10 + '0';
        sum += ((s-'0')*(pow(16,t-1-i)));
    char b[10];
    int index = 0;
    while(sum/10>1){
        b[index] = sum%10;
        index ++;
        sum = sum/10;
    b[index] = sum%10;
    index ++;
    sum = sum/10;
    while(index<10){
        b[index] = 15;
        index++;
    while(1) {
        Write_DATA(4*2,tab[b[7]]);
        Write_DATA(5*2,tab[b[6]]);
        Write_DATA(6*2,tab[b[5]]);
        Write_DATA(7*2,tab[b[4]]);
        Write_DATA(0*2,tab[b[3]]);
        Write_DATA(1*2,tab[b[2]]);
        Write_DATA(2*2,tab[b[1]]);
        Write_DATA(3*2,tab[b[0]]);
结果显示为:00065535
sy2-2.zip
1.98 KB, 下载次数: 7, 下载积分: 黑币 -5
ID:436127 发表于 2018-11-30 20:44 | 只看该作者
不知道什么原因后面变成斜体了,大家见谅哈!
ID:1 发表于 2018-11-30 22:47 | 只看该作者
[i]替换成[ i]即可解决变斜体问题
