查看: 2035|回复: 0
单片机滚动显示电话号码 C语言程序
ID:438865 发表于 2018-12-3 23:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//程序:ex30.c
//功能:在8×8LED点阵上从下向上滚动显示出手机号码 "13592346786"
#include <REGX51.H> //包含头文件REGX51.H,定义了51单片机的所有SFR
//函数名:delayms
//函数功能:实现软件延时
//形式参数:无符号整型变量i,控制时间为i*1ms
//返回值:无
void   delayms(unsigned int i)
{unsigned char k;
while(i--)
for(k=0;k<120;k++);     //120次空操作
unsigned char code led[]={0xff,0xe7,0xc7,0xe7,0xe7,0xe7,0xe7,0xe7,          //1
                                0xff,0x87,0xf3,0xf3,0xc7,0xf3,0xf3,0x87,           //3
                                                 0xff,0x87,0xbf,0x87,0xf3,0xf3,0xf3,0x87,          //5
                                                 0xff,0xc7,0x93,0x93,0x93,0xc3,0xf3,0xc7,          //9
                                                 0xff,0x87,0xf3,0xf3,0xc7,0x9f,0x9f,0x83,          //2
                                0xff,0xf3,0xe3,0xd3,0xb3,0x83,0xf3,0xf3,          //4
                                0xff,0xc7,0x9f,0x87,0x93,0x93,0x93,0xc7,          //6
                                0xff,0x03,0xf3,0xe7,0xe7,0xcf,0xcf,0xcf,      //7
                                0xff,0xc7,0x93,0x93,0xc7,0x93,0x93,0xc7,          //8
                                                0xff,0xc7,0x9f,0x87,0x93,0x93,0x93,0xc7};    //6
   unsigned char w;
   unsigned int i,j,k,m;
     for(k=0;k<88;k++)                  //显示滚动行数控制变量
           for(m=0;m<100;m++) //每个字符扫描显示100次,控制每个字符显示时间
                   w=0x01;
           j=k;
           for(i=0;i<8;i++)
               P1=w;                           //行数据送P1口
               P0=led[j];                      //列数据送P0口
               delayms(1);
                           P0=0xff;                        //关显示
               w<<=1;                          //行变量左移指向下一行
                           j++;                            //指向数组中下一个显示码
               if(j>87)j=j-88;                 //如果列数据显示完回到初始
