查看: 4499|回复: 0
STC89C52RC单片机、两片74HC595控制的七段4位数码管和有源蜂鸣器做的闹钟
ID:422055 发表于 2018-11-30 21:10 | 显示全部楼层 |阅读模式
捕获sd.PNG 通过按钮可以调整正常时间和闹钟时间
下面是部分代码
// SCK接P32 DIO接 P33   RCK接P34  上电后数码管会显示时钟
#include <AT89X51.H>
#define DISP_WEI P2
typedef unsigned char U8;
typedef unsigned int  U16;
sbit         KEY1 =P2^4;
sbit         KEY2 =P2^5;
sbit         KEY3 =P2^6;
sbit         KEY4 =P2^7;
U16 tcount;
U8 m;
U8 TIME_HOU_C,TIME_MIN_C,TIME_SEC_C;
U8 TIMER_TEMP,DISP_NUM;
static U8 second,minute,hour;
bit CLOCK_BUFF,CLOCK_FLAG;
bit ADJUST_TIME_FLAG,ADJUST_CLOCK_FLAG;
int bing ;
sbit BEEP = P1^5;
//int mode;//闹钟模式,时间模式 0闹钟   1 时间模式   //2正常模式
U8 code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};  //位选
U8  disbuf[8]={0,0,0,0,0,0,0,0};
U8 ADJUST_TIME[8]={0,0,0,0,0,0,0,0};
U8 code fseg[]={
0xc0,   //0
0xf9,   //1
0xa4,   //2
0xb0,   //3
0x99,   //4
0x92,   //5
0x82,   //6
0xf8,   //7
0x80,   //8
0x90,   //9
0x88,   //10        A
0x83,   //11        B
0xc6,   //12        C
0xa1,   //13        D
0x86,   //14        E
0x8e,   //15        F
0x8b,   //16        h
0x89,   //17        H
0xa3,   //18        o
0xc1,   //19        u
0xaa,   //20        M
0xcf,   //21        I
0xc8,   //22        N
0xbf ,   //23        -
0xff   , // 24   灭
0x00    // 25   全亮
void Buzzer();
void CLOCK_CALC();
void display();
void init();
void IN_KEY();
void hour_time();
void min();
void sec();
void hour_c();
void min_c();
void sec_c();
void sdata_c();
void DISP_ADJUST_TIME();
//数据传输//
void sdata(void)
unsigned char b,c,num;
         if(b==0)
          b++;
        num=segbit[m];
          for(c=0;c<8;c++)
                  P3_2=0;
                   P3_3=num&0x80;
                   num<<=1;
                   P3_2=1;
        if(b==1)
            b--;
          if((m==2||m==5))
          {num=0xbf;}
             num=fseg[disbuf[m]];
                  for(c=0;c<8;c++)
                   {  P3_2=0;
                         P3_3=num&0x80;
                         num<<=1;
                         P3_2=1;
             m++;
             if(m==8)
                 {m=0;
//数据传输//
void sdata_c(void)
         if(b==0)
          b++;
        num=segbit[m];
          for(c=0;c<8;c++)
                  P3_2=0;
                   P3_3=num&0x80;
                   num<<=1;
                   P3_2=1;
        if(b==1)
            b--;
                    num = fseg[ADJUST_TIME[m]];
                  for(c=0;c<8;c++)
                   {  P3_2=0;
                         P3_3=num&0x80;
                         num<<=1;
                         P3_2=1;
             m++;
             if(m==8)
                 {m=0;
//延时0.1ms个单位//
void delay (unsigned char h)
  {        while(h--);
  //延时0.1ms个单位//
//数据输出//
void out(void)
  P3_4=0;
  delay(50);
  P3_4=1;
//数据输出//
  void bcon(void)
        disbuf[0]=second%10;
        disbuf[1]=second/10;
        disbuf[3]=minute%10;
        disbuf[4]=minute/10;
        disbuf[6]=hour%10;
        disbuf[7]=hour/10;
void DISP_ADJUST_TIME(){
sdata_c();
out();
   void display(){
   bcon();
   sdata();
   out();
  //主函数//
void main(void)
init();
   display();       //显示时间
   IN_KEY();         //按键
   Buzzer();       //闹钟
  while(1);
//主函数//
全部资料51hei下载地址:
时钟-闹钟代码.rar (109.94 KB, 下载次数: 89)
