查看: 3975|回复: 1
MSP430实现定时器的源程序
ID:436127 发表于 2018-11-30 22:00 | 显示全部楼层 |阅读模式
该程序使用到了TM1638,附件中有。
(上一篇文章中的程序包含了此程序的公共代码部分,但是我忘了把 tm1638.h 放到附件里面了,这次补上)
定时器初值设为00:02:15,结束后重置为23:59:59
源の代码:
#include "TM1638.h"
#include "msp430f6638.h"
#include "stdint.h"
uint8_t num[8];    //各个数码管显示的值
uint8_t led_flag[8];
const uint8_t tab[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x00};
void init_port(void)
    P3DIR |= BIT5;
    P3DIR |= BIT4 + BIT2;
    P1DIR |= BIT0;    // ACLK set out to pins
    P1SEL |= BIT0;
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void TM1638_Write(unsigned char DATA)   //写数据函数
    unsigned char i;
    DIO_OUT;
    for(i=0;i<8;i++)
      CLK_low;
      if(DATA & 0x01)
          DIO_high;
          DIO_low;
      CLK_high;
      DATA>>=1;
unsigned char TM1638_Read(void)     //读数据函数
    unsigned char i;
    unsigned char temp=0;
    DIO_IN;
    STB_low;
    for(i=0;i<8;i++)
          temp>>=1;
          CLK_low;
          _delay_us(100);
          if(DIO_READ)
              temp |= 0x80;
              temp &= 0x7f;
          CLK_high;
    return temp;
void Write_COM(unsigned char cmd)  //发送命令字
    CLK_high;
    STB_high;
    STB_low;
    TM1638_Write(cmd);
    STB_high;
void Write_DATA(unsigned char add,unsigned char DATA)  //指定地址写入数据
    Write_COM(0x44);
    STB_low;
    TM1638_Write(0xc0|add);
    TM1638_Write(DATA);
    STB_high;
void init_TM1638(void)
    unsigned char count = 0;
    unsigned char times = 1;
    while(times--){
        Write_allLED(tab2[count]);
        count++;
        if(count == 16)
            count = 0;
        _delay_ms(100);
    Write_allLED(0xff);
    _delay_ms(100);
    Write_allLED(0);
void delay(){
    for (int i=0; i<10; i++)
      for (int j=0; j<1000; j++);
void  Write_allLED(unsigned char DATA){
    unsigned char i;
    Write_COM(0x8F);//显示控制
    Write_COM(0x40); //数据命令
    STB_low;
    TM1638_Write(0xc0);
    for(i=0;i<16;i++)
    TM1638_Write(DATA);
    STB_high;
int main(void)
    WDTCTL = WDTPW+WDTHOLD;
    init_port();
    init_TM1638();
    int hourA = 0;
    int hourB = 0;
    int minuteA = 0;
    int minuteB = 2;
    int secondA = 1;
    int secondB = 5;
    while(1) {
        secondB--;
        if(secondB == -1) {
            secondB = 9;
            secondA--;
            if(secondA == -1) {
                secondA = 5;
                minuteB--;
                if(minuteB == -1) {
                    minuteB = 9;
                    minuteA--;
                    if(minuteA == -1) {
                        minuteA = 5;
                        hourB--;
                        if(hourB == -1) {
                            hourB = 9;
                            hourA--;
                            if(hourA == -1) {
                                hourA = 2;
                                hourB = 3;
        Write_DATA(4*2,tab[hourA]);
        Write_DATA(5*2,tab[hourB]);
        Write_DATA(6*2,tab[15]);
        Write_DATA(7*2,tab[minuteA]);
        Write_DATA(0*2,tab[minuteB]);
        Write_DATA(1*2,tab[15]);
        Write_DATA(2*2,tab[secondA]);
        Write_DATA(3*2,tab[secondB]);
        delay();
sy2-3-1.zip
1.94 KB, 下载次数: 7, 下载积分: 黑币 -5
定时器
ID:436127 发表于 2018-11-30 22:17 | 显示全部楼层
补充说明一下,主函数中的delay是我自己写的,是为了便于调试,并没有真正起到延时1s的作用
