查看: 3955|回复: 1
基于stm8单片机的DHT11温湿度测量仪程序
ID:438219 发表于 2018-12-3 11:00 | 显示全部楼层 |阅读模式
程序代码:
(1)函数声明、变量定义代码:
Wsdcl_main.h文件:
#include"stm8s.h"
#define u8 unsigned char
#define u16 unsigned char
#define u32 unsigned long
#define KEY_PORT  GPIOE
#define KEY_PIN   GPIO_PIN_0
extern unsigned int   temp_1,temp_2, temp_4,temp_5;
extern unsigned int  humi_1, humi_2, humi_4, humi_5;
void CLK_Configuration(void);
void GPIO_Configuration(void);
void KEY_Init(void);
void TIM2_Configuration();
void ceshi_on(void);
void Alarm_Beep();
void ceshi_off(void);
DHT11.h文件:
#include"stm8s.h"
#define DHT11_IO_IN  GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_IN_PU_NO_IT)//输入模式
#define DHT11_IO_OUT GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_OUT_PP_LOW_FAST)//输出模式
#define GPIO_PIN_UP  GPIO_WriteHigh(GPIOE, GPIO_PIN_6)//拉高电平
#define GPIO_PIN_DOWN GPIO_WriteLow(GPIOE, GPIO_PIN_6)//拉低电平
#define        DHT11_DQ_IN  GPIO_ReadInputPin(GPIOE, GPIO_PIN_6) //读取引脚信号
extern unsigned char Table_Data[4];
unsigned char DHT11_Get_Data(void);
int start_DHT11(void);
7219.h文件:
#include"stm8s.h"
#include"wsdcl_main.h"
/*定义7219各个地址*/
#define MSB       0x80
#define LSB       0x01
#define DECODE_MODE   0x09
#define INTENSITY     0x0A
#define SCAN_LIMIT    0x0B
#define SHUT_DOWN     0x0C
#define DISPLAY_TEST  0x0F
#define   GPIO_PORT    GPIOD
void Init_Max7219();
void clear_7219();
void Write_Max7219(unsigned char address,unsigned char dat);
void Display_Error(void);
void Display_Temp(void);
void Display_Humi(void);
Delay.h文件:
#include"stm8s.h"
void Delay_ms(u32 ms);
void Delay_us(u32 us);
(2)主函数代码:
Wsdcl_main.c文件:
#include"stm8s.h"
#include"7219.h"
#include"Delay.h"
#include"DHT11.h"
int _Turn;
int main()
{   _Turn=1; //先显示温度
   CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //时钟配置16MHz
   KEY_Init();  //按键切换显示初始化
    TIM2_Configuration();//TIM2时钟配置
   if(start_DHT11()==1)//检测是否有响应,结果有响应往下执行
     DHT11_Get_Data();  //从DHT11取数据
        /*设置温湿度警戒 蜂鸣器报警*/
        if((Table_Data[2]>30)|(Table_Data[0]>60))
          Alarm_Beep();
        else   GPIO_WriteLow(GPIOD,GPIO_PIN_4);
           Init_Max7219(); //初始化Max7219
            /*取温度数据各个位数值*/
            temp_1=Table_Data[2]/10;
            temp_2=Table_Data[2]%10;
            temp_4=Table_Data[3]/10;
            temp_5=Table_Data[3]%10;
            /*取湿度数据各个位数值*/
            humi_1=Table_Data[0]/10;
            humi_2=Table_Data[0]%10;
            humi_4=Table_Data[1]/10;
            humi_5=Table_Data[1]%10;
        /*按键切换显示温湿度*/
        if(_Turn>0)
         Display_Temp();
         Display_Humi();
/*蜂鸣器报警函数*/
void Alarm_Beep()
  GPIO_Init(GPIOD, GPIO_PIN_4, GPIO_MODE_OUT_PP_LOW_FAST);
  BEEP_DeInit();
  BEEP_Init(BEEP_FREQUENCY_1KHZ);
  BEEP_LSICalibrationConfig(12800);
  BEEP_Cmd(ENABLE);
  GPIO_WriteHigh(GPIOD,GPIO_PIN_4);//蜂鸣器响
void ceshi_on(void)//用LED灯来测试程序运行情况
GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_WriteLow(GPIOE, GPIO_PIN_5);
GPIO_WriteHigh(GPIOE, GPIO_PIN_5);
/*********************TIM2配置*****************************/
   TIM2_DeInit();
   TIM2_ClearITPendingBit(TIM2_IT_UPDATE);
   TIM2_TimeBaseInit(TIM2_PRESCALER_8192,0xF42);//2秒产生一次中断
   TIM2_ITConfig(TIM2_IT_UPDATE, ENABLE);
   TIM2_Cmd(ENABLE);//启动定时器2
   enableInterrupts();//开总中断
/*********************按键配置*****************************/
void KEY_Init(void)
  GPIO_Init(KEY_PORT,KEY_PIN,GPIO_MODE_IN_PU_IT);
  EXTI_SetExtIntSensitivity(EXTI_PORT_GPIOE, EXTI_SENSITIVITY_FALL_ONLY);//只有下降沿触发
  enableInterrupts();
/*********************中断服务函数*****************************/
#pragma vector=9
__interrupt void EXTI_PORTE_IRQHandler(void)//按键中断切换显示服务函数
  _Turn=-_Turn;
#pragma vector=15
__interrupt void TIM2_UPD_OVF_BRK_IRQHandler(void)//定时中断更新数据服务函数
  start_DHT11();
  DHT11_Get_Data();//更新温湿度数据
(3)DHT11温湿度传感器模块代码:
DHT11.c文件:
#include"stm8s.h"
#include"DHT11.h"
#include"Delay.h"
int count_1,count_2;
unsigned char sbuf;
/**********************唤起DHT11**************************************/
         GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_OUT_PP_LOW_FAST);
         GPIO_WriteLow(GPIOE, GPIO_PIN_6);//拉低18ms以上
         Delay_ms(10000);//Delay_ms(18);
         GPIO_WriteHigh(GPIOE, GPIO_PIN_6);
         Delay_us(30);  //拉高20~40us
         GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_IN_PU_NO_IT); ceshi_on();
         while(!DHT11_DQ_IN);//等待80us低电平结束
         while(DHT11_DQ_IN); ceshi_off();//等待80us高电平结束
         return(1); //应答成功返回1
/************************读取8位字节***********************************/
void com(void)
        u8 i;
        sbuf=0;
        for(i=8;i>0;i--)
           count_1=2;
          while((!DHT11_DQ_IN)&&count_1++); //等待传送数据开始50us低电平结束并记录所用时间count_1
           count_2=2;
while((DHT11_DQ_IN)&&count_2++) ;//等待"1"或"0"高电平结束并记录所用时间count_2
        if(count_2>(count_1))  //比较count_2与count_1来判断输入是"1"还是"0"
          {        sbuf<<=1;
                        sbuf|=0x01;
          {  sbuf<<=1;
                   sbuf|=0x00;
/**********************读取数据**************************************/
unsigned char DHT11_Get_Data()
{        u32 check,sum;
                com();
                Table_Data[0]=sbuf;//湿度8位整数
                com();
                Table_Data[1]=sbuf;//湿度小数部分
                com();
                Table_Data[2]=sbuf;//温度整数部分
                com();
                Table_Data[3]=sbuf;//温度小数部分
                com();
                check = sbuf;//校验部分
                sum =(Table_Data[0]+Table_Data[1]+Table_Data[2]+Table_Data[3]);
        if(check == sum)//校验正确则返回1
         return(1);
        else  return (0);
(4)MAX7219显示模块程序代码:
7219.c文件:
#include"stm8s.h"
#include"DHT11.h"
#include"7219.h"
unsigned int   temp_1,temp_2,temp_4,temp_5;
u8 LEDcode[10]={0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x7b};
/**********************IO口配置************************************/
void Dispaly_GPIO_LoadOn()
  GPIO_Init(GPIO_PORT, GPIO_PIN_1, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_WriteHigh(GPIO_PORT,GPIO_PIN_1);
void Dispaly_GPIO_LoadOff()
  GPIO_Init(GPIO_PORT,GPIO_PIN_1, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_WriteLow(GPIO_PORT,GPIO_PIN_1);
void Dispaly_GPIO_ClkOn()
  GPIO_Init(GPIO_PORT,GPIO_PIN_2, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_WriteHigh(GPIO_PORT,GPIO_PIN_2);
void Dispaly_GPIO_ClkOff()
  GPIO_WriteLow(GPIO_PORT,GPIO_PIN_2);
void Dispaly_GPIO_INPUT()//载入数据
  GPIO_Init(GPIO_PORT,GPIO_PIN_0,GPIO_MODE_OUT_PP_LOW_FAST);
/*******************向Max7219写入8位数据************************/
void Write_Max7219_byte(unsigned char temp)
  unsigned char i,x;
  for (i=0;i<8;i++)
       Dispaly_GPIO_ClkOff();//GPIOD_PIN_2推挽输出,写低电平
       x=temp&MSB;
       if(x==0)
         Dispaly_GPIO_INPUT();//GPIOD_PIN_0推挽输出
         GPIO_WriteLow(GPIO_PORT,GPIO_PIN_0);//输入数据为"0"
         GPIO_WriteHigh(GPIO_PORT,GPIO_PIN_0);//输入数据为"1"
       temp<<=1;
Dispaly_GPIO_ClkOn();//GPIOD_PIN_2推挽输出,写高电平,数据载入16位移位寄存器
/***********************向7219写入16位数据*************************/
    Dispaly_GPIO_LoadOff();//GPIOD_PIN_1推挽输出,写低电平
    Write_Max7219_byte(address);
    Write_Max7219_byte(dat);
    Dispaly_GPIO_LoadOn(); //GPIOD_PIN_1推挽输出,写高电平,锁存16位数据
/***********************初始化Max7219***************************/
void Init_Max7219(void)
    Write_Max7219(SHUT_DOWN, 0x01);                   //正常操作模式
    Write_Max7219(DISPLAY_TEST, 0x00);           //正常显示
    Write_Max7219(DECODE_MODE, 0x00);           //不采用B译码模式
    Write_Max7219(SCAN_LIMIT, 0x07);                   //设置显示的数据位数
    Write_Max7219(INTENSITY, 0x0A);                   //设置显示的亮度
/**************************清除显示******************************/
void clear_7219(void)
unsigned char i;       //变量i,用来选择数码管位选
for(i=8;i>0;i--)     //i自减,选择完所有的8位
{  Write_Max7219(i,0x00);  //对应位选的段全部清除显示
/*********************温度显示***************************************/
   Init_Max7219();//MAX7219初始化
   clear_7219();   //MAX7219清除显示,免去干扰
    Write_Max7219(0x01,0x4e);//显示摄氏度符号℃
    Write_Max7219(0x02,0x63);
    Write_Max7219(0x03,LEDcode[temp_5]);
    Write_Max7219(0x04,LEDcode[temp_4]);
    Write_Max7219(0x05,LEDcode[temp_2]|0x80);
    Write_Max7219(0x06,LEDcode[temp_1]);
/************************湿度显示************************************/
    Write_Max7219(0x01,0x37);//显示湿度符号RH
    Write_Max7219(0x02,0x77);
    Write_Max7219(0x03,LEDcode[humi_5]);
    Write_Max7219(0x04,LEDcode[humi_4]);
    Write_Max7219(0x05,LEDcode[humi_2]|0x80);
    Write_Max7219(0x06,LEDcode[humi_1]);
(5)延时函数程序代码:
#include"stm8s.h"
#include"Delay.h"
  void Delay_ms(u32 nCount)
  for(char i=0;i<10;i++)
  {    while (nCount != 0)
    {      nCount--;
/*微秒延时函数*/
void Delay_us(u32 nCount)
{  for(char i=0;i<5;i++)
    {      nCount--;
ID:1 发表于 2018-12-4 04:35 | 显示全部楼层
补全原理图或者详细说明一下电路连接即可获得100+黑币
